Question about Apollo Boone PA5400 Professional Microphone
Battery My battery no longer charges??? can I replace it, if so, how do I remove it??
First, the battery is a Lenmar PBA50 found on ebay.
Second, place the amplifer onyour lap with the battery cover off and tap it on your leg, the battery should slide out the back.
Third. I have 2 of these amplifiers and both would not charge or play on battery. The problem is the metal spring contacts the make contact on the battery, they get out of shape and fail. I bent them around until I was able to make the work, but do not like that solution. Beside the left in of the battery is a small "pocket" if you will. I opened up the amplifier (BECAREFUL the handle come loose and there are nylon washers on each side total of 4 that will do what ever they can to escape.) With the amp opened I located the 2 wires going to the metal battery contacts and cut them off and removed the contacts. I then drilled a hole into the small "pocket" and routed the wires down thru the hole. I remove the battery and carefully soldered a wire on each battery contact. I then put a et of connectors on the wire end making sure I kept the polarities correct and plugged the into each other. I now have very good battry connection and all works well.
Posted on Jan 19, 2009
Does the battery in the Philips Lumea Precision SC2002 IPL hair Remover need replacing? I've had it nearly two years and it will no longer charge. thanks
Here is a guide how to replace the faulty battery pack yourself. It's a known problem that the batteries are dead if you don't charge the Lumea for more than 3 months.
Replacing battery in Philips Lumea LazyAdmin
Mar 02, 2015 | Philips Health & Beauty
Should I Remove the Laptop Battery?
Question: Should I Remove the Laptop Battery?
I have a dell latitude d820 laptop at home which I use as a desktop replacement. As such, 99% of the time the laptop is being used it is plugged in. I wonder if I should remove the dell latitude d820 battery so that it is not permanently being charged, or does the laptop cut off the current to the battery once it is fully charged? I do unplug the laptop when I turn it off.
Answer: When using a laptop as a desktop replacement the battery should not be left in for long periods of time. The laptop will over time discharge the battery. Remove the battery – making sure that it is charged to 40% and store it in a dry, warm place. Ensure that it is wrapped protectively and nothing will be dropped on it.
The battery should be re-installed every 3-4 weeks and allowed to fully discharge. Leaving a battery in storage for longer than this without using could cause the battery to fully discharge as the circuitry of the battery itself consumes power.
Leaving a battery in a laptop while using an electrical outlet for long periods of time will keep the battery in a constant state of charging up and that will reduce the life cycle of the battery.
Remember that when you have removed the dell vostro 1500 battery from a laptop while using with an electrical outlet – the automatic battery backup is no longer functional. Make sure to plug your laptop into an uninterrupted power source (UPS) not directly into an outlet or surge protector.
on Apr 20, 2010 | Computers & Internet
Light flashes fast on dewalt 0245
I believe the battery can no longer be charged.
Aug 31, 2014 | Drills
2004 dodge neon will not turn over
have you replaced the battery? the car draws it's electricity from the battery, then the alternator replaces the charge to the battery. if the battery is shot and will no longer hold a charge the car will not stay running once you remove the charge as in removing the jumper cables
Jul 14, 2012 | 2004 Dodge Neon
The battery quickly charge and discharge. And when the battery discharge and I connect the power adaptor to 220 volts power source, the laptop automatically shutdown and could not open unless the battery...
Do you live in Europe> Typically power supply should only be 110 - 115V
Battery is simply no good any longer. If you can get 2 yrs from a battery you're doing good.
Try removing the battery and using the power supply and charging battery when not in use. Replace battery.
Hope this helps
Jan 07, 2011 | Computers & Internet
Suspect the charger is shot on a seldom used like new Companion II. The batteries are at 3 volts but the charger red light wont illuminate when plugged in. Green light comes on, but not the red. I did see...
MStrong The charger will not charge batteries that are reading that low Replace the batteries and try the charger again. Remember to always charge before use and never charge longer than 12-16 hours. Get into the habit of charging overnite on scooters used everyday and once a week on seldomly used scooters always sore the scooter fully charged and if storing for a longer time remove the batteries and store fully charged. ope this helps you
Oct 03, 2010 | Golden Technologies Companion II Travel...
I think my battery is dead. Do I try to charge it
To charge battery, use a trickle charger at 2 amp. Batteries usually only last about 3 years, so if battery is at that age it probably needs replaced. (Replaced my battery with a lawn mower battery that matched the original battery size.) I would try to get a charge on the battery before replacing it. Replacing the battery could be expensive. Battery could also be low on zinc, water, or acid.
May 22, 2010 | 2004 Yamaha V Star Custom
change the phone memory
Apr 02, 2010 | LG Vu CU920 Cellular Phone
Battery charge indicator seems faulty.
Solved own problem. Bad conection between pcb and battery contact pins. Reheat each battery pin on the pcb carefully until solder reflow occurs then remove heat. PDA now repaired
Aug 03, 2008 | Fujitsu Pocket Loox 410 Pocket PC
Razor battrey
Did the phone show it was charging on the display? Was the charger firmly connected to the phone? The batteries will go bad after a period of time of recharge cycles. I have bought replacement batteries for my RAZR on eBay. Remove the battery and do a search on eBay for a NEW battery from a dealer using the battery P/N on the battery. I found a higher capacity battery for mine that lasts even longer on a charge than the original one that came with my RAZR. You can do a search on eBay for "RAZR battery". Look at the mAH rating on your battey, Try finding a replacement with the same or higher rating than your original. The higher the mAH rating, the longer it will last between recharge cycles.
- Jim
Jul 08, 2008 | Motorola Mobility RAZR V3
Apollo Boone PA5400 Professional Microphone Logo
201 people viewed this question
Top Apollo Boone Audio Players & Recorders Experts
Are you an Apollo Boone Audio Player and Recorder Expert? Answer questions, earn points and help others
