Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Liftmaster mod 1245R (1999) has indicator lightLiftmaster mod 1245R (1999) has indicator light blinks 5 times. Door will not operate from hardwire button. Tried unplugging unit to reset but same 5 blink sequence returned. Held button in to reset but no difference. Only get clicking sound at control unit when hard-wire button pushed. Need help! More Liftmaster mod 1245R (1999) has indicator light blinks 5 times. Door will not operate from hardwire button. Tried unplugging unit to reset but same 5 blink sequence returned. Held button in to reset but no difference. Only get clicking sound at control unit when hard-wire button pushed. Need help! Thanks. Comments: Nov 15, 2009 - Don, Thanks for help but door was not in open position. It was unattached to trolley that was in the full down position. The chain seemed tight when I connected the door to the trolley so I loosened the lock nuts and took some tension off the chain. Tried turning the travel controls and pressure controls to see it would operate but it only clicks when hard-wire button pushed. Thanks, Paul See less Solution #1 posted on Nov 14, 2009 Don0930 Rank: Guru Expert Rating: 88.38% , 441 votes If your door is in the open position and the trolley is jammed against the bolt just in front of the motor unit you need to remove the bolt and then run the opener until the door closes. While the door is closed locate the 'up limit control' on the side of the motor unit and turn the control a couple complete turns in the opposite direction of the arrow printed on the cover.
  • 19,396 Answers
Hi.
5 Blinks means RPM sensor failure or motor overload.
As a result the motor will not operate, or the trolley will get stuck on the stop bolt, with motor humming briefly and RPM sensor stuck.
Cut power to the unit to reset.
Wait thirty minutes before re-connecting power to allow the over heated motor cooling down.
If it is still flashing when you connect power back, then the RPM sensor must be replaced.
Regards.
Posted on Nov 16, 2009
2 Suggested Answers
  • 3197 Answers
SOURCE: Liftmaster mod 1245R (1999) has
The LED flashing 5 times is the code for "RPM sensor or motor overload". Usually if it is the RPM sensor - which is a small printed circuit board just in front of the motor - it will run a few inches and then reverse. I doubt very much it is the motor. I would pull the logic board and check for loose or missing traces on the printed circuit. Especially if you have had any electrical storms or power surges.
Testimonial: "Thanks very much. I will pull the board and check it."
Hi, My g. door opener doesn't work. The
5 Blinks on the logic board LED indicates that possibly the motor has overheated. If you have unplugged the unit and waited minimum of 30minutes before plugging it back in, and it still will not operate, then the logic board will need to be replaced.
I hope this helps
May 12, 2011 | liftmaster Chamberlain Garage Door Opener...
Liftmaster mod 1245R (1999) has indicator light blinks 5 times. Door will not operate from hardwire button. Tried unplugging unit to reset but same 5 blink sequence returned. Held button in to reset but no...
The trolley is most likely jammed against the bolt just in front of the motor unit. Remove the bolt and then run the door until it is closed. Now locate the 'up limit' control on the side of the motor unit. Turn this 2 complete turns in the opposite direction of the arrow printed on the cover. Be sure to replace the bolt.
Dec 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster mod 1245R (1999) has indicator lightLiftmaster mod 1245R (1999) has indicator light blinks 5 times. Door will not operate from hardwire button. Tried unplugging unit to reset but same 5 blink...
Nov 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Nov 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
No response to remote on Liftmaster 1/3 HP model # 1245R
It has probablly lost sync.
Follow the procedure to reload the codes. One usually has to hit a reset button on the head and then follow a sequence to sync your remote to the head.
Sep 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Garage Opener Clicks only and LED blinking 5 times
Just fixed this problem tonight. Had the 5 blink/flash thing. Opened it up and saw that the motor wasn't spinning so it wasn't a bad rpm sensor. Jumped the red to black and then the blue to black to verify motor worked. At that point assumed it was the logic board not telling the motor to start, but I could hear the click of the relay. Pulled the logic board out and noticed a solder joint that had failed directly behind one of the relays. Resoldered that joint and the garage door opener worked again like a dream. Hope that helps someone else.
Feb 28, 2009 | Building Materials
Door opener moves foward about 10 inches then returns
UNPLUG THE UNIT FOR ABOUT 5 MIN. TO RESET TRY TO OPERATE IF IT STILL MOVES 6-8 INCHES AND FLASHES 5 TIMES THE RPM SENSOR IS YOUR PROBLEM - COULD JUST BE THE CUP HAS MOVED ON THE SHAFT. IF IT IS IN PLACE AND STILL NOT WORKING REPLACE THE PICKUP.
Dec 11, 2008 | Sears Craftsman LiftMaster Chamberlain...
Raynor 1245rgd navigator learn button blinks
5 flashes on operator and the short movement on the door indicates a bad RPM sensor. try to unplug the unit for 30 seconds, if this does not reset the motor, replace the RPM sensor
Dec 10, 2008 | Sears Craftsman LiftMaster Chamberlain...
Trouble changing passwordon model 940CB wireless keyless entry
easyer then that , you die! Open your garage door, take out the step ladder, a chair or get up on *********** in law's back, (here's your chance to be on her back for a change) press the read button of your unit (motor) a led should light up and on the key pad, key in the new 4 digits code and press enter, the light of the unit should blink javascript:; Post Solution
May 19, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
276 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
