Question about Nikon Coolpix S4 Digital Camera
Nikon Coolpix S4. Broken plastic collar with hinged lens cover, part no LC-CP16. Replacement required. Mr RA Hayes
SOURCE: black monitor Nikon Coolpix S4 Digital
Give the lense side of the camara a few moderate slaps while moving camara from bright to dark obgects back and forth. the shutter gets stuck and doesn't respond to changing light. that's why outdoor pictures are usually too bright and indoor pictures are black.
good luck.
Posted on Aug 19, 2008
  • 291 Answers
SOURCE: Just received a mint condition Nikon Coolpix S4
Without some detailed information on how the unit processes video vs. still images, it won't be possible to say for sure, BUT....
The video resolution is processed at a much lower megapixel setting than still pictures. It may be that the defect in the sensor that is causing the lines is on a section of the sensor that is either not used in video mode, or that the software is processing out the defect when it doesn't need all the pixels to give you an image. I think the first is more likely. In video mode, the camera has to run at a lower resolution so that the electronics can store information fast enough to give you video, so it uses a lower resolution. Since it's using the same sensor, it has to either ignore some of the pixels or just not sample them.
If it is the sensor (this is most likely but can't be sure without testing it), then the only way to correct would be a new sensor. It could also be a bad wiring connection, but either way you'd need to get inside to fix. That would be expensive.
I think you should try to use a lower resolution setting and see if maybe that will eliminate the pixels that aren't working. You won't be able to get the highest resolution from the camera, but megapixels are overrated. If you can run it at 3 megapixels or more, you'll be able to do just about anything with it.
Posted on Aug 31, 2009
  • 10865 Answers
SOURCE: Battery problem
hello. Remove the battery and clean the battery contact spots with the eraser end of a common pencil. Also clean the ends of the batteries. Then reinstall batteries and test it. Regards, Joe
Posted on Feb 03, 2010
  • 10865 Answers
SOURCE: Nikon Coolpix s4-monitor working but no image
hello. you may be involved in a recall. please read this http://www.nikonusa.com/Service-And-Support/Service-Advisories/COOLPIX-Service-Advisory.page
please rate my answer as very helpful thank you. joe
Posted on Mar 01, 2010
  • 126 Answers
SOURCE: white lines in photos
CCD unit is not working properly, take it in for repair.
Posted on Mar 26, 2010
How do I correct lens cover error?
nikon coolpix s52 lens cover error Questions & Answers ...
www.fixya.com > Forum > Tags
Nikon COOLPIX S51 Digital Camera When I turn the camera on the lens cover willnot slide open. The screen displays a message that say "Lens Cover Error!
Nikon COOLPIX S52 Digital Camera - Fixya
www.fixya.com/support/p926575-nikon_coolpix_s52_digital_camera
Recent Nikon COOLPIX S52 Digital Camera questions, problems & answers. Free expert DIY tips, support, ... How do I correct lens cover error? Nikon COOLPIX.
Fixing a nikon S52 camera lens cover?? PLEASE HELP!!!? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Apr 4, 2011 - ... broke my lens cover on my nikon coolpix s52. when i try to turn it on it says Lens cover error and has a ... Can i fix it myself? What would be the approximate cost of repairs? ... How to fix Nikon Coolpix L6 digital camera lens?
Lens Error message ' Nikon Knowledgebase
Aug 31, 2015 | Nikon COOLPIX S52 Digital Camera
I have a nikkon coolpix s4 with a broken lens inside. I just downloaded the repair guide, but its too complicated. Can you do it?
Sorry, no. FixYa is an online information source only.
With all due respect, it's a bit like opening a repair book and asking it to get on with fixing your camera whilst you have a cup of tea ;-)
If you cannot fix this issue yourself using the repair guide which many FixYa Experts usually refer you to then your only remaining option is a professional repair, but it would be far cheaper to buy another camera.
Oct 11, 2010 | Nikon Coolpix S4 Digital Camera
When I turn it on, I get a "LENS ERROR" MESSAGE
When one gets a lens error it usually means there is a physical lockup of the gears inside. It may need to be repaired by Nikon.com, if repair is economical to the owner of the camera.
http://www.nikonusa.com/service-and-support/nikon-service-information.page
Aug 29, 2010 | Nikon Coolpix S4 Digital Camera
Display monitor on my Nikon coolpix s4 is not
I am having this problem also. I have reviewed the manual from back to front and cannot find the answer to my problem.
Jul 15, 2010 | Nikon Coolpix S4 Digital Camera
The latch on the battery door of my Nikon Coolpix
You can get that replaced or repaired thru the list of Nikon Authorized service centers near you area. Just click the link::
http://www.nikonusa.com/Service-And-Support/Nikon-Authorized-Repair-List.page
Hope this helps.
Dec 29, 2009 | Nikon Coolpix L11 Digital Camera
Lens error
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 03, 2009 | Nikon Coolpix S4 Digital Camera
MRCTB Parts
High limit switch is bad. Where can I get a replacement?
Sep 23, 2008 | Mr. Coffee MRCTB Coffee Maker
My Nikon Coolpix S5 has a broken lens; it son't fully close/ open. The message displayed on the screen says "Lens cover error". Is it something that can be repaired? How much would it cost to fix...
Hi , The lens cover error is because the stepper motor in the camera is unable to open the lens cover. I have a solution posted in doc "nikon s5 s6 lens cover error repair.doc"  uploaded on site http://www.esnips.com/web/papputatiyasStuff    It will be helpfull for you. You have written that your lense is broken. In that case you can follow the procedure given in my doc to open the camera. You can replace the camera lens if broken.
Happy debugging Mukesh
Jul 01, 2008 | Nikon Coolpix S3 Digital Camera
I have a nikon Coolpix S4 camera tha will not show what the swivel lens is focus on.
I can't get an image on my coolpix L15 monitor screen, it just shows a bright light, it will snap pictures and show a flash , but no image
May 30, 2008 | Nikon Cameras
Lens Error
Could be fatal - looks like it need to go to hospital- Nikon support Looks like CoolPix dont like that sort of Cool huh
Mar 08, 2007 | Nikon Coolpix S4 Digital Camera
Nikon Coolpix S4 Digital Camera Logo
59 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
