Question about Samsung M8800 Pixon - Unlocked QuadBand Cell Phone - 8MP Camera, GPS, 3.2" Touchscreen - Interna
How to fit replacement screen for a samsung m8800 mobile
3 Suggested Answers
  • 12 Answers
SOURCE: Samsung M8800 mobile touch screen not working.
It is a problem in this set... there is one solution I found on the internet...
just follow this link
http://www.handcellphone.com/mobile/forum/screen-freeze
mine is working now
But try it at your own risk
Posted on Jun 09, 2010
SOURCE: fitting instuctions for replacing lcd screen on my samsung e250 mobile phone
ok...
1.take off battery cover, remove battery, memory card and sim card
2. remove the five screws on the back... two at the bottom, two in the middle and one on the mid top right and take off this cover, remember! keep the screws safe
3. slide the phone up and take out the two screws on the left and right paralel with the battery tabs then remove the two screws ether side of the camera...they might be covered by rubber coverings, these pop out easily
4.now you can prise the top of the screen off with a small flat headed screwdriver
THERE ARE TWO OPTIONS HERE, IF THE REPLACEMENT SCREEN HAS NO RIBBON CABBLE ATTACHED THEN FOLLOW FROM FIVE, IF IT HAS ONE CONNECTED THEN FOLLOW FROM
5. its conected to a ribbon cable, remove the tape and slide out the cabble from the screen.
6. now take out the screen PCB from the plastic casing and replace it with your new one and put the ribbon cable in and clip it back together, now reverse stages 3 to 1 to put it back together.
7. if the ribbon cable is attached now you must look at the PCB board on the back for a square copper line, on the left of this there is a big black square just smaller than the copper square, prise this off with your finger nails, keeping it to the side take the PCB up about 2mm and then fold the bottom of it to revele it is conected to a ribbon cable by a bigger version of the black square so prise this off and take the PCB and put it safely to one side.
8. look on the front of the phone under the top bit of the screen, there should be a semi circle in the plastic with a black circle in the top of it, use your nail or a flat headed screwdriver to pop it to the other side of the semi circle, now the slider should go past what it used to o you can slide it up to when you can see the ribbon cable go down through the phone, now push the black square end through and you should be able to slide the whole front off.
9. replace the screen by taking the screen PCB out and repacing it, then thread the ribbon cable back through and slide the front on while making sure the back circle goes into the semi circle and to the top side of it, then thread the black square through the phone to the front and clip the phone front back on.
10. snap the black square back on to the back Circuit then put the circuit back into the phone and snap the small black square back on then go from stages 3 to 1 to put it back together.
this should be fairly easy to do for most people.
Posted on Mar 04, 2009
How can i unfreeze a samsung m8800 pixon
Hello, it's possible to solve Phone Freeze for Samsung m8800 on Fastgsm.com. I hope it helps.
Mar 24, 2013 | Samsung M8800 Pixon 8mp Gps Att T-mobile...
My Samsung M8800 is Freezing, can anybody please help me?
Do not worry get the unfreeze code for your Samsung M8800 pixon model mobile from this site Unlocking4u.com , here it gives the easy methods to get the mobile as unfreezes...........
Mar 26, 2012 | Samsung M8800 Pixon - Unlocked QuadBand...
How to unlock samsung pixon m8800
You can get the Unlock code from service provider...
Aug 03, 2011 | Samsung M8800 Pixon - Unlocked QuadBand...
My phone model is samsung m8800, when i switch on the mobile the text material written on the screen is demsbl boot loader msm6280 downloader ver 5.43
Do a Samsung Master Reset:
CAUTION: A "master reset" changes the phone settings back to default. This process will erase all contacts, downloaded settings, and downloaded applications (ringtones, wallpapers, graphics, etc). This process cannot be undone.
Enter *2767*3855# from the standby screen. (You may need to remove the SIM before it will allow you to type the code in)
Dec 27, 2010 | Samsung M8800 Pixon - Unlocked QuadBand...
Samsung m8800 my touch screen doesn`t work ...it hangs or get stuck sometimes ..what is the reason and got some solution for that or ..it`s just the software that has been made to hang after finishing it`s...
It is a hardware problem, there is one solution I found on the internet...
mine is working now
May 15, 2010 | Samsung SGH-E840 Smartphone
My screen has locked on the samsung m8800 I have switched off and waited 5 mins, removed the battery and replaced it and nothing is happening, I cant even enter my pin
If the screen has frozen, there is one solution I found on the internet...
mine is working now
May 09, 2010 | Samsung M8800 Pixon - Unlocked QuadBand...
mine is working now
May 05, 2010 | Samsung Tocco F480 - Pay Monthly Cellular...
Touch of the cell is not working
Switch off the mobile and then recharge it full in off mode. If the problem exist, better take to a dealer
Feb 27, 2010 | Samsung M8800 Pixon - Unlocked QuadBand...
Touch screen wont work on my Samsung pixon.
I had the same symptons with my samsung m8800 and all i did was squeeze the top right corner of the phone and hey presto it worked agin. I believe it could be a lose connection. hope this helps
Jul 27, 2009 | Samsung M8800 Pixon - Unlocked QuadBand...
Samsung M8800 Pixon - Unlocked QuadBand Cell Phone - 8MP Camera, GPS, 3.2" Touchscreen - Interna Logo
386 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
