Question about Briggs & Stratton Garden
How to start a Briggs and Stratton Classic 35 lawnmower? Or where to obtain a user manual?
  • 8 Answers
SOURCE: briggs a stratton 35 lawn mower
Turn the mixture screw on the carburator slowly counter clock wise till the idel stabalizes.
Posted on Jul 01, 2009
  • 61 Answers
SOURCE: 5hp briggs & Stratton lawnmower
ck fuel pump its on the side of the carb
3or4 screws hold cover on .
Posted on Sep 06, 2009
rwvanlue
  • 486 Answers
SOURCE: Briggs & Stratton 6.75 lawnmower. Won't start.
1) Determined that there is spark?
2) Have you used a type of spark tester?
3) What is the condition of the plug. Brown or dark brown is OK. Black or silver is NOT Ok.
*If you do not have a spark tester,
a) remove the plug, and with it connected to the wire,
b) find a portion of metal around the cylinder that you can ground it on, and then pull the rope.
c) If the plug is black, you may see spark, but you should replace the plug.
*** PLEASE NOTE ; if there is excess fuel in the cylinder or on spark plug,
it can catch fire, so be carefull to cover the hole with a heavy rag so that any fuel
cannot be exposed to spark plug durning test !!!!
Get back with me on how this issue works out.
thanks, rwvanlue
Fuel Starvation - Float Bowl Carburetor
1) remove air filter assembly
*be cautious of tearing the mounting gasket. If it does tear, you HAVE to replace it. It is part of the priming system
2) remove the float bowl fastener. This is the main jet
3) carefully remove the float bowl, the rubber o-ring/gasket will not be able to be used if it is removed, you WILL have to replace it
4) using a spray 'carb cleaner'
spray up thru the center of the carburetor
spray and clean the main jet with cleaner and 'tag' wire
(tag wire is very thin, and can be used to clean the hole in the center of the main jet)
5) clean any debris from inside the bowl or carb body
6) re-install bowl and center bolt, air filter assembly
*if you need gaskets, your local lawn & garden dealer can supply. The kit is cheaper than individual gaskets, and all the parts needed to finish the above repair are in the kit.
Posted on Nov 26, 2009
  • 10 Answers
SOURCE: Lawnmower timing settings needed
yep
Posted on Jul 25, 2010
eugbug
  • 479 Answers
SOURCE: I have just bought a
10W30 or SAE 30 oil is fine for four stroke engines up to about 4 HP
Have a look at this video for details on checking oil levels and type:
http://www.briggsandstratton.com/engines/videos/Maintenance%20Repairs/Checking%20The%20Oil%20In%20Your%20Briggs%20and%20Stratton%20Engine/
and this webpage:
http://www.briggsandstratton.com/engines/support/frequently-asked-questions/Engine%20Oil%20Recommendations/
Posted on Sep 03, 2011
Briggs & Stratton 35 Classic. How to fit the cable to drive the tines. Help!
briggs and stratton 35 classic is the model of engine not the rotavator
May 06, 2015 | Briggs & Stratton Garden
Where can i get a repair manual for Briggs and Stratton Champion 35 Lawnmower
contact Briggs and Stratton USA, they will have them. I got one 12 months ago for a different (old) model.
Apr 22, 2015 | Briggs & Stratton Garden
Briggs and stratton 35 classic. Need piccy of arrangement of carb/choke links and springs as think someone has changed them and mower no work. Model 9D902. Lever which may be choke, does not stay in place...
check youtube,guy on there has pics of spring set up,and still pics to follow the video.
check this name on youtube:4 HP Briggs & Stratton Quatro Motor Spring & Linkage Close Up Detail
Apr 25, 2011 | Briggs & Stratton Briggs Stratton...
Briggs and stratton 6.5 Ohv dies after running for about 10-15 minutes. I let it sit awhile then runs again. This is a vertical shaft lawnmower engine.
This is a classic symptom of a blocked fuel cap vent. Next time it dies, remove the cap, wait 30 seconds or so (for carb to re-fill), then try to re-start. If it works, replace the cao.
Aug 07, 2010 | Briggs & Stratton Garden
Garden Logo
1,292 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
