Question about Garden
Lack of power in my chain saw
My Craftsman 18'' chainsaw does not seem to have the power it used to - do you have any ideas why not?
freetek
  • 5568 Answers
SOURCE: where can I get manual for model 358.355061 craftsman chainsaw ?
Sears sells manuals for a reasonable cost; my last one was $7 US. Go to their website at sears.com and follow the links.
Posted on Aug 07, 2009
dontbother10
  • 2220 Answers
SOURCE: sear craftsman 18 inch electric saw does not work
No reset or in line fuse I'm aware of. I'd return it to Sears and test any replacement at the store prior to leaving.
Please discuss this with someone in charge of that department. If this has been a problem perhaps try a different model.
Read the manual about the size of conductors in any extension cord too, it may be a contributing factor. HTH
Lou
Posted on Oct 25, 2009
dontbother10
  • 2220 Answers
SOURCE: 18"poulan chainsaw
Start at 1.5 CCW form lightly seated then tune for performance like this:
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too.
I think your starting procedure may be the cause of flooding. Flooded is the #1 cause of hard starts in 2-cycle engines. Read carefully the recommended start in your manual. most miss the second note. It should be similar to this (read 3, read it again):
Warm start in the manual says 1/2 choke BS. Close choke, (sets fast idle) open choke, pull rope.
Start Procedure
Cold:
  1. Ignition on/off to on
  2. Set compression release – optional step even if saw is equipped with a compression release
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls; no more than 4).
  4. Set compression release – optional step even if saw is equipped with a compression release.
  5. Push (open) choke pull starter until it starts (usually first pull).
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) – Do not pull with choke closed.
  4. Push (open) choke, pull starter until it starts (usually first pull).
If you still have trouble reply as you did before. I will get back to you. HTH
Lou
Posted on Feb 19, 2010
Testimonial: "you'all have been very helpful.to even ask a question at a repair shop around here you must first hand them your wallet! Thank kindly"
SOURCE: I have a craftsman gas chain saw model 358.352180....
Make sure you drain the oil when storing your saw. That's because the saw is designed to supply a generous amount of oil to the chain and bar.
Posted on Jun 18, 2010
  • 95 Answers
SOURCE: my 18 " craftsman chainsaw will not oil the chain.
Take the bar off and clean the grove out with something like a small flat blade screwdriver.Make sure its open where it bolts on.It gets its oil through the bolt holes.If you have a way to blow the dirt out it helps.You can try running the saw without the bar on to see if its putting out any oil.If not you will have to get to the oil pump to see if its not bad.
Posted on Mar 08, 2011
Crafstsman chainsaw model 35.8352180
http://sophiesophieshops.ecrater.com/p/6490866/sears-craftsman-owners-manual-23a-23
Apr 01, 2013 | Craftsman sears 18" Chain Saw Chain (...
Craftsman 18" chainsaw runs but dies when I press the throttle, new carb and fuel lines low and high speed set at 1 turn .
remove the muffler and run it after seeing that it runs good open the muffler and clean the screen inside
Sep 27, 2012 | Craftsman sears 18" Chain Saw Chain (...
Describe your sears 18"
if such problem happened when you didn't touch the throttle, then open the filter cover and take out the filter you may see the carburettor and then pull the choke, you may find the issue
Sep 21, 2011 | Craftsman sears 18" Chain Saw Chain (...
I put a new bar and chain on my craftsman 18" chainsaw because the chain keeps coming loose. I am still having the same problem, after running 10 seconds, the chain falls off.
Sep 11, 2011 | Craftsman sears 18" Chain Saw Chain (...
My 18 " craftsman chainsaw will not oil the chain.
Mar 08, 2011 | Craftsman sears 18" Chain Saw Chain (...
Chain saw manual 358-354831
Hi and welcome to FixYa, I am Kelly
Not sure if you looking for a parts list or an owners manual.
Owners manual and parts listing: 3.88 mb:
http://www.managemylife.com/mmh/owner_manuals/22739/CRAFTSMAN-Chainsaw-Gas-L0904588?brand_name_search=358354831+CRAFTSMAN (Takes a while to load)
On line Parts list:
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Chainsaw-Parts/Model-358354831/0247/1503220?sid=PDVertical
If the 1st link does not work use this one:
http://www.managemyhome.com/mmh/products/ManualSearch.action?sid=MMHMxSearsx00019&product.modelNumber=358354831&product.brandName=CRAFTSMAN
and then click on the model number to see the manual.
You can also wait until the on-line parts list loads using the 2nd link above and on the right side of the page click on view manuals.
This should be what you were looking for. Thanks for choosing FixYa,
Kelly
Jan 28, 2011 | Craftsman sears 18" Chain Saw Chain (...
Chainsaw model #358.35181 will not start can I get a manual for this
You can locate the manual directly through www.searspartsDirect
or:
http://www.managemylife.com/mmh/owner_manuals/search?sid=MMHMxSearsx00019&query=358351810+CRAFTSMAN
Then click on "View Manual"
Sep 27, 2010 | Craftsman sears 18" Chain Saw Chain (...
Have a craftsman # 358.350880 saw will not accelerate and lacks power
Check the fuel filter, air filter, and muffler for plugging. Check the fuel lines for decay or other damage. Make sure the carburetor fasteners are tight. Check for proper chain oiling by running the saw at speed for several moments with the bar tip near some cardboard--it should throw off a thin line of oil. Hope this helps!
Aug 13, 2010 | Craftsman sears 18" Chain Saw Chain (...
Craftman,36cc, 18" Gas Power Saw Blade
Go to a home improvement store and buy a new chain, they are cheap!
Jul 29, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Garden Logo
43 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
