Question about HP LaserJet 2420 Printer
Question on a 52.00 error message on an HP LaserJet 2420dn.
    Problem Solver:
  • 3 Answers
Look for a broken tab on top of your cartridge; if you have one, the laser safety interlock is not being opened when the cartridge is inserted. Install new cartridge.
If you don't have cartridge damage, there may be a failure of the laser assembly or (less likely) the engine controller board.
Posted on Nov 16, 2009
  • 102 Answers
SOURCE: Printer Hp Laserjet 3055 giving error message 5
If you scanner error 5 or printer hangs at scanner bulb warming up than the issue is with Scanning Assembly inside the printer and it is hardware issue.
Posted on Jul 02, 2009
Nikhil Gedam
  • 87 Answers
SOURCE: HP Laserjet 2420dn - Faint
  • Please perform a half page test, by printing a test page from tray 1.
  • Open the top cover as soon as the paper is 70% through from tray 1 so that the media
  • Check if the ghosting appears, if yes, fuser needs swap out.
Posted on Oct 30, 2008
sys_admin
  • 829 Answers
SOURCE: 52 scanner error on HP Color Laserjet 2840
The device has experienced an internal hardware error. Recommended Action
  1. Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.
  2. If the error is still unresolved, contact Hewlett-Packard for technical support to troubleshoot the problem. Call HP for telephone support
Posted on Mar 22, 2009
  • 81 Answers
SOURCE: My HP Laserjet 2420dn will not print and is
This could be a firmware fault on the main formatter board inside the printer
1. Press CANCEL JOB to clear the
print job from the printer
memory.
2. Turn the printer off, and then
turn the printer on again.
3. Go to http: www.hp.com/
support/lj2410, www.hp.com/
support/lj2420, or
www.hp.com/support/lj2430.
Click Download Drivers and
Software
. Check for the
latest firmware image version
at the bottom of the page. If
this firmware image is newer
than the one installed on the
printer and the printer can
receive a firmware update,
download the newer firmware
upgrade. Not all printer
models can receive firmware update
Posted on Jan 01, 2010
  • 121 Answers
SOURCE: Hp laserjet M2727nf scanner error 52
First, power the printer off, wait for about 30secs and power on. If problem persist replace the scanner.
Posted on Feb 23, 2010
Error in 2420dn laserjet 57.03
57.03 is a fan error. If power cycling the printer doesn't clear the message, Which ever is the bad fan will have to be replaced.
In other words you are going to have to remove the covers to find the bad fan. Or have a printer tech check it out for you.
Aug 18, 2011 | HP LaserJet 2420dn Printer
I am getin an error in hp laserjet 2420 printer which says 57.03 error restart the printer again
A temporary printing error occurred in one of the printer fans.
Check the fans are not stuck - use air duster to see if they spin
Aug 06, 2010 | HP LaserJet 2420dn Printer
Does not print, get error message
unplug, wait a minute, replug in. try it
check cartridges and rollers to insure nothing is blocking the printing formation.
is there too much paper in the tray?
hp has an awesome trouble shooting web site as a last choice.
Apr 29, 2010 | HP LaserJet 2420dn Printer
HP LaserJet 2420dn display is blank when powering on.
I had the same problem here. Removed memory and put it in the other slot and problem solved!
Feb 22, 2010 | HP LaserJet 2420dn Printer
HP Laserjet 2420dn will not print and is displaying message '49.FF04 service error'
Does the error display when printing a particular job, or anything that you print? If you have extra memory installed, remove it. Power up and try again. If it won't clear replace the formatter
Jan 29, 2010 | HP LaserJet 2420dn Printer
Hp 2420dn printer problem
"Low subthermistor fuser error"
replace fuser unit or replace thermistor first.
Jun 19, 2009 | HP LaserJet 2420dn Printer
I need hplaserjet 2420dn driver
http://www.printcountry.com/drivers/HP_DRIVERS.asp
http://www.soft32.com/download_176629.html
Dec 17, 2008 | HP LaserJet 2420dn Printer
LaserJet 2420dn Error
The error means -
A critical firmware error has
occurred.
Recommended action
1. After performing the actions
listed in the preceding item, if
the message persists when
using different software
programs and attempting
specific print jobs, disconnect
all cables that connect the
printer to the network or a
computer.
2. Turn the printer off.
3. Remove all memory DIMMs
or third-party DIMMs from the
printer. (Do not remove the
firmware DIMM in slot J1.)
4. Remove all of the
EIO devices from the printer.
5. Turn the printer on.
6. If the error message
disappears, reinstall
each DIMM and EIO device
individually, making sure to
turn the printer off and then
on again as you install each
device. To replace a DIMM,
see.
7. Replace the DIMM or
EIO device that caused the
error message.
8. Remember to reconnect all of
the cables that connect the
computer.
9. If this error message persists,
replace the firmware DIMM.
10. Replace the formatter
Jun 03, 2008 | HP LaserJet 2420dn Printer
SHOWS FF95 ERROR MESSAGE
This error is due to corrupt firmware or the correct network connectivity.
Please upgrade the firmware of the printer by following the link below:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c00280149&jumpid=reg_R1002_USEN
- Let me know once done
- Nikhil
May 31, 2008 | HP LaserJet 2420dn Printer
Service error
What's the error message?
Apr 28, 2007 | HP LaserJet 2420dn Printer
HP LaserJet 2420 Printer Logo
266 people viewed this question
Seeker5211
Seeker5211
