Question about Kingston Technologies 512MB DataTraveler I (DTI512KR) Hard Drive
Hi.... i hav 2gb kingston n it does not b format
Hi i hav 2gb kingston n it does not b format plz do help me
    President:
  • 281 Answers
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW.EXE
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Posted on Jan 28, 2010
Kingston Data Traveler 2.0 64 GB USB - file system corrupted - need to work on windows XP- Upon formatting the pen drive It shows that it has become a raw drive - wat is the file format for the USB to work...
Theoretically, you can't format a more than 32 GB drive with FAT/FAT32 file system. In your case you have to choose the NTFS file system to format your 64 GB USB flash drive. However, if you really need to format it with FAT32, you got to use the command line or a third party tool. Hope this is going to help you.
Apr 06, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I cant format my 2GB Kingston flash disk, when I plug it to the computer it is reading removable disk and when i try to format it it will start formating but failing to be formatted successfully.
that problem is usually caused by a failure of the hardware to properly recognize the USB drive, clean the contacts with WD-40 or with a contact cleaner. Try a different USB port.
Hope this helps
Dec 27, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Same Problem!!! the Error is |X| Cannot Copy the file: Cannot Fine the Specified file Make Sure you specify the correct path and the filename my USB devise having problem SKYMEDI USB drive 2GB and it cant...
Hi
try to format your kingston with
Following tool.(HP USB Disk Storage Format Tool )
from the site
http://www.softpedia.com/progDownload/HP-USB-Disk-Storage-Format-Tool-Download-123786.html
This tool allows you to format your pendrive either
in fat32 or NTFS
IN which NTFS is better
and also IT· Allows creation of a FAT32 volume larger than 32 GB.
An alternative is to format it in any linux
Oct 13, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Not able to copy more than 1GB into 2GB Kingston SD card
Hi 1123sun,
Copy your files off the card. Then Format the card and select FAT32 file system. After the format is done try the card again and see if you can copy more files to it.
Kingston Tech Support
Feb 18, 2009 | Kingston 2GB Secure Digital Memory Card
My kinston pen drive reads zero bytes
Hi sirmac,
If formatting doesn't clear up the problem then it just needs to be replaced. Contact Kingston Tech Support for a replacement.
Dec 14, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Pendrive error
just open and see which files are there and then delete unused files and then format it i m sure it will work
Dec 02, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Kingston DataTraveler2GB
Hi, I couldn't get any software utility or firmware updater/repair from the Kingston site, however, I have tried the HP Drive Key Boot Utility and it works even for Kingston and JetFlash. The bad side is it completely erases the contents of the USB drive. Should you want to venture and try it, it is available for download at http://h18000.www1.hp.com/support/files/serveroptions/us/download/23839.html file name is cp006049.exe Hope this be of some help/idea. Post back how things are or should you need further information. Good luck and kind regards.
Aug 31, 2007 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Computers & Internet Logo
172 people viewed this question
Top Kingston Computers & Internet Experts
Cleverer2
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
