My printer will not do any color. I have cleaned heads a few times and still won't work. Also can I clean the heads without using up the ink? It is only 3 yrs. old.
  • wolfe_shirle Nov 16, 2009
    My printer is:Kodak Eaqsy Share 5500.
  • 3,940 Answers
You didn't mention the model of the printer, but if the system isn't printing color, the first thing to do is replace the color cartridge with a NEW one and then run a head alignment.
If it still doesn't print color, run the head cleaning process 10 to 15 times in a row, (If the printer model has a seperate head, the nozzles may be clogged with dried ink and multiple passes are required to dislodge it)
If that doesn't resolve, then depending on the model, generally is it cheaper to replace a printer than to get one repaired after the (cost of shipping and labor)
If you replay back with the make and model I can give more specific recommendations.
Posted on Nov 16, 2009
Won't Print Color Ink
INK PROBLEM
Inkjet printers need to be used frequently to prevent inkdrying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
May 19, 2012 | HP PSC 1510 All-In-One InkJet Printer
Black or color printer not printing new inkjet
Ink is a lubricant for the print heads. Some color ink is used even if you only print in black or vice-versa. If you printed with a color missing, you could destroy that print head from the friction of running without ink to lubricate it. That's why most printers won't allow you to print with a color missing even if you aren't using it.
If you allow a color to go empty, the residual ink in the head could clog and become permanently blocked. You would never be able to print that color again. So always replace ink cartridges as soon as they are empty.
Leaving your printer on takes very little power. Every so often the printer sends a signal to cycle the ink in the heads so it doesn't clog. If you turn your printer off, the next time you turn it on it will do a cleaning which wastes a lot of ink. The excess ink is soaked up by the waste pad beneath the printer. When the waste pad is full, the printer stops working. Unless you want to spend more than the cost of the printer or waste a lot of time on a messy cleanup you will end up throwing the printer out. So shutting it off actually shortens its life.
If you leave the printer off for extended periods of time, the ink in the heads will clog and you will have to throw the printer away. Someone I know with a Canon (though this can happen with any inkjet) had to have the heads replaced twice within the first few months before the Canon tech told her to stop turning it off. Since then it has worked perfectly for over a year.
How to clear blocked print heads:
-leave the printer on for a day
-run several head cleanings and print the nozzle check pattern
-if that doesn't fix it, remove the cartridge(s) from the blocked head and drop alcohol where the ink enters the printer.
-reinsert the cartridges
-run one head cleaning
-wait about an hour then run some head cleanings.
-dip the print heads in Isopropyl Alcohol overnight, which you can buy from chemist
-if that still doesn't work, your heads may be clogged to the point where they need repair or replacement, which will probably cost more than a new printer.
Jan 25, 2011 | Brother MFC 210C All-In-One InkJet Printer
I just purchased a new black ink cartridge for my dell 946 printer and properly installed it. When I went to print it said there was a full cartridge of ink but when the paper printed there was no ink on...
Jan 05, 2011 | Dell 946 All-In-One InkJet Printer
I've changed my colour ink cartridge three times now and it still wont print red.
If you allow the red color to go empty, the residual ink in the head could clog and become permanently blocked. You would never be able to print that color again. So always replace ink cartridges as soon as they are empty.
Dec 17, 2010 | HP DeskJet 3650 InkJet Printer
I replaced my black ink cartridge and the printer will not print. I tried shaking the new cartridge. I purchased an Office Depot cartridge #TO529
Ink is a lubricant for the print heads. Some color ink is used even if you only print in black or vice versa. If you printed with a color missing, you could destroy that print head from the friction of running without ink to lubricate it. That's why most printers won't allow you to print with a color missing even if you aren't using it.
If you leave the printer off for extended periods of time, the ink in the heads will clog and you will have to throw the printer away. Someone I know with a Canon (though this can happen with any ink-jet) had to have the heads replaced twice within the first few months before the Canon tech told her to stop turning it off. Since then it has worked perfectly for over a year.
If after that still doesn't work, your heads may be clogged to the point where they need repair or replacement, which will probably cost more than a new printer.
Dec 12, 2010 | Dell Inkjet 720 Printer
I installed a knew print cartridge and it wont print in black ink?
Ink is a lubricant for the print heads. Some color ink is used even if you only print in black or viceversa. If you printed with a color missing, you could destroy that print head from the friction of running without ink to lubricate it. That's why most printers won't allow you to print with a color missing even if you aren't using it.
Dec 08, 2010 | Epson Stylus NX105 All-In-One Printer
Color stopped printing, changed cartridges, still will not print color. Now my black ink cartridge is acting up by starting off not completely printing text. What do I do now, buy a new printer?
Dec 06, 2010 | Lexmark JetPrinter X1185 All-In-One InkJet
Black color will not print. Installed a new black
Dec 06, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
The printer wont print the black i checked all ink levels but did notice that i usually gey a small screen telling me how full the levels are but i get no reading. i've changed the black ink and still...
Nov 30, 2010 | Brother MFC255CW All-in-One InkJet Printer
Canon i960 printer won't print in blue
Your problem is the print head. You can buy one from Canon for about $95, or find them new from dealers on Ebay for $60 to $70. For a less expensive fix, try to remove the print head and clean it. (You don't need any tools, just remove the ink tanks and pull the print head forward and out. Over time, the receivers tend to get dry & crusted ink on them. Note that the inks used are fast drying inks to keep your pictures, etc. from smudging after you print them. Try not to use solvent. I use q-tips and hot water, then dry using another q-tip. If this does not work, there are commercial cleaning kits available for about $10. Short of that, your choice is to replace the print head or the printer itself. My i960 prints such good quality color prints and normal color printing, that I would fix it rather than replace the printer. I hope the easy cleaning does it for you!
Jan 13, 2009 | Canon I960 InkJet Photo Printer
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
