Question about Oregon Scientific Electric PTO Clutch for Exmark and Warner
How do i wire a toggle switch tomy electric clutch orignal switch doesn't work.
    President:
  • 1,627 Answers
Ther are two wires,one power one ground.The ground wire should be grounded already[confirm with an ohm meter.You need to put a power sorce to the switch and one from it to the pto this will make it work but will make all the safety switches in-operable so it is not a safe thing to do.Your best bet is to replace the swich or the safety switch that is keeping it from working[seat switch or brake switch usually].
Posted on Nov 19, 2009
I have a 95 blazerr, the blower motor stopped working, ive put in two toggle switch but they both quit working
A toggle switch will only work on a fresh cable, which is wired directly to the alternator or the battery. If you put a toggle switch on the existing electric fan wire, you will not be able to turn it on as long as the engine management does not send you current.
Jan 13, 2018 | Chevrolet Blazer Cars & Trucks
94ford probe won't start
Well Sandra , the thing to do would be to get it to turn the engine over with the key , Then diagnose the no start problem . Look at a wiring diagram (do you know what that is ?) When you turn the key to start , the electrical part of the ignition switch sends B+ voltage to the starter interrupter relay through the clutch switch to the starter motor solenoid . Testing the electrical circuit with a DVOM - digital volt ohm meter with the help of a wiring diagram ,so you know where to test is the proper way to diagnose the problem . Not guessing ,an rigging the stuff . You can find free wiring diagrams here http://www.bbbind.com/free_tsb.html
Enter vehicle info. year , make , model an engine ! Under system click on engine ,then under subsystem click starting . Click the search button then the third blue link .
Electric Testing Techniques You Need to Know
Do you know what a relay is ?
VEHICLE RELAYS Testing from the relay base
VEHICLE RELAYS Operation Diagnosis
If you look at the wiring diagram you will see the relay is controlled by the CPU - engine computer .
How to voltage drop test starter motor circuit
Jun 29, 2017 | Cars & Trucks
Have a 97 honda. Just purchased. It has a toggle switch installed that works with original key ignition. That said... toggle controls whole electrical..everything works..except tail lights,and the dash...
So If I understand, you turn on toggle and then use key to engage starter? Do brake lights and turn lights work, just not the running lights? Or are all tail lights dead. If none work, juice is not getting to the headlamp switch. Best fix would be to replace the probably bad ignition switch and repair wiring back to original, but quick fix would be to run a second wire from toggle switched side to the headlamp switch +
Dec 18, 2014 | Cars & Trucks
Working on a cub cadet zero turn electric pto to blades, pto won't engage when pulling switch, can't find out why can get it to run jumping straight to battery if I put a toggle on this set up is...
go to partstree.com and they should have wiring diagrams for your mower, should be a switch or something if the clutch works when you hook it to a battery (seat switch, pto switch, parking brake switch, even the neutral safety switches) also check your ground hook ups
Apr 27, 2013 | Garden
Passengers side electric window doesn't raise when toggle is pressed on main panel
if passenger window switch work passenger side window and driver side master switch dont. master switch either locked out or master driver window switch is bad.
Oct 25, 2012 | 2002 Jeep Liberty
1999 Ford Escort ZX2 won't start
It's called the clutch start switch. Yes, it could be bad or needs adjustment.
Push the clutch in and the switch closes contact, so power flows from the ignition switch start position to the clutch switch and on to the starter motor-well, actually to the starter solenoid on the starter motor. If you have a voltmeter or test light, you can test the clutch switch . A red and white wire to it and a red wire from the switch to the starter solenoid. When this wire gets to the solenoid, it is a black wire with red stripe. It should have voltage when key is held in start position and the clutch pedal is depressed.
Feb 23, 2018 | Ford Escort Cars & Trucks
Schematics for cjb100pd
Red is your positive, black is negative, both brown wires are to the speaker, and the yellow and green wire are for any emergency strobe lights you may want to hook up to it. P.S. if you wire up the brown wires and siren doesn't work make sure volume is turned up and try it again if it doesn't work then switch the brown wires around. Both toggle switches on the far right is to only turn the lights on. not the siren. Make sure the siren nob is turned all the way left thats off. The rest of the are just siren modes. The toggle switch all the way to the left. Push down horn comes on release it then horn goes off. Push up siren comes on for like 7-10 seconds and the goes off. Horn and your microphone always override any siren that may be on.
Mar 12, 2012 | Cars & Trucks
Garden Trctor Model 917.273023 . Key switch broke, wore out. replaced it. started up great, tried to mow and the electric clutch would not engage, checked out wireing restarted engine. and engaged...
Bill, not sure, but, the engine will not crank with the clutch engaged, I don't know what happened, but sounds like the clutch switch went out and took the mower with it. Take the wires apart between the ignition and the clutch and hot wire them to see if the clutch jumps. If it is working, then make sure it is off, or disconnected and try to start it, then take it from there, if it starts, you know it is the switch. If it doesn't start, then you can go look at other safety switches. make sure it is neutral, mower off, driver in seat, clutch in, etc, Hope this helps.
Jun 29, 2011 | Craftsman Garden
Mower will not engage when switch for electric electric clutch is pulled up into on position
could be safety switches faulty or sticking,usally 1 under seat, and 1 by the catcher, pto toggle switch maybe faulty, if battery is low there won't be enough power for the clutch to engage. I would jump the clutch to make sure that hasn't died first cause that is the costly part.
Jan 24, 2011 | John Deere 195HP Hydrostatic 42" Cut...
Have a 23hp craftsman garden tractor with kohler engine no wiring
on most starter switches the back of the switch is labeled which wire goes to what
Apr 04, 2017 | Craftsman 24 Hp 48" Deck Yard Tractor
Oregon Scientific Electric PTO Clutch for Exmark and Warner Logo
460 people viewed this question
Top Oregon Scientific Garden Experts
Dennis Key
Dennis Key
Colin Stickland
Colin Stickland
roeb
Are you an Oregon Scientific Garden Expert? Answer questions, earn points and help others
