Question about Dell Dimension 9200 PC Desktop
I'm having serious issues with my Dell Dimension 9200 desktop. I left my computer on overnight and during the night I had a 5 minute power failure. Now when I try to turn the computer on, it does not boot up at all. It does turn on, and on the turn the number 1 and 2 stay on the entire time.. But the computer does not load anything! What happened? Is there anything I could do?
    President:
  • 414 Answers
Though itz not known to me if u r using an ups or invertor or cvt..
is any light blinks up..??..esp. on the monitor or set dead..
DO IT ONLY IF U R A PROFESSIONAL..
however..plz do check the following as in order:..
the Hardware part:..
1) check mains/power supply..the fuse, switch, wiring n associated circuitry..
2) [in case of desktop] the smps itself may b defective/faulty..check the outputs of smps viz. 0v (black~ground); +12v(yellow); +5v (red, green~ps-on, violet~pg& grey~sb); -12v (blue);-5v(white); +3.3v(orange)..
check the battery n adapter [main power], in case of laptops..
replace with a standby n see..
3) unplug mains supply..pick open/remove the cmos battery..check (above +3v)..resit..
4) open the cpu n see if heat is generated..if not..replace the cpu n see..
5) open the CPU Heat-Sink with fan out of the socket..put some "Heat Sink Compound" (available in local electronics chip level spare market)between the cpu/processor and the CPU Heat Sink *** fan..resit/fit it tightly in position..
6) on main/mother board..see with a debug card for mb error..may b short..look for defective capacitors(espabove1000mfd)/mosfets..go through the mb's south bridge n the circuit lie around atx connector..the crystal clock generator (if cpu isn't heating up)..
7)see if the ram(s) is loose/faulty..open clean/remove carbon & or oxide formed on the teeth with an eraser n resit it..or replace with a standby n see..
8)remove/clean dust neatly..dust is non-uniform in nature n may cause jam/short circuitry/excess resistance n many more..resulting an increase in heat..
plz give priority to steps(2, 4 & 6)..
if u r not a professional, always better to seek advise from ur system admin/vendor....
Posted on Nov 16, 2009
How can I jump the power switch?
Solid Amber Light on Dimension 4500 - Power supply is suspect ...
en.community.dell.com/support-forums/desktop/f/.../t/18332108?...
Dell
Feb 12, 2007 - 14 posts - ‎4 authors
I have a Dimension 4500 that is obviously a few years old. ... So when I push thepower button "on" now, the light is a constant ... I pulled of the 20-prong conection (to the motherboard) and jumped ... The fan itself can be replaced, if you're good at mechanical projects. .... And the computer started right up. Boot Up Problem With Dell Dimension 4500 - General ...
Sep 5, 2012
Dell Dimension 4500 won't power up - General ...
Oct 24, 2006
Dimension 4600 - Bad Power Supply or Power switch ...
Mar 27, 2006
On/Off butotn failure.. Please Help - Community
Mar 8, 2006
More results from en.community.dell.com
Dell desktop won't start with power button - Forums - CNET
www.cnet.com > Forums > Desktops
CNETAug 5, 2009 - My dell dimension 4500 was accidentally turned off at the power strip and ... There is a light behind the button but no lights on back of computer. ... I have a Dimension 2400 that I'm not using--could I try that power supply in it?
Dell Dimension 4600 won't power up {Resolved} - Virtual Dr
Feb 03, 2016 | Dell Dimension 4500 PC Desktop
Dell Dimension 9200 does not boot.
remove ram and listen beep codes from the system ......still no beeps from the system .....the problem with motherboard only
Oct 15, 2012 | Dell Dimension 9200 PC Desktop
I have a Dell Dimenstion E521 with Windows 7 Ultimate 64-bit, that powered itself off last night, booted up fine the first time. Then it powered itself off again within 5 minutes and just kept powering...
There is a setting in BIOS that determines what to do when when the computer receives power after a power failure. There was a time when this was set as power on; computer would power on automatically computer receives power after a power failure. I think this answers your first question.
In Windows you have a setting to 'Automatically restart' when the computer encounters a hardware/software problem. When unattended, the computer can turn on and turn off by itself repeatedly if there is a problem.
The repeated on-off can lead to more errors. If the problem is with the hard disk, it is likely to get damaged further, where finally you cannot go beyond the BIOS settings. In a Dell machine, F2 should be pressed to enter the BIOS setup.
Do not hesitate if you need further help.
Sep 14, 2011 | Dell Dimension E521 PC Desktop
Dell dimension 9200 pc put herself in power save
You just need to go into power options and disable the sleep and hibernate function
Jun 09, 2011 | Dell Dimension 9200 PC Desktop
My dell dimension desktop does not come on. all i am getting is the monitor in power save mode, and the computer fan is running.This has occurred after my electricity supply was lost and came back on. I...
you can try checking if there's a HDD led activity but as per what you have said, this is either caused by a power supply or mainboard failure. Sometimes, surge strips cannot guarantee that it will protect your computer from unstable current caused by on and off of the electricity.
Aug 07, 2010 | Dell Dimension 9200 PC Desktop
Dell Dimension 9200 beeps on startup, with nothing...
A beep code of 3-3-4= Video Memory(RAM) Test Failure that would explain why you get nothing on your screen the first thing you would need to do is disconnect your monitor and try it on another computer. if it works fine then the problem is your video card. If that the case and the video card is intergrated with the motherboard, you will need to repalce the motherboard --- Sorry-- Please vote me a 10 when this works
May 20, 2010 | Dell Dimension 9200 PC Desktop
My cd/dvd tray will not stay closed on my Dell Dimension desktop computer
You can go to the BIOS page of the system by pressing F2 as soon as the Dell Logo comes up.
There is an option for you to load the system to its defaut settings.
Note: Don't forget to set your diskette drive to disabled or off before saving the settings or else the system will always prompt you a diskett drive seek failure message.
May 10, 2010 | Dell Dimension 9200 PC Desktop
My Dell 9200 won't start up (boot) after 7 months non use
No offense, but you need to plug it in to turn it on.
Jun 18, 2009 | Dell Dimension 9200 PC Desktop
Dell Dimension 9200 "system does not support installed processor
This is really hard to say. Maybe he messed around in the BIOS settings and tried to overclock your processor. First thing I would do is to go into the BIOS (press F2 during startup) and check every setting. You can also reset it to default and see if that makes a difference.
Another possibility is that there is an issue with the RAM. Did you (or he) install new RAM? Look here to find a list of possible issues.
Check Dell's support page, to see if you can upgrade your BIOS.
Check your Device Manager (click Windowskey+R, type devmgmt.msc) for any unusual entries.
That's all I can think of right now. But please come back and post your findings (even if everything looks ok), so we can look into other places.
Apr 13, 2009 | Dell Dimension 9200 PC Desktop
Dell Dimension 9200 PC Desktop Logo
250 people viewed this question
Alun Cox
