Question about Nokia 2600 Classic Cell Phone
DISPLAY IS OK BUT DISPLAY LIGHTS IS NOT WORKING,I CHANGED DISPLAY TO NEW ONE STILL SAME PROBLEM
Nokia2600c(classic)
Posted on Dec 24, 2011
  • sajeersajeer Dec 24, 2011
    nokia 2600c(classic)display light not work
Samsung champ duos c3262 no display forums fix
many reasons are major cause for no display,blank display,scrambled display. In samsing champ duos c3262 no display problem terouble shooting.first connect with charger no charging logo on screen.open your cell phone and clean pcb and lcd connector with corbon tetra cleaner(ctc)dry normal.problem not solve then try seen lcd with lamp if display is shown but no light make light jumper or change lcd.lcd ok and new 100%working condition please be care fully check lcd connector.no display no luck final heat or replace display controller ic.
here is the light ic jumper if your lcd is black and now lights.
click on link for jumper ways by image. Samsung champ duos c3262 no display jumper Phonetolls
Jan 04, 2015 | Samsung Cell Phones
I have an Electrolux refrigerator (ei23cs55gs1) who's display is stuck on "door ajar" and does not let me select ice to dispense only water. The display is not complete (like a series of dashes) but turns...
you could have a defective switch or a defective display. Check as best you can to see if the switch is being depressed by the door when its closed. Check to see if it works, hold the door open and depress the switch yourself and see if the light goes out. If the light stays on you need a new switch. if the switches seems to work ok you make need a new display board.
http://parts.sears.com/partsdirect/part-model/Electrolux-Parts/Refrigerator-Parts/Model-EI23CS55GS1/1412/0165000/R1201135/00007?shdMod=EI23CS55GS1
Aug 05, 2013 | Electrolux Refrigerators
My phone is a Nortel Networks phone T7316e I want to change my personal greeting but when i press "pers" it asks me for a greeting number. I do not know what the number is. My extension is 21...
Recording Company Greeting 1 Press FEATURE 9 8 3
The display shows
Log: QUIT RETRY REC
2 Enter 1 0 2 0 0 0 0
3 Press OK
The display shows
Admin MBOX AA OTHR
4 Press AA
The display shows
Auto Atdt Admin GRTG TABLE LINES
5 Press GRTG
The display shows
Greeting Admin GRTG AA
6 Press GRTG
The display shows
Greeting: RETRY OK
7 Enter Greeting number "13" (for holiday recordings
8 Press OK
The display shows
Greeting RETRY PLAY REC
9 Press REC
10 At the sound of the tone record the greeting.
Greeting: "Thank you for calling (your company name)..........."
11 Press OK to end your recording.
The display shows Accept Greeting:
RETRY PLAY OK
NOTE: To listen to the greeting press PLAY, to re-record the greeting press RETRY
12 Press OK to Accept the greeting
To program to play
1 From Step 12 press *
2 Press Table
Auto Atdt Admin GRTG TABLE LINES3 At Grtg table: enter 1
4 Grtg table: Retry OK
5 Press OK
6 Press OK again @ AA menu prompt
7 At Morning: 1 press CHNG to whichever new greeting you recorded
CHNG Morning: 1 PLAY NEXT
8 Continue by pushing next through all times
9 Afternoon:2 CHNG PLAY NEXT
10 You should note which times had which greetings to change back after holiday
11 After you change all the times Morning Afternoon Evening Non-business press Release
This will work for setting a new greeting as well, you can use numbers 1,2,3 etc for the greeting numbers to set them at different times of day in the table.
Feb 24, 2011 | NorStar T7316E Corded Phone
W200i-keypad light ok,no display light
its hardware fault i think lcd fault try to change it
Feb 12, 2011 | Sony Ericsson W200i Cellular Phone
Lock remote stopped working. changed baterry, tried to reprogram as per manual nothing works
some auto parts stores have a display at the counter where they sell new remotes or fob's. The display has a sensor that lights up when you use your remote. Point the remote at the display and press any button if the light comes on your fob is likely ok. may need to check the receiver. good luck
Nov 30, 2009 | 2002 Ford Explorer
The motherboard not give any display !
last 2 things to do
1.remove the cmos battery
2.remove the cmos jumper.
remove power cable from power supply.
3.wait for 2 to 3 mins
4.put the jumper back to the correct position usually pin one and pin 2
5.try to start the mb if ok
ok
Nov 13, 2009 | ASUS P5N32-SLI Deluxe Motherboard
Having display light but display is not working
The display circuit is broken even if the LCD-panel seems to be ok. the only circuit working in the display is the one for the backlight.
This is a very common Nokia display problem.
Only solution is to change the display.
You need a T-6 Torx skrewdriver to do the job.
You can find displays for fair prise at:
www.mytrendyphone.com
This is your solution! Please vote!
Jun 27, 2009 | Nokia 3120 Cellular Phone
6070 lighting no work
Your display circuit is broken, even if the LCD-panel,
seems to be ok the display is damaged.
This is a very common problem in Nokia phones.
The only way to fix this is to change the display.
You need a T-6 Torx Skrewdriver to do the job.
You can find displays for fair price at :
Jan 24, 2009 | Nokia 6070 Cellular Phone
Display light out
Hello, I've had JVC RV-B90 Boombox for few yearst too, but display lighting is ok, There is just small bulb, so take it apart and just change bulg for new one. Good luck !
Jan 17, 2007 | JVC RV-B99GY Cassette Boombox
Nokia 2600 Classic Cell Phone Logo
184 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
