Question about HP Pavilion MX75 17" CRT Monitor
Monitor display problem
All my windows goes down...bt when i re-plug the power supply of the moniter the problem solves ... bt after few mins .... same problem arise..!!
    President:
  • 414 Answers
Though itz very unclear n i don't understand the moral meaning of windows going down..!!..n wat is the link of windows going down with ur monitor..
however, itz probably causing from faulty or defective smps or main/mother board..
if not probably itz causing from the monitor itself..
proceed to verify with the below stated steps, only if u r a professional..
DO IT ONLY IF U R A PROFESSIONAL..
..plz do check the following as in order:..
the Hardware part:..
1) check mains/power supply..the fuse, switch, wiring n associated circuitry..
2) [in case of desktop] thesmps itself may b defective/faulty..check the outputs of smps viz. 0v(black~ground); +12v(yellow); +5v (red, green~ps-on, violet~pg&grey~sb); -12v (blue);-5v(white); +3.3v(orange)..
check the battery n adapter [main power], in case of laptops..
replace with a standby n see..
3) unplug mains supply..pick open/remove the cmos battery..check (above +3v)..resit..
4) open the cpu n see if heat is generated..if not..replace the cpu n see..
5) open the CPU Heat-Sink with fan out of thesocket..put some "Heat Sink Compound" (available in local electronicschip level spare market)between the cpu/processor and the CPU Heat Sink*** fan..resit/fit it tightly in position..
6) on main/motherboard..see with a debug card for mb error..may b short..look fordefective capacitors(espabove1000mfd)/mosfets..go through the mb'ssouth bridge n the circuit lie around atx connector..the crystal clockgenerator (if cpu isn't heating up)..
7)seeif the ram(s) is loose/faulty..open clean/remove carbon & or oxideformed on the teeth with an eraser n resit it..or replace with a standbyn see..
8)remove/clean dustneatly..dust is non-uniform in nature n may causejam/short circuitry/excess resistance n many more..resulting an increasein heat..
9) if all above fails..just try to service the monitor..open and re-sould all the dry soulderings..itz probably is causing due to ur monitor's internal circuit dry-soulds..esp. at the crt base n around the horizontal output section (hot)..
the Software part:..
1)hv a licensed and UPDATEDantivirus installed (i prefer avg/kaspersky,remember, without updationa full version antivirus is useless)..
2) download, install n run microsoft kb890830..http://www.microsoft.com/downloads/details.aspx?FamilyId=AD724AE0-E72D-4F54-9AB3-75B8EB148356&displaylang=en..
3) download n run Startup Control Panel..http://download.cnet.com/Startup-Control-Panel/3000-2094_4-10039330.html..'removeall the unnecessary startup items from here..(if u can't find whatto remove, post me/us in ur comment with all the items listed in eachn every tabs herein)..
4) remove all unnecessary software from add/remove programs..
5) download, install n run 'Advanced System Care Pro'..http://download.cnet.com/Advanced-SystemCare-Pro/3000-2086_4-10399324.html..
6)disable the following:..
a)'Automatically Restart'right click on my computer->properties->advanced->startupn recovery->(un check on the) Automatically Restart;
b)'Error Reporting'right click onmy computer->properties->advanced->error reporting->disableerror reporting->(uncheck on the) 'but notify me when critical erroroccur'..
7) Increase the size of Virtual Memory, Initial: 1440; Maximum: 2880
if u r not a professional, always better to seek advise from ur system admin/vendor....
Posted on Nov 16, 2009
Aadab: when the moniter ON after few second the moniter is does not give display and when we on and off the moniter so then the picture displayed why this problem is occure.how i recover it.
That is because the settings on the power are set for the monitor to go to sleep if not in use.. It is a very quick and easy fix.. Just right click anywhere on the desktop that doesn't have any icons, the display properties box will appear, then click on screen saver under monitor power click on power, there you could set the monitor never to turn off... Let me know if this solved the problem and good luck..
Sep 09, 2011 | Compaq Presario 5000 PC Desktop
I had a power failure in my area. When power was restored my pc booted up ok but the monitor screen only stays visible as it should for about 3 seconds, then it goes black screen. I have powered...
Close windows down. Wait 15 - 20 mins, then power monitor up but NOT windows. Screeen should say "NO SIGNAL in centre. If t does not, wait five mins If still no display shut down and wait another 5 mins. Then start monitor un ANDt windows.. All should be OK now, If not shut EVERYTHING down and disconnect from mains ovrernight. (PC riouter/modem,,,, EVERYTHING . 12 hours later, re-connetc in THIS order - 1.) MONITOR 2.) PC 3) ROUTER/MODEM Should be OK now.
Aug 17, 2011 | Acer X193W LCD Monitor
My hard drive clicks and the moniter turns off
Hi, you can isolate that problem to see what is the defective part;
1. Remove the hard disk connection from the board and its power then re-start the PC.
2. If the PC powers and initializes, then you can prove that the defective is the hard drive. If the same problem that it shuts down then. the next target is the power supply. If you change the power supply and it turns out success, then we have solved the problem, if not, next thing is,
3. Turn off PC, remove the battery/clear cmos, the memory and the processor for 20 minutes.
4, After 20 min re-install the battery, memory and processor. Without the hard drive when starting, lets see if it will boot without the O/S.
others, when you say the monitor turns off, does the CPU still working or not? Isolate also the monitor by powering it on and not attaching the communication cable to video port, lets see it the monitor itsel display by its internal video logo to be sure it is okay.
Jun 22, 2011 | Computers & Internet
Hello sir i have a broblm in my samsung synicmastr 19" blak, when i switch on the moniter, the moniter is with in 2 or 3 second automitically off the display light but moniter is still on and display...
this problem can occur cause of two cases 1 problem with LCD panel (replacement can solve) 2 power failure in side moniter (repairing moniter can solve)
thanx PLZ vote
Feb 22, 2011 | Samsung SyncMaster 931B 19" LCD Monitor
I have lg flatron l1730s lcd black color monitor. I have problem with this. Power not come. some time when i connect it power LED blinking once then no display. Some time when i connect it power LED...
Oct 14, 2010 | LG L1730S 17" LCD Monitor
Samsung SynchMaster 191N Monitor stay on fine for 15-20 min after that it goes dark,, and power swtich thrun itself off, cannot turn on or off, unless I unplug power for few min and replug. Then stays...
If the OSD has display and after a min goes dark that monitor has 2 possible problem. 1. bad electrolytic capacitor from secondary power supply to inverter area or fault semiconductors around inverter area. 2. Bad CCFL or fluorescent lamp of lcd panel it may be reddish color.
Sep 29, 2010 | Samsung SyncMaster 191T 19" Flat Panel LCD...
I have sony vaio desktop. My moniter keeps going off and on. Tried different moniter does the same thing. Could it be something that the desktop might be causing. Also, last year I replaced my power...
When you say 'on and off' you have not indicated if the whole power on the monitor is going on and off or if the monitor remains turned on but the screen display goes on and off.
Is the monitor power plugged through the socket on the pc or direct to a power outlet?
multiplug power outlet boards are often a source of power failure.
Did you try a different power lead for the monitor and b) a different wall socket?
If it is the screen display that is intermittent you should check the graphics card is fully seated (if it's a separate one)
Aug 12, 2010 | Sony VAIO VGC-RB42G PC Desktop
The montier turns on then turns right off
Hi!
When a monitor display image for a second and then goes to black screen... there are possible reasons why this problem occur..
1. You need to check if the high voltage ballast transformer of your backlight inverter is about to be burned... the transformer is overheating..that's why you experience the monitor working for a couple of seconds and then it will shut off until the transformer cool down again and then it will be ready to work again...
2. Check also the backlight inverter if it is busted...the backlight inverter is the light source responsible for the image display you seen on your screen. If this are busted then all that you will be seeing is black screen
3. You need to check the power supply section for possible loose connections and possible blown and bad capacitors..
the ballast transformer has direct effect on power supply section.. when there is overheating transformer,,, the supply current from the power supply section becomes unstable.. and will not be able to supply the remaining good working ballast transformer.
In case you do not know, the ballast transformer generates high voltage for the backlight inverter to work....
Please be advise that if you don't have the knowledge, the proper skills and the right tools to open the back cover of your monitor and replace its part...don't risk it...
Otherwise, bring your unit to a credible technician and avail of warranty if there is any.....
Much appreciated if you rate this help...thanks...
May 25, 2010 | HP f2105 21" LCD Monitor
My laptop moniter turns on as usual with the proper reading. I start in safe mode as normal..wait about 10 min and screen goes white
hello
"I start in safe mode as normal."
safe mode is not a normal thing during your windows boot sequence :)
if your display works ok until those 10 minutes of safe mode are over i would say that reinstalling your windows operating system will most likely solve your monitor issues :)
Mar 24, 2010 | Princeton Digital LCD17 17" Flat Panel LCD...
Does a bad power supply look like this?
i suggest that you buy a new monitor coz your current monitor is too old...there's some electric component is weaken...its better to buy new than to repair the old one..
Mar 08, 2007 | Mag Innovision LT776s 17" LCD Monitor
HP Pavilion MX75 17" CRT Monitor Logo
127 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
