Question about Vtech 5.8GHz Cordless Phone with Digital Answering System
Can call some numbers and get thru some i call it says theres a restriction on the phone not on the phone line
I didnot have to pay to get it fixed
Posted on Nov 17, 2009
How do you unblock an incoming call on my landline
You can't unblock an incoming number that's blocked, but you can call your phone company and see if they have a service that restricts blocked numbers from calling you. The callers would then have to unblock the number to get thru.
Sep 19, 2017 | Lands Phones
How can i see restricted calls made from my phone
  • Look at your phone records at the end of the month. Some cell phone and home phone providers list numbers that are restricted on the phone bill. Simply note the date and time the restricted call came into your phone and look for that date and time on the print out of phone calls made and received on the bill. The actual phone number may be there.
    Have a block put on your phone that notifies callers that you do not accept phone calls from restricted numbers. This will force the individual calling you from a restricted number to unblock his phone number and call you again, if he wants to contact you badly enough.
  • Install a toll-free number to use on your phone. When you have a toll-free number (with most providers) and only give out that number instead of your traditional phone number, you automatically receive the numbers of everyone who calls because you're paying for the calls that come to your phone.
    Jan 04, 2015 | Cell Phones
    How to Change COS (Class of Service) Password
    If you set the all line and set restrictions to no restrictions, you are not restricted from making any calls. I don't think it's the phone system requiring this 4 digit code. Are you sure all your lines are set with the same long distance provider. Did the lines in the dial 8 group require a code. (ie some users had the long distance provider set up their lines to need a code entered to charge calls off to different job codes, so they can distribute the charges correctly).
    You should now be able to call 9+1+area code+number, with no restrictions.
    Mar 25, 2014 | Nortel Norstar M7310 Display Phone
    How to set up restrictions through line restriction filters
    It's best if you use the "reply to post" window below the solution box so you can continue the same thread with the same person.
    To set up the restriction filters we'll need to get into programming.
    Programming is done on 7310, 7324 and 7316 type sets.
    Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
    The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
    At the terminals&sets prompt, press the next key (bottom right arrow).
    The display should now LINES.
    Press the show key (top right arrow)
    The display should now ask for a line number.
    Enter line number you want to change the line filter on. ex. 002 = line 2
    The display should say Trunk/Line data
    Press the next key 2 times (bottom right arrow) .
    The display should say Restrictions.
    The display should say Restriction Filters
    Enter in the restriction filter 25
    The display should say No Restrictions and the ADD soft key should appear on the lower right soft key
    Press the add soft key and in the restrictions you want on the line.ex. 011any will bolck int'l dialing but not long distance. 0any and 1any will block long distance, operator assisted calls, and int'l dialing
    You can also add overrides by pressing the show key (top right arrow) then the next key (bottom right arrow) .The display should say no over rides and the add soft key should appear on the right soft key.
    When finished with the filter press the heading key(top left arrow)
    Press the next key (bottom right arrow) .
    The display should say Line restrictions
    The display should say Normal:none
    Press the change key and enter 25.
    Press the heading key (top left arrow) til the display says Lines.
    Press the back key (bottom left arrow)
    The display should say Terminals&Sets
    Enter in the extension number of the person you want to allow free use of the line.
    Press the next key 4 times(bottom right key)
    Press the next key 2 times(bottom right arrow)
    The display should say Line/Set restrictions
    The display should ask for a line number.
    Enter in the number of the line that was restricted.
    The display should say Normal: none
    Change the filter to 00 (no restrictions)
    That bypasses this extension from line filter 25
    Press the release key when finished
    Dec 23, 2009 | NorStar M7310 Phone
    WHEN A FAX IS TRYING TO COME THRU, IT RINGS, THEN BEEPS AND SAYS "RECEIVE ERROR"
    There may be some static on the phone line, try a line filter. If possible, you could plug the fax into another working telephone line, and have someone send a fax to that number (whatever number is attached to the new phone jack) to isolate whether or not it is the machine, or the wall jack.
    May 20, 2009 | Samsung Office Equipment & Supplies
    Need to block numbers from calling me
    Unfortunately, there is no way to block numbers from calling you. You can change your number or simply don't answer. Sorry! I wish they would make a way!
    If there is a way to make it where only people in your contacts can call you it would be under main> settings> security> restriction, but I doubt it.
    Apr 14, 2009 | Samsung Instinct Cell Phone
    Number Not Provided
    Usually not unless you programmed all of your speed dials with a *67 first. Usually this is set up by you the end user, with the telephone company, having a private/restricted number, or by adding call blocking to your line. If you dial *82 then the phone number of somebody that you have this problem with, the call should go thru. You can have this feature removed by the phone company, however no matter who you call, stores, resturants etc... will have your number for telemarketing purposes.
    Hope this helps.
    Jan 08, 2009 | Lands Phones
    Cannot fax
    Is thi sin an office?
    Are you using a direct outside line or is it an office extension?
    Your office extension may have restrictions on it and you would need to remove those.
    I would confrim the numbers are fax numbers and that that line is ok by:
    • Dialing those fax numbers from a working phone line other than the fax machine
    • Unplug the fax and plug in a regular phone in the same line and see if you can dial out and then try those fax numbers again.
    If the numbers work from a normal phone but not the fax line, then I would check that line for restrictions.
    Dec 12, 2008 | HP OfficeJet 6110 All-In-One InkJet...
    Restrict a mitel superset from dialing 1900 and international calls
    What Mitel system are you using and what are the numbers you want to allow and what extension are we talking about ??
    Jul 22, 2008 | Lands Phones
    Prostar 816 Toll Restriction
    The Station Toll Class of the phone needs to be changed to a Toll Class 5 which allows 911 calls and certain numbers set in MMC # 94. The program to do this is MMC # 30. The problem is when MMC # 30 is accessed it displays the Toll Class for all 16 phones so use caution that you do not change the wrong extension. If you still need help with this problem please repost and I can walk you thru the process.
    Apr 25, 2008 | Samsung Prostar 816 Phone
    Vtech 5.8GHz Cordless Phone with Digital Answering System Logo
    20 people viewed this question
    Top Vtech Lands Phones Experts
    David Burbee
    David Burbee
    Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
