Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Hot water on cold washes
My Whirlpool ultimate care 2 top loader washer is running hot water when its on a cold wash. The first fill is always cold then the rinse etc after is hot. when dial is on COLD wash???? Pipes are correct at rear??? Help
  • giselle_foxa Nov 16, 2009
    Yes they are on the correct way. The machine was recently moved to a different room & has done this seince. The initial fill is cold on the cold wash & then the rinse cycle comes in hot which is more confusing!
  • Doug Connell May 11, 2010
    are your hoses hooked up right
  • 715 Answers
Check plumbing in house to make sure that the hot is on the left and cold or the right
Posted on Nov 16, 2009
  • 26 Answers
To solve this problem simply reverse the water hoses from the way that they are set up currently. Then do a test again to make sure that when you select HOT you are getting HOT.
Does not take water ,hot or cold
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Jun 16, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
On rinse cycle...cannot control water temperature...set it for warm but still feels cold to touch. wash cycle is ok. model is whirlpool gold ultimate care II..top loader.
Is the hot water turned on. Remove hose from washer and check screen in water inlet. If it is clear you may need a new water inlet valve.
Apr 01, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool auto load not filling with water to wash, but will go to rinse cycle
There are 2 inlet valves 1 for hot water and 1 for cold. Sounds like your hot water valve is either faulty or the hot water valve to it is off. The machine normally fills with hot water as it doesn't have a heating element to heat the water and fills with the cold water to rinse
Feb 24, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer does not fill with hot water
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
heatman101
Feb 03, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing machine
If it is a hot and cold fill m/c, then you can just use it from cold water.
You would need to fit what is called a Y piece connector , this supplys water to both hot and cold valves regardless of what prog you select..
You connect the cold supply to the straight leg of the connector, and the hot and cold to the other 2 connections.
Plz rate this solution.
Thanks.
Dec 28, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Top Loader Washing Machine - Model 3RLSQ8033RW2
it may be a bad water valve or just a clogged screen. take off the cold water connection from the back of the washer and clean out the screen you see inside the plastic piece the hose fits on. do not take it out, clean it while it is still inside.
Aug 09, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
WASHER WON`T FILL FULLY WITHOUT RE OPENING TOPLID SEVERAL TIMES?
water valve should be a single unit consisting of a hot and cold solinoid assembly. This whole valve assembly should be replaced.
Jul 20, 2008 | Washing Machines
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
167 people viewed this question
Dan Webster
Dan Webster
Sal De
