Question about Logitech Harmony One Advanced Universal Remote with Color Touch Screen
Remote will light up but will not work was on charger for 10 hours
    Scholar:
  • 89 Answers
Hey!
I have found that usually when my Harmony remote stops working, a firmware update will get it working again. If you dont know how to do one, just look at the link here:
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=10747
Hope this helps!!!
-Kennedy
Posted on Mar 31, 2010
How do I charge a moxie power scooter??
  • Turn the scooter's power switch to the OFF position.
  • Connect the charger's plug to the charging port on the scooter.
  • Plug the charger's power cable into a power outlet.
  • When the charger's LED red/orange light is on, the battery is charging. Optimal charging time is 6 to 8 hours, or up to 10 hours to achieve a complete charge. The scooter manual will have the exact charging
  • Times recommended for your scooter.
  • Stop charging when the LED light is completely green.
  • Disconnect charger from the scooter, then from the power outlet.
  • Run your scooter before riding it to verify the battery charge.
Feb 02, 2016 | Health & Beauty
How do I know its fully charged?
It depends if the charger are intelligent or not, check the owners manual.sometimes changes, it depends the manufacturer charger.when it compares charges, disconect itself the circuit. not always.
Oct 18, 2014 | SoundLogic Sound Logic Power Cell...
My victory 4 mobilty wont charge the green light is very faint/the charger was tested working.so why wont my scooter charge
make sure battery cables are secure at battery terminals and clean.how old are the batteries.If the batteries run down fast they are no good.a good way to test them is put scooter against some thing solid and go forward.If the battery indicator drops to o the batteries are no good.It takes about 10 hours to charge the batteries
Mar 15, 2013 | Pride New Mobility Victory XL 4 Wheel...
I just bought a 339 Metal series r/c helicopter and I haven't even used it yet because when I pulgged the charger from the remote up the LED lights would not come on... So I don't know If its...
Leave it on the charger for an hour. The lights can be turned on and off from the remote control. After an hour go through the start up procedure in the instructions.
Dec 25, 2012 | Toys
Turn key...nothing.....radio...ac....lights work....is it my starter?
If there is nothing, you probably have a dead battery-nothing else would cause no crank/lights or accessories unless it was a bad connection at your battery terminals. charge the battery with a battery charger ) a 2 amp charger would take a couple of days, 10 amp about 8 to 10 hours and a 50 amp about 3 hours, but charging slowly is better for the battery)- If you have a voltage meter, chances are your battery is well below 12 volts, and as it sits it should recover somewhat, but probably you will still need to at least charge it. Conventional batteries do not do well with full discharges and it can 'kill' even a fairly new battery in short order, so prepare for the possiblilty that you need to replace it.
Jul 04, 2011 | 2000 Chevrolet 3500
It tells you to that you should charge the battery
The problem is your batteries are either over heating or worn out. You might also have a problem with the charger but you'll need Dewalt tech support to determine if it's good or bad.
The first thing to do is clean the contacts. Use a white plastic pencil eraser and clean all the contacts you can reach. If there are any contact you can reach with the eraser use a Q-tip that is just damp (not wet) with rubbing alcohol to clean them.
Discharge your batteries completely then put them in the freezer for 8-24 hours. Take the batteries out of the freezer and let the set 24-48 hours after that put them on the charger, they'll either charge or you need new batteries (more likely) or a charger.
Jul 01, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
After charging the wii remotes in the base until
I don't think you are doing anything wrong, just the setup you are useing is'nt as effective as you would like.
I use the energizer rechargeable (NiMH) batteries with the energizer 15 minute charger. The other batteries and chargers just don't seem to work as well. I get several hours of play time on a single charge, where I was only getting about 1/2 hour to an hour with the others. **No I am not a paid endorser, I just use and like the product!**
Hope this helps, please let me know how you end up or if I can help more.
Mar 05, 2010 | Nintendo Wii Console
New battery. Charged for 24 hours. Light is green, but after 20 seconds light turns red and it stops.
There's a chance that the battery you bought is bad. There's a greater chance that the problem is with the charger. If you're using the dock to charge, try plugging the charger directly into the roomba just to rule that out. If that doesn't fix the problem, I would try borrowing or buying a new charger, and see if that works. If a new charger and new battery don't solve the problem, the problem must be with your roomba itself.
Sep 25, 2009 | Roomba Robotic Floor Bagless Vacuum
Mx 3000 universal lcd remote
There are 4 reasons why your unit is behaving this way:
1. Charger is the problem.
2. The docking station is the broken.
3. The battery is broken or not accepting charge.
4. The actual unit is the problem.
It is very hard to tell which one is causing this to happen.
Let us do some troubleshooting first:
1. Plug your charger in an A/C outlet and make sure the red power light (left) is lit, otherwise the charger or the docking station is broken.
2. You can test the charger with a multimeter. Unplug the charger from the docking station and measure the voltage across the outside and inside, it should register more than 5 volts DC. If there is a 5Volt DC the docking station is the problem otherwise the charger is broken.
3. If the red power light is lit and the status light (right) is lit too, your docking station is broken.
4. If the red power light is lit, dock the unit into the charger, the status light (left) should turn red when your battery is accepting charge or turn blue when your battery is fully charged.
5. If the status light will not lit at all (while the red power light is on), tap the screen while the unit is docked on the charger. If the unit will become alive, you need a new battery otherwise you need a new unit.
12 hours is very long time to charge, the status light should turn to blue in less than 2 hours especially for a new battery.
Aug 29, 2008 | Universal Remote Control MX-3000 LCD...
S-750DD
Not sure if this will help... however an altmeter will allow you to test along your electrics for any faults. You can check at the lights for example and throught the system.
Oct 11, 2007 | Transport Schwinn Rechargeable Portable ...
Logitech Harmony One Advanced Universal Remote with Color Touch Screen Logo
127 people viewed this question
Top Logitech Televison & Video Experts
Greg Ulan
Jerry Umali
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
