Question about LG Crystal GD900 Cell Phone
When I try to add a city in world clock the phone switches itself off, same if I go to date and time and try to change the time zone
  • 34 Answers
This is a manufacturer defect and you'll need to update your software via firmware update.
Posted on Nov 19, 2009
How to delete international clock
      To see times in other cities, scroll up or down. To remove a city from the list, tap Edit, and then tap the red circle with the white horizontal line in it to the left of the city you want to drop. Then tap Delete. You can also rearrange the order of the cities displaying the time.
      How to Use the World Clock on Your iPhone - For Dummies
      www.dummies.com/.../how-to-use-the-world-clock-on-your-iphone0.html
    Feedback
    How to use the World Clock Android app - Time and Date
    www.timeanddate.com > Apps > Android Apps
    Time and DateTo find a city/location without adding it to your Favorites: Tap on the "Cities" tab located at the top of the screen. Scroll down to the city of your choice and tap on the city row to see details about it.
    How to remove or turn off world clock? ' Verizon Wireless Community
    https://community.verizonwireless.com/thread/807403
Feb 09, 2016 | Cell Phones
How can i change the world clock.
About The World Clock - Time and Date
www.timeanddate.com > Time Zones > World Clock
Time and DateMark DST: Choose whether to display DST information for cities observing Daylight Saving Time. You can choose to mark cities currently observing DST with an asterisk (*) or with text (DST). Columns: Change the number of columns on the World Clockpage. You can have up to 8 columns.
How to Use the World Clock-Time Zones App - Time and Date
www.timeanddate.com > Apps > iOS apps
Time and Datetimeanddate.com explains how to use our World Clock-Time Zones application on the Apple iPhone.
Dec 28, 2015 | Cell Phones
How do i change the time and date on my Sansung GT-B5722, it is set on the 01 01 2009?
you may wanna try this:
Create and view world clocks Learn to view the time in another region and set world clocks to appear on your display.
Create a world clock
1. In Menu mode, select World clock.
2. Select Add.
3. Scroll left or right to a time zone.
4. To set daylight saving time, select 1.htm92.gif.
5. Select Add to create your world clock.
6. To add more world clocks, repeat steps 2-5 above.
Add a world clock to your display
With the dual clock widget, you can view clocks with two different time zones on your display.
After you have created world clocks,
2. Select the world clock you want to add and select More → Set as 2nd clock.
May 02, 2011 | Samsung B5722 Cell Phone
I can't change the time back on my motorola razr i tried shutting it off for 30 seconds that didn't work, i tried going to settings and initial setup and there is no place that says date and time and there...
go to TOOLS, then WORLD CLOCK, then find the time zone you are in, then select SET DST at the bottom of the screen and that will set the time for you. hope this helped :)
Nov 07, 2010 | Motorola Mobility RAZR V3m Cellular Phone
Clock keeps working plus 1 hour Lexibook RP200GB set the time but every night it resets to 1 hour ahead can't find user manual please help
Hope this helps I had same irratating problem
1. The RP200 is designed to automatically synchronize its calendar clock once it is brought within a range of 1500km of the Frankfurt DCF77 radio signal. When the RP200 is brought within this range, its auto-control mechanism will override all manual settings.
2. The clock automatically starts scanning the RF 433MHz signal after new batteries are inserted in the main unit. When receiving the RF 433MHz radio signal, the Radio Tower symbol starts to blink. A complete reception generally takes about 10 minutes, depending on the strength of the radio signal.
3. When the reception is complete, the Radio Tower symbol will stop blinking and remain solid
4. For an optimal reception, place the clock away from metal objects and electrical appliances (i.e. television, computer, monitor, etc) to minimize interference.
Notes:
• The unit will receive the RCC signals every day at 2am.
• The RCC signal can also be triggered by holding the key for 2
seconds in time mode.
• When the unit is searching or receiving the RCC signal (which lasts
about 5 minutes), none of the keys is working except the key.
• Press and hold the key for 2 seconds if you wish to stop to the
RCC signal search.
If the RP200 is brought outside the range of the Frankfurt DCF77 radio signal or if the signal is interfered, please set the time and date manually according to the instructions below. If the unit is located within the radio-controlled range, you may want to customize some of the clock settings.
Note: When no key is pressed for more than one minute, the unit returns to time mode (time, date and temperature display
World Time Clock
This function allows you to adjust the clock to a time zone. It is
particularly useful for travelers. Set the clock to the city you are located in, or to a city in the same time zone.
1. In time mode, press [MODE] twice to select the world time clock.
2. Press the key to select the city in which you are located.
3. Press to adjust the summer saving time function.
4. Press and hold [SET] to set the world time as the local time. When the local time is the same as the world time, the icon flashes.
May 15, 2010 | Toys
How to change time on garmin nuvi 200
go to the Travel Kit, Select World Clock, Select (or press on the clock), Select the city currently residing in the Time Zone window, Scroll up or down and select the city that is in the time zone you wish to select, press OK, Select Back, Select Back, Select Back, verify that the time (Hour) is correct.you can set the timezone here as well as the current time. Make sure you are acquiring the satellite as well as sometimes the time is automatic depending on the firmware on your unit.
Aug 30, 2009 | Garmin nuvi 200W GPS Receiver
I have an OREGON SCIENTIFIC MODEL 323A travel alarm clock. I want to set it to East Coast time. It's presently on West Coast time and nothing I do to the front panel buttons will allow me to change the...
The following is from a manual I found online. Step 1. and 2. worked to solve the same problem you're having for my sister-in-law. Hope it works for you too--good luck! JLC
SETTING THE CLOCK AND CALENDAR
CLOCK MANUALLY
1. Press and hold [MODE] button for 2 seconds.
2. Using the [UP]/[DOWN] button to scroll through the 4 U.S.
time-zones (Pacific, Mountain, Central or Eastern) or non-U.S.
cities. Press [MODE] to confirm.
3. If non-U.S. city is selected, the world time city will be flashing.
Use [UP]/[DOWN] to select the city (for city names abbreviation,
please refer to the section “Selecting the World Time”). Press
[MODE] to confirm.
4. Repeat the same procedures to set the hours, minutes, year, month,
day, language of day-of-week and hourly-chime on/off by using
[UP]/[DOWN] button.
Jul 11, 2009 | Oregon Scientific RM323A Travel Alarm...
Unable to set the time correctly
Try to set it again:
1/Verify the date and local time (this should be
the date and time according to the local date and
time of country/area you are in). Because the
time shows is Universal Time (UTC), you will
need to enter a time offset to display the correct
local time for your area.
2/Move the field highlight to the OFFSET field
and press Enter
3/With the arrows (←→), go to the figure which
represents the hours then with the up & down
arrows (↑↓), select the time offset for your
longitude and press .
4/Move the field highlight to the HOURS field
and change to 24 if that is not already the case.
5. Press QUIT , to return to the MENU Page, then select
Navigation Setup “NAV SETUP” with the Up & Down arrows (↑↓)
then press ENTER
Hope that helps.......
Jul 02, 2008 | GPS
World Cloack
As far as I can ascertain, you need to set your clock time to GMT, and then use the world clock feature to look up times in various cities. It would only be of any use if you were travelling.
May 18, 2008 | LG Prada KE850 Cellular Phone
Regarding clock
Turn Off automatic time and date, then menu>clock>second tab in the menu>my current city
Mar 24, 2008 | Nokia N72 Cellular Phone
LG Crystal GD900 Cell Phone Logo
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
