Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Top drawer stopped first with F1 and would not turn off. Now 2nd drawer is the same ,Had to turn off power to diswaher .
  • Fisher and P... Master
  • 3,247 Answers
F1 means the flood switch is activated. This is located at the base of the housing under the bottom drawer. You will have to find if there is water collected at the base by extending out the bottom drawer. Make sure the power is turned off.
Use towels and hair dryer to dry base out. The terminals of the switch will have to dry out as well. Quicker way would be to get the bottom drawer out and fix it back after the drying operation.
Next you will have to find the source of the water collection. Cracked hoses, broken actuator link arm (that holds up the wires and hoses to allow the drawer to move in and out without getting entangled) or foaming inside the drawer due to use of incorrect detergent.
Good luck
Posted on Nov 20, 2009
F1 error on Fisher and Paykel Dish Drawer
Sorry did not see your problem report earlier. If you have checked the sensor under the bottom drawer and it is dry, then F1 is caused by top drawer power filter fault. This means the bottom drawer controller is giving the F1 error but the top drawer controller has no power. Can you confirm this.
Apr 08, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Have an f1 error that comes up , says it is a flood switch doesn t seem to be any water in the area around the dishwasher. Any ideas?
The flood switch is at the base of the dishwasher housing under the bottom drawer.
Do you have the F1 fault displayed in both drawers? If so, or if you have single drawer, then turn power off and take the bottom drawer out. Dry the base with towels and use hair dryer on the small circuit board at the base.
Put everything back and turn power back on. The source of leak could be lid seal, kink in hose or ruptured hose.
If you have 2 drawer unit and the F1 error is in top drawer only then the bottom drawer has lost power. Could be due to thermal fuse blown on heater plate.
Hope this helps find the problem.
Dec 22, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
We have a 23" Fisher&Paykel dishwasher and got
The F1 error coming on top drawer when operating bottom drawer is due to the thermal fuse blowing up on the bottom drawer and shutting controller power.
The thermal fuse could have blown either as a normal component failure or heater over heated due to thermostat failure. In any case this can be repaired by replacing the whole heater assembly as all the parts are integrated.
This is at the underside of the drawer and will need a technician to replace unless you are very familiar with repairing electronic dishwashers. The part look like this.
The way you have described the onset of the F1 error is not due to flood switch. You can confirm that the lights on the bottom drawer are out even though the top drawer is showing F1 and beeping.
If problem was flood switch then both drawers would show F1.
Nov 25, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Need a service person. Machine reads F1 and must unplug to stop it from running
Is this happening with both drawers or just one.
You have water leaking into the base of the dishwasher under the drawer.
Most likely the drawer seal is leaking.
The flood switch is located at the base of the dishwasher and this needs to be dried.
Turn power off and take the bottom drawer out. Dry base with towels and hair dryer. Turn power back on without putting the drawer back.
Run top drawer to see if any water is leaking.
Water leaks can be due to faulty seal or drain hoses cracked.
Hope you are able to fix it.
Sep 07, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
I have F1 flashing on my dish drawer....turn it off a couple of months ago because of the same issue and have not used it since....turned it back on and used the bottom drawer...all OK...went to use the...
Please confirm if the F1 on top drawer shows up immediately you press the Start button or part through a wash cycle? What happens when you turn off the power and back on.
Sep 02, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 error
The heater unit in the bottom drawer is blown. This causes power to shut off to the controller. The effect of this is the F1 error on the top drawer.
If you get the heater on bottom drawer fixed, that should take care of the F1 error in the top drawer.
Jul 11, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
How to shut off dishwasher? F1 is flashing on control panel.
Hi now F1 mean that your machine has triggered the flood alarm. there are two reasons this happens-- 1st-- there is a leak on one or both of your drawers. they leak because you might have a hole in one of the hoses or your lid is not shutting properly etc. the 2nd reason is that some water or soap suds escaped from the overflow. now i would like you to turn the machine off at the wall and leave it off for a couple of days to dry it out. then turn it on and use the lower drawer for one cycle. if it does not go F1 then try the top drawer for one cycle and see how it goes. if it continues to flash F1 then reply back for further help. good luck.
Jun 03, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Son put normal dish washing liquid in top draw!
ok, the machine flooded and the water has leaked into the bottom of the machine, 1st turn off the machine at the power point. 2nd- open the top drawer and remove the suds from it. 3rd. open the bottom drawer and look under it to the bottom of the cabinet . that is where the water will be. use a torch if you have to. now you need to dry the water up. you can do this with a hair dryer or a fan heater. the reason the machine is flashing F1 is because the water has triggered the flood switch and you need to dry up that water. please reply 4 more help.once dryed F1 will disappear. please make sure all the suds are removed from the top drawer. good luck
May 14, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Top drawer not working
sometimes if the heater is faulty only one drawer will work and the other drawer will flash f1
Nov 02, 2007 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
141 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
