Question about Nikon Coolpix 3200 Digital Camera
Lens error When powering camera on, the view screen indicates a 'lens error'.
  • soozie82 Feb 25, 2008
    yup, mine does the same, the lens comes out, screen says 'lens error' and the lens goes back in!! second time ive had a lens related problem :-(
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Feb 22, 2010
Dropped camera while it was turned on - now "lens error" appears on screen & can't turn off camera or view pictures
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Dec 25, 2010 | Nikon COOLPIX L20 Digital Camera
Camera shuts off even with new batteries
"E18" indicates an error that involves the lens unit or lens cover in your camera .This error appears where the lens is prevented from properly extending or retracting .The error may also be displayed if the lens camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera.Hold the camera so that your fingers do not touch the lens unit when you are shooting. Make sure the camera is off before the camera is placed back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.If you cannot clear the error code by turning the camera off and then on again, or if the error code is displayed frequently, a camera malfunction may have occurred and might require service from canon.Or else try pressing the power button on and held it down while extending the zoom lens. The lens will extend out and the camera will be freed from the error.
Thank you !!
Jul 12, 2010 | Canon PowerShot A95 Digital Camera
Camera will not switch on/off properly, and "E18" appears on the screen
"E18"indicates an error that involves the lens unit or lens cover in your camera .This error appears where the lens is prevented from properly extending or retracting .The error may also be displayed if the lens camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera.Hold the camera so that your fingers do not touch the lens unit when you are shooting. Make sure the camera is off before the camera is placed back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.If you cannot clear the error code by turning the camera off and then on again, or if the error code is displayed frequently, a camera malfunction may have occurred and might require service from canon.Or else try pressing the power button on and held it down while extending the zoom lens. The lens will extend out and the camera will be freed from the error.
Thank you !!
Jul 06, 2010 | Canon PowerShot A95 Digital Camera
Lens error
This is probably THE most common failure among digital cameras.
Feb 15, 2010 | Nikon Coolpix S210 Digital Camera
When i turn my camera on, its a blank screen with
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Oct 03, 2009 | Canon PowerShot A75 Digital Camera
When i turn on the camera e18 comes on the screen and nothing else. I can view photos, but the zoom won't go back in
Jul 30, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
The lens will not retract. When in picture mode er18 appears on the otherwise blank screen. It will switch to allow me to view the pictures on the card
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Oct 10, 2008 | Cameras
Bonnie
I was getting the Lens Error message on my A730, even though my lens seemed to be working fine. I'd had the camera in my pocket, and apparently it tried to open but jammed. But it seemed to be OK except for the cursed Lens Error message when I'd power it on. The way I found to fix it is press and hold the "func/OK" button on the back, then turn the camera on. Now it's working again. Note that this may not work for you if your lens is actually screwed up. Mine wasn't.
Dec 12, 2007 | Cameras
Error 18
The "E18" error code indicates an error that involves the lens unit or lens cover. This error may appear where the lens is prevented from properly extending or retracting such as, for example, when pressure is applied to the lens or the area surrounding the lens while handling the camera. The error may also be displayed if the lens unit/camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera. Solution Check the following when you operate the camera to avoid applying pressure to the lens and surrounding area: - Hold the camera so that your fingers do not touch the lens unit when you are shooting. - Make sure the camera is off before you put it back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.
Aug 31, 2005 | Canon PowerShot SD500 / IXUS 700 Digital...
Nikon Coolpix 3200 Digital Camera Logo
147 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
