Question about Samsung SGH-i900 Omnia Unlocked Cellular Phone
Can samsung lcd tv a550 parts work with a b550? iv'e been trying to find parts for my LN37b550k1ZXA and i have no luck is this a part i can buy from a brandsmart or bestbuy ??? its main unit board that i need someone please help me my tv has been out of action for 2months now !!!
Samsung no power lcd tv
Congratulations !! Now finally you can buy new TV for you. Same case happened with my ViewSonic LCD Monitor. Its due to damaged PCB behind LCD panel. Check if you are lucky by searching PCB for your TV.
Oct 04, 2014 | Samsung Ln46a550 46-inch 1080p Lcd Hdtv
Samsung s23b550 monitor doesn't work with right resolution
Your monitor does not support the resolution capabilities of your superior Mac.
Mar 19, 2014 | Samsung B550 Series S23B550V ToC 23" 2ms...
Sleep mode
A Google search indicates this is a common problem.. Some of the comments in this video may help. If it is still under warranty, you might be best to get a RMA. Good Luck.
How to fix Samsung monitor that is stuck in sleep standby mode Temporarily
Oct 26, 2017 | Samsung BX2450 LCD Monitor
Turn off and on codes
samsung usually doesnt have a code. hide a switched power strip or something behind the tv or unhook it somehow when you're away. you can lock cableboxes and sat boxes sometimes, but i think that panasonic code is a rare thing
Jun 17, 2010 | Samsung UN55B8000 55 in. LCD HDTV
Problem for choosing lcd tv
When you buy a samsung, you buy a LED TV with a panel manufactured
by the company "S - LCD" which belongs to 50/50 % sony and samsung.
The S - LCD company is fully driven under samsung engineering.
Today, sony seems to buy their panels from "sharp corp" and trying to
seperate from samsung due to the cold war (high competition ) between
them
Just go for the samsung UN32C6500 32" 1080p LED HDTV.
Theres no better picture quality you can buy for 32".
Good luck....
Jun 14, 2010 | LG 42LC2D 42 in. LCD HDTV
TV turns on and off...
My repair experience on same symptom of the Samsung A550 series, it is the main board fails, the part # you can see a sticker on the board, the format is like BN99-99999C.
May 15, 2010 | Samsung LN-S4692D 46 in. LCD HDTV
Where can i buy main unit board for my b550 set? help!
Sounds right to me, try calling 1-800-samsung to find nearest service/parts center.
Nov 15, 2009 | Samsung LN37B530 37 in. LCD TV
Black and white grainy output to new samsung lcd
Your DVD player is using a PAL or NTSC variant which is not supported by your display. Somewhere hidden in the depths of the options in the DVD player should be an option to change the composite output type.
Jul 07, 2009 | Insignia 32" 720p Flat-Panel LCD HDTV
I have Samsung A550 46 LCD HDTV, and Anteina IN Broken
Yes it can be fixed if the tuner board was not damaged. Get an RF modulator, you can pick them up at walmart, and use your RCA inputs in the back. All you do is input your main tv cable into the RF mod cable in, then connect to the out of it with your RCA cables and then into the RCA connect in, into the back of your tv. Or, like you said, you can input your main tv cable into your vcr/dvd then come out of that with the RCA cables, and again into the RCA cable in on your tv. This way you have to syncronize your channels after you do this to get the picture. You know, vcr on channel 3 while your tv is set to input 1 or whatever needs to be done.
Jul 07, 2009 | Samsung LN46A550 LCD TV
Samsung SGH-i900 Omnia Unlocked Cellular Phone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
