Question about Motorola Mobility Rival A455 Cell Phone
How can I transfer songs from my music to my ringtones
Is there anyway to get free ringtones and music on my iphone 4s witout a computer or an iphone card?
Well I have tried just about everything and one thing works well and that is going to youtube and downloading music then you go to them and set them as ringtone or just listen to them.
Nov 22, 2013 | Cell Phones
Iphone rightone maker software
If you have a song in mind and you want to make a rington out of it then I think you can use itunes to do that. The music file should be an Apple purchased song though...
Aug 31, 2011 | Apple iPhone (16 GB) Smartphone
How can i change the ringing tone of my iphone? can i get music from it's ipod?
You can use the ringtones stored in Settings > Sounds > Ringtones. Otherwise, you can purchase custom ringtones from the iTunes Store application. You can also try using 3rd party applications that are named ringtone makers and try to use music in your iPod application. You cannot set songs in iPod as ringtones directly.
Feb 16, 2011 | Apple iPhone 3G
I want to download an app to download songs and ringtones
Method 1:
Transfer the song(s) you want to set as ringtones onto the microSD card either by connecting to pc via USB or using an SD adapter. Next, Tap on the Music Player, open the music list, press the menu button and select PLAY ALL, this will scan your SD card for music/audio files. Once all your songs have been added to the list, select the song you want to set as ringtone and click MENU key, choose SET AS RINGTONE and that will take you to the RIngtone Trimmer, make the ringtone 30 seconds or less, select Trim and you're done.
Method 2:
Root your HTC Hero, create a directory in your C: drive and name it HeroRIngtones, HTC, or whatever and put there all the ringtones you want to be added (30 seconds or less), then open Command Prompt; make sure your device is connected and already visible. Run the following command "adb push directoryname/myringtone.mp3 /system/media/audio/ringtones" and press enter. Do same procedure for all the audio files you want to set as ringtones.
Method 2 is not available for non-root users.
Dec 17, 2010 | HTC Hero Smartphone
How can i put my music from my music player as a ringtone?
navigate to your music player and then transfer the music or song to a pc and from there by using a ring tone converter software you can change it as a ring tone and save it to your mobile phone and the use it.
or else you can transfer the song to your mobile and then select the song and go to the properties of the song and then set it as ringtone.
Oct 30, 2009 | Samsung Behold Cell Phone
I am adding music on SD card, by a Mac, but when put card into ph, it does not transfer to "My Music", it transfer to audio/ringtones
make sure you read the manual about your phone to see which music file format does it support(MP3, WMA etc).
May 31, 2009 | LG Vu CU920 Cellular Phone
Blackberry storm ringtones
You cannot use the songs you purchase from Vcast as ringtones. You have to actually own the music on your computer and transfer it to your phone. Than you will be able to use that song as a ringtone. Just hit highlight the song and hit menu than set as ringtone.
Dec 28, 2008 | RIM BlackBerry Storm 9530 Smartphone
Memory crd
ring settings select memory card data an select the song
dont forget to rate me
Aug 16, 2008 | Palm Treo 650 Handheld
Ringtones
if you already transfer them to you mobile you should be able to to go to sounds in your phone and apply them.
Mar 19, 2008 | Motorola Mobility RAZR V3
Motorola Mobility Rival A455  Cell Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
