Question about Alpine MRP-M450 Car Audio Amplifier
I got Alpine MRP-M450 which has three nobs on the side. (1) Gain (2) Bass EQ (3) Filter. The Gain works fine but Bass EQ and Filter nobs are keep spinning when I try to tune. I checked with an Autoshop and they said it's broken and you need to replace the part. Can someone help me?
    Novelist:
  • 92 Answers
SOMETIMES THE KNOBS THEMSELVES GET STRIPPED OUT AND THE CONTROL POTENTIOMETERS ARE FINE. YOU WILL HAVE TO INSPECT THIS TO DETERMINE WHICH IS AT FAULT. IF THEY ARE NOT STRIPPED, BUT CONTINUE TO TURN AROUND AND AROUND, THEN THE CONTROL POTENTIOMETERS ARE AT FAULT. LOOK NEAR THE CONTROLS ON THE PC BOARD AND YOU SHOULD SEE THE LOCATION NUMBERS PRINTED ON THE BOARD ITSELF. SEE BELOW FOR THE LOCATION AND PART NUMBERS:
VR101 18E39146S01 VOL,ROTARY 50K
VR102 18E39147S01 VOL,ROTARY 5K
VR103 18E39145S01 VOL,ROTARY 20K
YOU CAN OBTAIN THESE FROM PACIFIC COAST PARTS AT 800-421-5080, BUT YOU NEED TO HAVE SOMEONE QUALIFIED TO REPLACE THEM AS YOU WILL HAVE TO TOTALLY DISASSEMBLE THE AMPLIFIER AND ALSO HAVE GOOD SOLDERING SKILLS. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE....V
Posted on Jan 06, 2010
Testimonial: "First of all, thanks for your reply. I will check the part# and see who can do the smart soldering. Thanks :)"
I have a 900 watt amp wired to 2 mtx 12's. it powers up fine but when the bass hits the power light fades away
Try using a 4ga ground cable. Ground it to the frame of your car. And use a 2ga and a inline fuse 100amp run this to your battery. And you need a cap. A 1000 watt will work good. Hope this helps....
Feb 08, 2014 | Alpine MRP-M450 Car Audio Amplifier
Hi there, my name is adam. I recently bought an alpine typs s 1043d sub (10'') and an alpine mono mrp-m500 amplifier. I was wondering a few things. 1) can u show me a wiring diagram or video or pictures as...
Hello mate,you can do one of two things, you can either google your amp model and download a pdf file of the manual which explains all of what you are asking, or you can email me at butcher960@btinternet.com and i will email you the pdf file, hope this helps you, colin.
Dec 28, 2009 | Car Audio & Video
Alpine amplifiers fade in and out durring high volume bass hits
main problem i think you are having is your loosing power when it kicks a note.. get a power cap! power caps feed your amps constant power! this will solve your problem :)
Jan 06, 2009 | Alpine MRP-M450 Car Audio Amplifier
When the bass cut on the speakers cut off
220 watts RMS x 1 at 4 ohms (400 watts RMS x 1 at 2 ohms)
the amplifier may be over-driven. are there red protection lights coming on the front panel? Or a loose wire - power, ground, or speaker.
Dec 18, 2008 | Alpine MRP-M450 Car Audio Amplifier
Not enough bass
its prolly the deck, did you try turning the alpine's input gain controls up...
its not the wiring, if the wiring was insuficient, it would just melt...
you might also see if you could adjust the bass frequencies or crossover frequency, the crv might just have a different resonant frequency then the rav 4
May 16, 2008 | Alpine MRP-M450 Car Audio Amplifier
MRP-M450 puts out no sound to the subs
The amplifier may be overloaded, check to see if it can handle 4 OHM loads and 2 OHM loads. if it turns off at high volume the amp may be overloaded. if so try a 8 OHM load. if it still turns off it may be an internal problem.
Jan 07, 2008 | Alpine MRP-M650 Car Audio Amplifier
Alpine MRP M450 Problem
Sounds like it is getting too hot and a thermal overheat protection switch is shutting it off. Check to make sure your gain isnt over 3/4.
Dec 05, 2007 | Alpine MRP-M450 Car Audio Amplifier
Alpine mrd-m500
Hi SPDGOD,
Could not find exact, but close manual.  It is the MRP-M450 mono block amp from alpine.
Go to this url and view in Adobe. Print it if you need to
http://vault.alpine-usa.com/products/documents/OM_MRP-M450.PDF
Oct 19, 2007 | Alpine MRD-M1005 500W x 1 mono subwoofer...
The light on top on my MRP-M450 blinks and the amp doesn't work
Well if you took off the cover on the amp and nothing seems to be burn't, check the voice coils on the sub. It's possible the voice coils have separated and is causing the amp to short it self out due to ground error. If that doesn't help let me know and I'll tell you the next step.
Sep 29, 2007 | Alpine MRP-M450 Car Audio Amplifier
Alpine MRP-M450 Car Audio Amplifier Logo
211 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
