Question about Microsoft PowerPoint 2007 for PC
PowerPoint 2007 causes PC lockup after being used for several hours. We're seeing this on multiple PCs, so it's not the hardware's fault, it must be a problem in PowerPoint itself. Files are in .pptx format.
    Problem Solver:
  • 14 Answers
Ahhh, thats powerpoints tendancy to hog the memory and not release it leading to the machine crashing or locking up as you observed. Microsoft have a fix for this you can download, I used it last year in 250 machines. So far so good. Best of luck.
Posted on Dec 19, 2009
Testimonial: "Thanks! I'll check it out right away!"
Powerpoint 2007 cannot open .pps file created in Powerpoint 2003
I would prefer guide below or another methods are proposed from different sources over Internet, but in case the guide from MS Corporation can't handle the problem
https://www.openfiletool.com/pptxopen.html PPTX Open File Tool
http://itknowledgeexchange.techtarget.com/itanswers/how-to-open-powerpoint-file/
http://community.office365.com/en-us/f/172/t/268740.aspx
  1. Open PowerPoint 2007.
  2. Click the Microsoft Office Button and click Open.
  3. In the File name: box, enter the text in bold to display a list of the automatically saved files (if any).You can also copy and paste this text into the File name: box.
    PowerPoint 2007: %temp%\ppt*.tmp
  4. Click the Open button.
  5. Click the name of the file that you want to recover, and then click Open.
    Note : The automatically saved files may not be named in a descriptive way. Continue to open files until you find the one you are looking for.
  6. After you find the file, click Save. Then save the file to your My Documents or other location.
Oct 23, 2015 | Microsoft PowerPoint for PC
Message in Powerpoint: Part of the file is missing. How to fix it?
your powerpoint file seems to be severely corrupted. You may try to open this file in PowerPoint Fix Toolbox http://www.powerpoint.fixtoolbox.com/
If if it useless follow the steps 1) Open a new presentation and use Insert --> Slides --> From existing presentation to pull in the slides from the corrupted file. This works about 50% of the time.
2) Try using the Clone Me add-in from Microsoft. It may work, it may not.
Or see more http://www.filerepairforum.com/forum/microsoft/microsoft-aa/powerpoint/679-could-you-help-me-with-recovering-ppt-file
Feb 06, 2015 | Microsoft PowerPoint 2007 for PC
Does Microsoft Office PowerPoint 2003 can be open in Microsoft Office PowerPoint 2007?
Yes Microsoft Office PowerPoint 2003 can be open in Microsoft Office PowerPoint 2007 But Microsoft Office PowerPoint 2007 cannot be open in Microsoft Office PowerPoint 2003
Thanks for using FixYa
All the Best!
Jul 25, 2011 | Microsoft Office Home and Student 2007...
I have a malata notebook pc which i bought from china. Now it kept hanging after i work on it for 10 minute.i change the memory, format the hard drive and do sort of thing. what can i do.
Once it freezes up, have you tried pressing the CTRL + ALT + DEL? If the CTRL + ALT + DEL did not work, then its a hardware lockup. Hardware lockups are usually problems with hardware, failing memory being the common cause.
Though you change the memory, that does not mean that the memory is working correctly. Try testing the memory, use a bootable CD to start and run your computer. let it run for several hours and see if it reports any memory problems.
If everthing checks out ok, there are some more Operating system idenpendent ways to isolate the problem. Contact a technician to see if the problem is the hardware or the software.
Have a good day!
Oct 11, 2009 | Office Equipment & Supplies
I can't get powerpoint 2007 to work.
Solution given by pankaj is very effective but in any case this method didn't work for you then use stellar phoenix powerpoint repair software to fix your problem.
Sep 09, 2009 | Microsoft PowerPoint 2007 for PC
Powerpoint 2007
Has the powerpoint document been saved as an office 2007 document or as a prior version? in office 2007 in order to open it in 2003 it must be saved as a prior version of office. You can download a patch to read newer versions, but that is not always the most reliable process.
Jun 09, 2008 | Microsoft Office Professional 2007 Full...
PowerPoint Viewer 2007
The PP2007 is just a converter from 2007 to 2003
If you are trying to view PP2003 files, then install the PP2003 viewer. The PP2007 is just a converter from 2007 to 2003
Jan 04, 2008 | Microsoft Office Outlook 2003 for PC
PowerPoint
Hi it is not the problem related to PP viewer. The problem with the Browser or iexplorer.exe So please try to upgrade it to IE7 or repair internet explorer and restore defaults of the explorer settings..
I face the same problem then i done like this.
I resolved the problem....
Goodluck :)
Jan 02, 2008 | Microsoft Office Outlook 2003 for PC
Freezing up
A few things to try. Check the event logs on your PC for Hard drive errors. If the lockups are random they could be caused by bad blocks on your drive in a paging or system file. If you see disk errors, replace the drive immediately and make sure to keep proper backups. Next, update all drivers, especially the video driver. Often lockups will be caused by Video driver corruption. Dont be scared to install beta versions of drivers for your laptop in an attempt to resolve the problem. Next, search out a utility boot CD from the internet. There are several, usually running linux but most contain a memory test utility that you want to run for a long period of time (several hours) to see if after a stress period you start getting memory errors. Next, search for speedfan on google and install it to monitor the temperature on your processor, this problem could be caused by dust buildup on the processor heat sync or cooling fan. Generally it would take some time to have this problem lock up the system, however, after the first lock up and reboot subsequent lockups would happen more quickly. Many laptop repair depots will do a service for under $100 where they will dissassemble the machine, clean the heat sink and fan (or replace it) and apply new thermal grease.
Jun 20, 2007 | Acer TravelMate C312XCi Tablet PC
Microsoft PowerPoint 2007 for PC Logo
111 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
