Question about Zebra Printer 140-751-00000
140 install Zebra 140 using USB
    Champion:
  • Zebra Expert
  • 285 Answers
Install the correct drivers from www.zebra.com
http://www.zebra.com/id/zebra/na/en/index/drivers_downloads.html
check if printer is connect and on.
wen finish, restart the computer, he can check automaticly.
check on START-Printers and Faxs- see the printer icon - print test page
Posted on Nov 13, 2010
140Xi II Thermal Printer: how can I put my zebra xi-140 printer in self clea...
There is no such thing as self clean mode. get a cotton swab soaked in 90% or stronger isopropyl alchol and wipe the print head. be careful not to scratch.
May 16, 2010 | Zebra 140Xi II Thermal Printer
Zebra 140 head cold on led display. What does this mean?
you need to run some labels to warm up the printhead. its not a problem, its just a warning. you can disable fthis warning from the setings.
May 10, 2010 | Zebra Printer 140-751-00000
Please help me find a driver for zebra 160S supporting Windows XP
Go to zebra.com and download the ZUD - (Zebra Universal Driver) - not the Zebra Designer Driver. Run the setup utility and install the driver for the 105SL and choose the port for your 160S. You may have to change the driver properties for firmware versions X.10 and earlier - I do not think that this feature is supported in the Designer Driver. The main point here is that if you can't find support for your specific model, install another model that supports the same features and print language. In your case, the 140XiIIIPlus has thermal transfer and runs on ZPL (Zebra Printer Language) just like your 160.
Jan 29, 2010 | Zebra Printer 140-751-00000
What keys on the control panel do you use to make a zebra printer do a cold reset
It all depends on what type of zebra you have. Some have different buttons than others...
Jul 08, 2009 | Zebra Printer 140-751-00000
Printer problem
your problem may be in the serial /usb adaptor that you are using
any reason why you cannot connect the usb cable from the printer directly to a usb port on the computer
like any other printer
Mar 19, 2017 | Zebra Eltron Orion LP2443 Thermal Printer
How Send EPL2 commands to USB
Use the Zebra ZUD driver. Latest version V5.5.7.25 (Download from Zebra website). When driver is installed, go to printer & Faxes folder and double-click on the installed printer icon.
Click Printer/properties/printer/advanced (+)/tools (Click on tools) This opens a text box. Type commands in here and send directly to printer. E.G type U click send and it will print a config sheet.
This definately works.
May 14, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Sizing and Orientation problem on Zebra 140 Xill
As far as the size it sounds like it might not be using the right resolution these come in either 200 or 300 DPI. Make usre your DPI is set to the same as the printer. If the printer is 300 and the design shows 200 then it will print rather small on the label. Not sure about the other issue.
Mar 17, 2009 | Zebra 140XiIII Plus Thermal Label Printer
UPS Thermal 2844 Connection problem(USB)
Add the printer as a Local LPT1. Then go into the properties and switch the port to a USB port. Try a test label. If it doesn't print, go back to properties of the printer and switch it to another USB until it does. If all else fails there is a remove utility included with the Zebra drivers you downloaded. You can remove all zebra related drivers and printers and then reboot. The PC should redetect the printer when you turn it on.
Feb 21, 2008 | Zebra LP 2844 Thermal Printer
How to configure the Zebra S500 using a USB to Parallel adapter?
The Zebra Stripe S500 has a RS-232 SERIAL interface using a DB-25 connector . You'll need a USB to SERIAL converter, not parallel. Be sure that the baud rate and data/stop bits are set the same on the printer and interface converter. Generally speaking, use the fastest setting possible (19200 baud) unless you encounter problems.
Oct 30, 2007 | Zebra Stripe S500 Thermal Label Printer
Zebra Printer 140-751-00000 Logo
771 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
