Question about Acer Aspire™ T180 PC Desktop
Will not boot to operating system or the bios. no messages and no beeps
  • 3 Answers
You probably have a bad power supply or one of your components is bad. I don't have enough info to point to anything specific, but here is some ideas you can try.
1) unplug all components internally but the power supply and check for bios beeps. Not the front panel wires though.
2) swap power supply or check with voltmeter for +5vdc, +12vdc, and -12vdc.
3) check for operation of fans attached to motherboard.
4) most likely suspects are motherboard, processor, or power supply.
Posted on Nov 16, 2009
My acer wnt start up or boot is bios missing dll blue screen is all i ger
If you have a boot menu the problem is likely not the Bios. No beep codes? Some PC's will give hardware error codes in the form of long and short beeps through the MB speaker. Otherwise a bad boot sector on the hard drive would likely give you an error message, like ; NTLDR is missing
Press Ctrl+Alt+Del to restart
Check the power and ribbon wire connections to the hard drive. If you have recovery disc/'s, doesnt hurt to try! Otherwise its a new operating system, new hard drive, and searching for drivers. Good luck to you!
Aug 13, 2014 | Acer Aspire 7540G Compatible Laptop Power...
Black screen green dots
What was the last thing you did on your computer before this happened?
Did you change any system settings in the BIOS?
Did you add new software? or update any software or drivers?
Did you add any new hardware?
Is your system BIOS infected with a virus?
Because it appears that your PC is hanging up during the Power-On-Self-Test [POST]
Here's what happens; when the power is turned on, the computer BIOS [Basic Input/Output System] runs a POST (Power-On Self-Test). It is a diagnostic testing sequence that the computer runs to determine if the hardware [like the mouse, keyboard, hard drive, etc.] is working properly.
If the necessary hardware is detected and found to be operating properly, the computer begins to boot; If the hardware is not detected or is not operating properly, the BIOS issues an error message.
The error message may be a text on the display screen and/or a series of coded beeps, depending on the nature of the problem.
The series or pattern of beeps may vary...they may be in a number of long or short beeps or a mixture of long and short beeps, or even one long continuous beep, depending on what type of BIOS is installed.
Since POST runs before the computer's video card is activated or the integrated graphic chip on the main board, it may not be possible to progress to the display screen.
So if an error is detected during the POST it will halt the boot process because the hardware is essential for the computer's functions.
How many beeps do you hear during the initial POST?
You may have a burned out video chip/card; or corrupt drivers; or even an IRQ [Interrupt Request] conflict.
Nov 26, 2013 | Acer Computers & Internet
Aspire 5336 2524
Keyboard key might be pressed,......try changing the keyboard.
Nov 10, 2013 | Rebellious Productions Beeping Bios Codes
Operating System Not Found Message
dsflews 1 or 2 HDD ?
made any changes in BIOS ?
if 2 HDDs and you set optimal defaults in BIOS windows can change BOOTDISK. if two it's easy just change back.
http://www.pcmag.com/encyclopedia/term/38515/beep-codes
good reading.
Apr 19, 2013 | Dell Dimension XPS PC Desktop
Operating systems doesn't boot (BIOS beep codes)?
Do you have video going to your monitor? If not the beeps mean you have a bad memory stick in there. If you have video the beeps are the bios telling you that its not set right. More than likely you have it set to run too fast. Go into your bios find where the processor speed is located and choose a lower freq. rate. Its probably set too high for the memory you have.
Jun 22, 2012 | AcerPower F2 PC Desktop
Boot sequence for emachine M6811
As SOON as you press the Power On button, start tapping on the DELete key.
Tap in 2 second intervals.
You may hear beeps. This is a Stuck Key Error Beep. (Or beeps)
Ignore the beeps.
You will now be in the BIOS Setup utility.
The BIOS program is made by Phoenix.
It is Version NSF03.P0
Release date - 07/28/2004
http://www.notebookreview.com/default.asp?newsID=2170#specs
Scroll the page down a little, until you come to the bold heading -
EMachines Desktop Replacement Notebook Specs
Scroll down until you see the sub-heading - Detailed specs
Left-click on - Click here to See appendix for detailed specs
Now look under the bold heading - DMI, and [ BIOS ]
When you are in the BIOS Setup utility, you CANNOT use your mouse
anymore. You have to use your Keyboard.
At the top of the BIOS Setup utility you will see headings;
Main, Advanced, Security, Power, Boot, and Exit.
The BIOS Setup utility automatically opens to the Main screen.
Use the Right Arrow key, and stop on the - Boot - tab
What is listed is a Boot Order.
In the list of the Boot Order are Boot Devices.
What is at the TOP is the first boot device the laptop will boot from.
Should be;
1) CD-ROM Drive
2) Removable Devices
3) Hard Drive
4) Network
Having CD-ROM Drive at the top allows you to install a different Operating System, that the laptop did not have from the factory.
ALSO; Windows DOES NOT like to be written over, with a lesser operating system, or the SAME version of operating system.
Examples;
Trying to install Windows 98SE, on a Windows computer that has Windows XP on it.
Trying to install Windows XP, on a Windows computer that has Windows XP already on it.
Using CD-ROM Drive as the first boot device, will allow you to install what you wish.
[ Doesn't work for installing Windows XP over Windows Vista. There is a special procedure ]
If I haven't answered your question, or you have additional questions, please post in a Comment.
Regards,
joecoolvette
May 04, 2012 | eMachines M6811 Notebook
My laptop will not boot - Operating System Not Found, cannot enter BIOS system - nothing at all. When I try to access the BIOS, the key keeps beeping. It is a Type 2373. Thank You -- IMCND
How are you attempting to enter the setup (BIOS)? Here are the steps:
Press the blue Access IBM button when the message "To interrupt normal startup, press the blue Access IBM button" is displayed to enter the ThinkVantage Productivity Center, then select Start setup utility to open the BIOS Setup Utility.
Feb 18, 2010 | IBM ThinkPad T42 Notebook
My motherboard ringing long
can you tell me after beeping and cheksum error did boot your system or is stoping there?
if is stoping there see on the end of monitor a message lke pres f1 to continue.
presit and see is booting your operating system or not?
if yes all to do is to change your cmos bios onboard batery with new one.
if no then you have problem with your bios , try to flashit with new release of your bios.
Apr 09, 2009 | Biostar U8668 (U8668DV7) Motherboard
Laptop caught up in reboot sequence
Do you have the case speaker connected? If so listen for the bios beep codes. You will have to know which bios you have.
Dec 27, 2008 | Microsoft Windows XP Professional
Acer Aspire™ T180 PC Desktop Logo
155 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
