Question about AEG T58840 Dryer Electric
Squealing noise on start up drying still works
Squealing noise on start up but drying still works OK. Machgine doesn't seem to be not working properly apart from this noise. Model number is AEG Lavatherm 57560 and is 5 years old.
  • 26 Answers
This dryer needs to be taken apart to lubricate any and all moving parts. Idler pulley and rollers, if they are worn out in any way, replace them.
Also, consider a new belt.
Posted on Nov 16, 2009
Canon mf8380cdw squeals when starting up
Squeals are often a lubrication issue. Can you tell where the squeal is. Front, back, side. sometimes it's hard to tell because sound bounces and could be from anywhere. Does it go away right after first print or after warm up cycle?. Delicate equipment does operate better in the proper environment. The manual will usually tell you what room temp machine will work better in.Try to get a better idea of where noise starts Depending on how long you have had it and the print count it may need to be checked out by tech..
Feb 25, 2014 | Canon imageClass MF8380Cdw Wireless Color...
I have a loud squealing noise upon starting the car. the squealing normally lasts about 30-45 seconds. sometimes the noise will appear aftrer pulling off from a stopped position, as well. all belts
Try to tighten the belts a little firm.Sounds like when engine idling no squelling only when about to take off .Some times belts may seem ok on the outside but if you look on inner side you tend to see cracks in the belts .
Jan 06, 2014 | 2000 Mazda 626
Squealing noise when drying clothe
While the drum belt could be PART of the problem, I would suspect the bearing failing and rubbing against the cabinet.
You can purchase the belt (and bearing) from www.searspartsdirect.com
Jan 18, 2012 | Samsung Dryers
There is a loud noise while going through final stages of wash. Sounds like pump motor whineing.
Hello
When an appliance such as a dishwasher starts making a new noise, you need to isolate the cause of the noise so that you know whether or not it is damaging the machine. Several things can cause a noisy dishwasher.
Motor
Dishwashers are driven by an internal motor that gets quite noisy when defective. The problem occurs when a seal breaks down and allows water to access the bearings in the motor, removing the grease needed for proper lubrication and creating a loud motor noise when the dishwasher runs. The seal or bearings need to be replaced in this situation quickly or more extensive damage to the motor may occur.
Inlet Valve
If the inlet valve on your dishwasher is broken or breaking, you will hear a distinctive thumping or clattering noise whenever a load is run. A thumping noise doesn't always indicate this problem, however, depending on when you hear it. If you hear a noise like this when the water is filling up the dishwasher at the start of the cycle, the noise likely points to an inlet valve problem.
Squealing
A high-pitched squealing noise is an indication that something is wrong with the fan. Fan bearings that are worn out indicate that the fan apparatus needs to be replaced. If the noise you're hearing is in fact coming from the fan, it will only occur when the dishwasher is drying the dishes. Dishwashers use a fan to generate and distribute heat to dry the dishes quickly.
Minor Concerns
Sometimes even a minor concern can cause a great deal of noise. The thing to watch for is whether or not the noise repeats itself on multiple loads. A loud noise on a single load that doesn't repeat could be caused by things like a loose utensil or small implement rattling around loose in the dishwasher. Also inspect the bottom of your dishwasher. Hardened bits of old food can become rock hard under the heat in the dishwasher and cause noise when the unit runs.
Sep 11, 2011 | Fisher and Paykel 23 in. DD603H SS...
My dryer started making a squeaking sound. It's
Belt needs to be replaced,have you ever had a car drive by and heard a squealing noise? dryer belts "glaze" and squeal due to wear just like the ones in your engine
Apr 01, 2010 | Frigidaire Electric Dryer
1999 dodge durango 5.9 v8 loud squealing noise from under hood replaced tenison pulley, idler pulley, ac pulley/clutch assembley,and belt please help
You didn't mention the alternator, power steering pump, or water pump. In fact, any pulley other than the crankshaft one can have a bad bearing or dry seal. Remove the belt and spin each pulley while listening for any rough noise or squeal. If it was the crankshaft, it might be time to check the oil. Start the engine with the belt off to see if it does squeal. Make sure the noise isn't coming from the radiator fan(s).
Nov 17, 2009 | 1999 Dodge Durango
Put dryer belt back on, correctly
Rick,
It sounds like you are having a problem with the tensioner for the dryer belt - when this device starts to fail, it can sometimes be lubricated with oil and last a little while longer, but will usually need to be replaced. The squealing you hear is a dry bearing for the tensioner pulley. While you're in there, also look aroud and listen if you hear any strange noises coming from the other spots. There could also be issues with the dryer support rollers or support guides.
I am asuming the belt is ok and the drive motor is working properly.
Apr 20, 2009 | Dryers
Kenmore 110.86874100 Motor (?) Squealing
I don't think they can be, but, also take a look at the fan bearing assembly too. You should be able to isolate if the noise is from the motor bearings or blower bearings.
Jan 26, 2009 | Dryers
High pitched squealing and now not working
Seems like the wii froze. Try other discs and if worse comes to worse send the wii to nintendo
Dec 31, 2008 | Nintendo Wii Console
Hoover Nextra 8 dryer making a squealing noise
you have to open the dryer and lubricate the rollers, these are the parts that normally make the squealing sounds.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Dryers
AEG T58840 Dryer Electric Logo
833 people viewed this question
Top AEG Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Gaark
Are you an AEG Dryer Expert? Answer questions, earn points and help others
