Question about AT&T 650530003417 Cordless Phone
Load default Delta file message - AT&T 650530003417 Cordless Phone
Problem My handset displays either LOAD DELTA FILE or LOAD DEFAULT DELTA FILE. What should I do?
Solution(s) Tip 1 of 2
If the handset is not responding normally, you may need to reset your telephone system. Complete the following steps to reset the telephone system:
Step 1: Disconnect the power to the telephone base.
Step 2: Disconnect the handset battery.
Step 3: Wait a few minutes and then reconnect the power to the telephone base.
Step 4: Reconnect the handset battery
Step 5: Wait about one minute for the handset to re-establish a link with the telephone base and then test the phone again.
Posted on Mar 06, 2010
  • 3 more comments
  • bufbob Dec 11, 2010
    I followed the instructions to the letter and the handset is now working and useable. Thanks for solving the problem.
    Buffalo Bob Casale
  • earl5 Dec 29, 2010
    What would we ever do without Google - I had no idea where my hard copy instructions were and this sure did the trick. Thanks!!! Earl
  • solheim4115 Mar 01, 2011
    .......and I thought I'd need to buy a new phone. This worked!!! Thank you.
  • bonnie3 Mar 26, 2011
    Wow, this worked, thanks you saved me $100.00
  • cgiambri
    cgiambri Feb 17, 2013
    AWesome. Worked! Problems removing battery with red and black cables attached? Use needle nose pliers! Then follow steps above. Worked. Follow steps above now. ttery and red and black cables as one unit. Follow above. Worked!
    New Friend:
All you have to do is disconnect the battery and then reconnect it. Phone will display "connecting" and be perfectly fine.
Posted on Jan 28, 2013
My Staples Tech found this above. When I followed the above steps, phone handset worked like a charm!
Posted on Feb 18, 2012
3 Suggested Answers
SOURCE:
SOURCE: What do I do to clear the LOAD DEFAULT DELTA FILE
I disconnected the battery, waited a few seconds, reconnected the battery and set it on the charger. Working great!
Posted on Dec 22, 2009
  • 1196 Answers
SOURCE: AT&T cordless phone #cl81219 message
Try reset that particular cordless phone, Turn off the phone, remove the AC adapter, press and hold the page/call button that is on the phone and plug back your Ac adapter, that s
hould fix the problem.
Posted on Aug 13, 2011
My at&t mobile phone keeps flashing LOAD DEFAULT DELTA FILE. How to I get it back to normal so I can answer the phone and make calls?
You may need to do a factory reset to correct this problem. I would call your cell phones service provider first and see if they know a work around.
Dec 28, 2016 | AT&T Cell Phones
Magicjack comfaq
this is not a computer problem, repost in another thread
Feb 14, 2014 | Computers & Internet
Help me to remove Delta search
You need to remove it from your browser too. See Remove Delta Search Below.
I would also do a Malwarebytes scan in Windows Safe Mode
1st Update Malwarebytes Anti-Malware or reinstall it from here
Malwarebytes Thank you for download Malwarebytes Anti Malware
Watch How to download, install and use MalwareBytes 2.0
at
http://www.youtube.com/watch?v=-KwTmIQTJes
How to Enter Windows Safe Mode: Click Start then All Programs then Accessories select Run type msconfig and hit enter.
Select the Boot tab, select Safe boot and Minimal then Apply and OK.
Restart the computer and you'll enter safe mode.The screen will look odd, with no desktop wallpaper and large icons. Open Malwarebytes and run a scan.When your done with MalwareBytes 2.0 scan in safe mode, Click Start then All Programs then Accessories select Run type msconfig and hit enter.
Select the Boot tab, uncheck Safe boot then click Apply and OK
Restart the computer and it will boot back to normal Windows mode.
Remove Delta Search from Internet Explorer
  1. Remove Delta Search add-ons from Internet Explorer.
    Open Internet Explorer,then click on the gear icon " src="http://malwaretips.com/blogs/wp-content/uploads/2013/01/icongear.jpg" ]="" (Tools for Windows XP users) at the top (far right) and then select Manage add-ons.
    From the Toolbars and Extensions tab, select Delta Toolbar, Delta Helper Object, and Yontoo add-ons, and click on Disable.
    " src="http://malwaretips.com/blogs/wp-content/uploads/2013/02/Delta-Search-Internet-Explorer-addons.jpg" ]
  2. Set Internet Explorer default search engine from Delta Search (delta-search.com) to Bing.
    To change your default search engine, click on the gear icon " src="http://malwaretips.com/blogs/wp-content/uploads/2013/01/icongear.jpg" ]="" ,="" select="" Manage Add-ons, and then, under Add-on Types, click Search Providers.
    Select Bing and on click the Set Default button.
    " src="http://malwaretips.com/blogs/wp-content/uploads/2013/03/Delta-Toolbar-Internet-Explorer-search-engine.jpg" ]
    To remove delta-search.com from Internet Explorer, select Delta Search and click on Remove.
    " src="http://malwaretips.com/blogs/wp-content/uploads/2013/03/Delta-Toolbar-Internet-Explorer-search-engine-removal.jpg" ]
  3. Change your Internet Explorer homepage from delta-search.com to its default
    To change your homepage, click on the gear icon " src="http://malwaretips.com/blogs/wp-content/uploads/2013/01/icongear.jpg" ]="" ,="" select="" internet="" explore="" options,="" and="" in="" the="" General tab,under the Home page section, click on Use default to restore Internet Explorer default home page.
    " src="http://malwaretips.com/blogs/wp-content/uploads/2013/02/Delta-Search-Internet-Explorer-home-page.jpg" ]
Remove Delta Search from Mozilla Firefox
  1. Remove Delta Search extensions from Internet Explorer.
    At the top of the Firefox window, click the orange Firefox button, then select Add-ons.
    Select the Extensions tab, then remove Delta Toolbar, BitGuard, Mixi.DJ and Yontoo extensions from Mozilla Firefox.
    " src="http://malwaretips.com/blogs/wp-content/uploads/2013/02/Delta-Search-Firefox-extensions.jpg" ]
  2. Reset your default search engine and home page from delta-search.com to their default.
    To reset your search engine and homepage to their default, we will use the SearchReset extension.This add-on is very simple: on installation, it backs up and then resets your search preferences and home page to their default values, and then uninstalls itself. This affects the search bar, URL bar searches, and the home page.
    You can download SearchReset from the below link, and then we will just need to install it to revert Firefox to its default settings.
    SEARCHRESET DOWNLOAD LINK (This link will open another web page from where you can download the SearchReset Firefox extension)
    " src="http://malwaretips.com/blogs/wp-content/uploads/2013/03/searchreset-firefox-extension.jpg" ]
Remove Delta Search from Google Chrome
  1. Remove Delta Search extensions from Google Chrome.
    Click the Chrome menu chrome-button.png button on the browser toolbar, select Tools and then click on Extensions.
    In the Extensions tab, remove (by clicking on the Recycle Bin) the Delta Toolbar, Mixi.DJ and BitGuard and any other unknown extensions by clicking the trash can " src="http://malwaretips.com/blogs/wp-content/uploads/2013/07/Trash-Can-Chrome.png" ]="" icon.
    Basically, if you have not installed an extension, you should remove it from your web browser.
    " src="http://malwaretips.com/blogs/wp-content/uploads/2013/02/Delta-Search-Chrome-extensions.jpg" ]
  2. Set Google Chrome default search engine from Delta Search to Google.
    Click the Chrome menu chrome-button.png button, then select Settings and click on Manage search engines in the Search section.
    In the Search Engines dialog that appears, select Google and click the Make Default button that appears in the row.
    " src="http://malwaretips.com/blogs/wp-content/uploads/2013/03/delta-Toolbar-Chrome-search-engine.jpg" ]
    Search for Delta Search in the Search Engines list, and click the X button that appears at the end of the row.
    " src="http://malwaretips.com/blogs/wp-content/uploads/2013/03/delta-Toolbar-Chrome-search-engine-removal.jpg" ]
  3. Change Google Chrome homepage from delta-search.com to its default.
    Delta Search has modified your Google settings to open their webpage whenever you start your browser, so we will need to revert this change.
    Click the Chrome menu chrome-button.png button, then select Settings and click on One the New Tab page in the On Startup section.
    " src="http://malwaretips.com/blogs/wp-content/uploads/2013/06/Chrome-default-page.jpg" ]
Jul 19, 2013 | HP Computers & Internet
Machine won't read usb
When you load your designs on your memory stick, they have tt be in a file called " Embroidery" but ALSO in a 2nd file called "My Designs" or the Janome will not read it. Please go to the Janome message boards and you will find tremendous help in learning how to use your machine. Blessings!
bles
Oct 29, 2012 | Default Manufacture Janome Memory Craft MC...
Cordless phone reads Load default Delta file
I unplugged the battery and then plugged it back in.
Nov 21, 2010 | AT&T DECT 6.0 Cordless Phone System with...
What do I do to clear the LOAD DEFAULT DELTA FILE eror message?
Dec 21, 2009 | AT&T 650530003417 Cordless Phone
Vtech phone problem Model # LS6117-5 DECT 6.0
take out battery for a few seconds then put back in. My phone just did the same thing and it kixed it. Not sure why it happened though
Jan 04, 2009 | Vtech Lands Phones
AT&T 650530003417 Cordless Phone Logo
7,486 people viewed this question
Top AT&T Lands Phones Experts
Marvin
Marvin
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
