Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
I have a 19.5 b/s turbo cool and the engine gets hard to turn by hand at T.D.C. with spark plugs out . I also need imfo. on how the gov. works inide the engine.
    Sniper:
  • 197 Answers
Set the valves at .004 when piston is 1/4 inch down from TDC, This is to help with cranking when plugs are in but not sure why its hard to turn past TDC when plugs are out,could be from coil or coils conntacting flywheel magnets.
Posted on Nov 16, 2009
I put the wrong type of spark plugs into a eclipse and the wrong type of gas into the car and rebbed it up it shut down and does not crank anymore. It's a 1998 turbo misutibsi eclipse
What was the difference in the spark plug, long reach, or hotter?
What was the 'wrong gas', not nitro-methane or methanol I hope?
You can try removing the spark plugs and try turning the engine by hand. If manual, put car in second gear and push backwards. If the engine turns, check for compression. If automatic, put a socket on the crankshaft pulley and turn it.
Jul 19, 2016 | Cars & Trucks
Have used 4g63turbo evo2 . Aftermarket bov etc . 800kms through bottom end run-in process . All is well but tonight acceleration is straining .airflow/turbo related? Also thinking exhaust.
first with engine cooled down removed spark plugs then turn engine in direction of running rotation by hand from the crank to see if its mechanical related like eg bearing seized. With the spark plugs removed engine must turn easily by hand if not something is holding
May 28, 2016 | Cars & Trucks
Spark plug gap 96 gov safari ACDelco platinum 41-942
Spark Plug Gap - AutoZone
www.autozone.com/.../specificationsMain.jsp?...Spark+Plug+G...
AutoZone2004 Mercury Grand Marquis 4.6L SFI 8cyl ' Specifications ' Spark Plug Gap.
AstroSafari.com • Spark plug gap size?
www.astrosafari.com/viewtopic.php?f=43&t=81409
Jul 27, 2015 - You're doing a '96? I think EARLIER 2nd Gen 4.3's used a .045" gap ; I believe it changed in 2000 or 2001 but don't quote me on that. All i'm ...Missing: gov
AstroSafariVans.com • View topic - spark plug gap question
astrosafarivans.org > ... > ENGINES GENERAL/PERFORMANCE
Nov 28, 2012 - 15 posts - ‎4 authors
My question is do I gap the spark plugs per 89 4.3 specs or do I use the 95 .... The vortec heads for a V8 chevy are 1996 and up however there ...Missing: gov
What is the proper sparkplug gap? - CarGurus
www.cargurus.com > Questions > GMC > Jimmy
CarGurusMar 16, 2013 - My Haynes manual and various places I've seen online say the gap is .045 inches ... spark plug gap for 1992 4.3 160 HP? ... Used GMC Safari".Missing: gov
[PDF]2000 GMC Safari Owners Manual - GM Extended Warranty
www.vadengmpp.com/owners-manual/gmc/2000-GMC-Safari.pdf
Jan 27, 2016 | Cars & Trucks
1989 ford f 150 i been driving and the engine stop fuel have don't start
could be fuel pump,check for fuel see if fuel pump supplying fuel and you are getting spark.make sure ignition timing is correct and the idle speed setting correct check the under hood emissions information label.also check engine make sure engine not over heating check cooling fan clutch see if cooling fan clutch is okay by turning it by hand if engine is hot cooling fan should have resistance if engine is hot, if cooling fan feel loose no resistance the fan clutch is bad.
Feb 06, 2012 | Ford F-150 Cars & Trucks
Took 2004 9-3 to the Dealer because car was vibrating and misfiring. Dealer replaced spark plugs. 01/19. Took 400 mile road trip 2 weeks later. Car was vibrating, smoking and sparks were coming out of...
I have know by experience that if you cross plug wires you can get an engine extremely hot ive seen it also seen it hot enough to get the exhaust manifolds glowing red if they havent put their hands in it and corrected the problem i would check the firing order to make sure it was correct and that they didnt cross the plug wires.
Feb 09, 2011 | 2004 Saab 9-3
Stopped for gas on my way home from work. Tried to start car but it would not turn over. Sounded like the battery was dead but it is less than 2 months old and was tested the day before and was good. Left...
Please check to be sure that connections at your battery are tight and clean. Try to turn them by hand. if you can, they're not tight enough. If this is not the case, I would suspect a faulty starter. When it will not turn over, do your headlamps, and the rest of the electrical accessiries work? If so, try tapping the starter with a hammer, LIGHTLY. This will usually make it work a few more times. Good luck!
Dec 31, 2010 | Saturn Ion Cars & Trucks
I blew the turbo on my 2005 pt cruiser limited ed. I replaced the entire turbo,and added new sparks...(only has 52k miles) Since then my car does not get over 65mph without feeling like its stalling...
What kind of spark plugs did you use??? Here is a list of plugs that you can use on your Turbo engine.
Champion
* Copper - stock # 440 - RE14MCC5 (OEM)
* Copper - stock # 470 - RE14MCC5 (supercedes/replaces # 440, but some catalogs same part #)
* Copper - RE16MC (supercedes/replaces RE14MCC5 and new Chrysler recommended gap is .040)
NGK
* Copper - LZTR4A-11 (supercedes/replaces RE14MCC5 and new * Chrysler recommended gap is .040)
* Copper - stock # 4306 - LZTR5A-13 (one range colder)
If you use the platinum spark plugs used on the Non-turbo engine, they will start to glow and cause misfires and can cause engine damage to saver detonations throughout the RPM cycle.
As for the over heating, you could have a blown head gasket from a severer detonation if you notice coolant and oil mixing in your engine and coolant tank. The less cause for over heating wold be a bad thermostat or a faulty radiator cooling fan, cooling fan relay or cooling fuse which is located in the engine compartment fuse box by the battery.
Good luck and thank you for using Fixya.
Mar 17, 2010 | 2005 Chrysler PT Cruiser
Spark plug wire diagram 94 plymouth laser
I am not sure whether you have the 1.8L, 2.0L, or 2.0L Turbo; however I have included all below.
You Posted your Car Question under a different (non car) (Home| Lite On | Spark Plug Lite Green LED| Problem) heading.
I work on pretty much only vehicles, and found your problem today.
For the 1.8L SOHC
Firing Order:
1-3-4-2
Cylinders:
(back of engine)
4---3---2---1
(front of engine)
Distributor:
...(back)
(+)..1
2..........3
......4..(+)-screw
...(front)
For the 2.0L DOHC AND 2.0L Turbo:
Firing Order:
1-3-2-4
Cylinders:
(back of engine)
1----2-----3-----4
(front of engine)
Ignition Coil Connections:
......(back)
........3
........2
........1
........4
......(front)
Let me know if this helped or if you have additional information or questions. Feel Free to contact me at FixYa.com!
Feb 08, 2010 | Lite On Spark Plug Lite Green LED
Where are the spark plugs
Instructions Things You'll Need:
  • Spark plug socket
  • Socket wrench with extender
  • Anti-seize compound
  • New spark plug
  • Tension tester tool
  1. Step 1 Raise the hood and locate the battery. Disconnect the negative battery cable. Allow the engine to cool before attempting this process. Depending on the climate, it may take 30 minutes or more to cool the engine.
  2. Step 2 Find the spark plug cables on the Kia Spectra engine of either a four- or six-cylinder variety. The number of cylinders indicates the number of spark plug cables on the engine.
  3. Step 3 Turn the cables by the boot, or cover, that connects to the engine or directly to the spark plug. Disconnect one cable and complete the replacement process before removing the other cables to ensure the cables don't cross. Pull back on the cable to reveal the spark plug.
  4. Step 4 Remove the spark plug from the cylinder well with the socket. The extender may not be needed for 4-cylinder engines. Turn the socket in a counter-clockwise motion to unscrew the plug and remove it from the cylinder block.
  5. Step 5 Use the applicator supplied with the anti-seize to spread the compound over the threads of the new spark plug. This compound allows for easy removal when you need to check or replace the spark plugs.
  6. Step 6 Screw the spark plug into the cylinder well by hand. The spark plug needs to be tight in the well but may have to be loosened after the tension test finishes.
  7. Step 7 Test the torque of the spark plug with the tension tester tool. Normally the spark plugs on a Kia Spectra need 18 to 22 ft-lbs torque. Check the Spectra model's owner's manual or the manufacturer's package because some premium or performance spark plugs use different torques.
  8. Step 8 Reconnect the spark plug wire and turn it to lock it in place. Continue replacing the rest of the spark plugs. Reconnect the battery cable after you replace all the spark plugs.
Oct 27, 2009 | 2002 Kia Spectra
88 suburu 1.8 liter getting gas but wont start , just changed plugs and wires, could it be the turbo
the turbo has nothing to do with starting
check for spark with a timing light
Aug 28, 2009 | 1988 Subaru GL-10
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
67 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
