Question about Whirlpool Dryers
My gas dryer is not heating up I checked to see if any flames is on when its running but its not coming on the timer is turning.what needs to change
  • 26 Answers
All gas dryers have a gas module. The older models (very old) have a pilot light and the new ones have what is called a GLOW PLUG and it is made out of ceramic. If this glow plug is in any way broken, you will not have any heat. The GLOW PLUG is what comes on when you first turn the dryer on and it GLOWS until the gas module actually spits out a small amount of gas and an internal combustion occurs and the flames come on full power and this is what dries your clothes. If the GLOW PLUG is fine, then the gas module could be bad. ALSO, Always check for burnt wires and check any thermostats or fuses internally in the unit.
Posted on Nov 16, 2009
My whirlpool dryer comes on and runs good but it wont get hot can you tell me whats the problem
Hello there and welcome to fixya there are several things that could make this dryer not heat up
Here are the most common things
Thermal Fuse
If the dryer doesn\'t heat, but the drum
turns, check the thermal fuse(s). The thermal fuse protects the dryer
from overheating and helps to prevent fires. If the thermal fuse is
blown, it will have to be replaced.
Enter your model number to see parts for your dryer.
Help me find my model number
Gas Valve Solenoid
The gas valve has two or more electric
solenoids which open the valve to let the gas flow into the burner
assembly. If the dryer doesn\'t heat one or more of the solenoids may be
defective. If the igniter glows for 90 seconds but the burner flame
doesn\'t light, replace these coils as a set.
Dryer Igniter
If the dryer doesn\'t heat, the igniter might
be burned out. Check the igniter for continuity with an ohm meter. Dryer
igniters burn out over time, similar to a light bulb.
Heating Element
The heating element on an electric dryer can
burn out over time. If the dryer doesn\'t heat, the element should be
checked for continuity. The heating element cannot be repaired and must
be replaced if defective.
Heating Element Assembly
the heating element assembly on an electric
dryer can burn out over time. If the dryer doesn\'t heat, the element
assembly should be checked for continuity. The heating element assembly
cannot be repaired and must be replaced if defective.
Flame Sensor
Gas dryers have a flame sensor to detect the
heat given off by the flame. If the dryer doesn\'t heat, the flame sensor
might be defective. Check the flame sensor for continuity. This is not
as common as a burned out igniter or thermal fuse.
High Limit Thermostat
Although not common, if the dryer doesn\'t
heat the high limit thermostat can be defective. It can be checked for
continuity. If the thermostat is "open" the dryer doesn\'t heat.
Cycling Thermostat
The cycling thermostat regulates the
temperature of the air in the dryer. If the dryer doesn\'t heat it may be
caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at
fault when the dryer doesn\'t heat. Check all of the other components in
this troubleshooting guide before replacing the main control board. The
main control board cannot be tested easily and must be replaced if it is
defective.
Timer
The timer is normally not at fault if the
dryer doesn\'t heat. In many situations where timers are replaced they
end up being returned. Check all of the more common components in this
troubleshooting guide before replacing the timer
Oct 14, 2013 | Dryers
Maytag DG410 gas dryer-no flame, no heat. I replaced the ignitor - that apparently isn't the problem. Other ideas?
Motor runs, but main burner will not ignite
1.heat switch set wrong---correct switch setting
2.defective timer or timer circuit---check timer wiring--replace timer motor or switch as needed
3.defective centrifugal switch in motor---clean switch or replace as needed
4.gas supply valve closed----open gas valve
5.inoperative solenoid coil---test coil for open circuit & the voltage to it
Pilot burner goes out
1.insufficient gas supply---- low gas pressure or clogged pilot filter or partially closed gas valve
2.carbon deposit on thermocouple tube---clean tube & check pilot burner for proper combustion
3.improperly adjusted pilot flame--adjust pilot flame until faint yellow tip begins to appear
4.faulty ignition or reset valve or thermocouple---replace
Clothes not drying, but dryer runs & heats
1.defective operating thermostat---test thermostat, replace if defective
2.fan or it's pulley loose on shaft---tighten set screw
3.incorrect heat or timer settings---reset timer
4.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
5.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 22, 2011 | Maytag PYG4500A Gas Dryer
I have an Amana Designer Series Gas Dryer. It worked fine for more than 10 years. Suddenly, yesterday it still ran, but there was no heat. I opened the bottom panel while it was running, and...
Sep 22, 2011 | Amana ALG331RAW Gas Dryer
Dryer is running, but heat will not turn on
There are several things that can prevent a dryer from not heating.. Unplug Power Before checking.
Electric Models
1- Power- Your dryer runs on 220volts. 110 runs the entire dryer and 110 runs just the element. Your breaker may have half tripped. Check to see if you are getting the correct amount of power by using a ohm meter. Also check the power cord for burn marks on the plugin and the cord itself.
2- The thermal fuse can prevent this from heating. The thermal fuse is a sensor on the blower housing the measures the temperature of the air. There is a cycling thermistat near the thermal fuse. If the dryer temp gets over 190-220 degrees the thermal fuse will blow to cut power to the element to prevent fire. You can test this by using a continuity tester.
3- High limit and/or thermal cutoff. These are both sensors on the heating element housing. Thermal cutoff is at the top and the high limit is near the bottom above the heating element connectors. Test these with a continuity tester.
4- Heating element- Just below the high limit on the heater housing. Test for continuity.
5- Motor- The motor has to reach a certain rpm to activate a sinfrigrial switch inside the motor. If the rpm is not reached it will not allow current to go to the element.
6- Timer- Make sure you are trying this on timed dry. Sometimes people use air fluff and forget to change it back. The timer could also not be sending current to the heater.
Gas models
1- Electric ignitor- Inside the flame tunnel inside of dryer near where gas line hooks up. Usually if it glows than it is still good but check to see if it is sending and amp signal to the heat coils.
2- Heater coils are two valves that open up when the ignitor send signal saying the ignitor can ignite the gas. Heat coils will not open to send gas if it does not receive a signal from the ignotor. They look like two round disk with two wires running from ignitor.
3- Flame sensor- Change if you change the heater coils. The flame sensor could not be detecting the flame inside so it shuts down the ignitor.
4- Motor- See above
5- Timer See above
If you have any further questions or need further assistance please feel free to comment me back.
Jul 27, 2011 | Kenmore Dryers
Hi, have a kenmore gas dryer, flame comes on about
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 17, 2010 | Dryers
Dryer will not turn off is it the timer? the dial does not move
do you have heat?when the dryer heats up the timer doesn't move,when the heat shuts off the timer moves,when the heat comes back on the timer stops,the timer will not move if there's no heat.if you have heat it could be the timer.also run the dryer when it's cold for 15 to 30 minutes and check to see if the flame is still liting,there's a little cover on the front panel that you can pop off to see the flame,there's a set of gas coils on top of the gas valve that when they fail they will stop working when they heat up,when the coils cool down they will let the gas through and the flame will lite again,common problem with gas dryers and most likely your problem.also when was the last time you cleaned out the dryer,you need to blow out the vent line if it's a long run from the back of dryer to the outside i use a leaf blower to blow out the line,make sure the outside vent is clear so the air can blow through,next you need to clean out the duct that the lint filter slides into and vac out the inside of dryer where the motor is,you should do this once a year moreso with gas so you don't have a fire,also your clothes will dry on time and you'll have less problems with the dryer.let me know what you find.
Apr 18, 2010 | Kenmore 73952 Gas Dryer
Whirlpool gas dryer Model #WGD5530SQ0 not heating properly
If your dryer heats when you first turn it on and after a few minutes it does'nt. check the ignitor to see if it is glowing. It should glow bright then you will hear a click and the burner will light. If the ignitor glows bright but you hear a click but no flame and if you watch this for several minutes and this process continues of glow then glow goes out no flame, then you have a bad burner coil. There are 2 black solenoids sitting on top of gas valve. One of them is shorting out after it warms up. Replace both solenoids. You can usually get them as a kit from parts store.
Feb 04, 2010 | Dryers
No Heat
Hello
Welcome to Fixya
Remove the vent line from the rear and try the dryer.
If it heats then that means there is a clog or kink in the vent line blocking the vent air from exiting which will stop the dryer from getting hot!
If not then it's another one of these problems.
Defective Ignitor (Gas Only)
When heated the ignitor used on your gas dryer must obtain a specific high temperature
in order to activate the flame sensor. This ignitor is fragile and susceptible to cracking.
A hairline fracture that is barely visible to the naked eye is enough to change
the resistance of the ignitor to a point that is will not work properly.
You can test the resistance of your ignitor. You should get a reading of 50-400 ohms of
resistance.
If the ignitor gets hot and then goes off after about 10-15 seconds and there is
no ignition, the problem is probably not the ignitor. It is most likely the gas valve
coils that are defective.
If the ignitor comes on and stays on, it is the flame sensor that is defective.
If the ignitor is not getting hot it could also be one of the thermostats that is defective.
The power for the ignitor is passed from the timer, through all of the thermostats,
limit switches and fuses to the ignitor. So if you are not getting power to the ignitor
during ignition, you should check the continuity of the individual thermostats and fuses.
DRYER DOES NOT HEAT
Defective Gas Valve Coil (Gas Dryer Only)
If the gas dryer will light once but will not relight until it cools down, it is likely the gas valve coils are faulty. These coils loose some strength when subjected to heat. When they become old, the addition of heat may be enough to prevent them from opening the gas valve when hot. However the coils still work when when cool.
An easy way to diagnose the coils when the burner is not lighting, watch the ignitor. If the the ignitor glows for 10 to 15 seconds but no flame is created, then the coils are faulty. If the ignitor is not glowing the problem is elsewhere.
Recent Customer Symptoms:
The dryer burner doesn't always come on when starting. If the burner does come on, once it goes off if won't come on again until the dryer cools down.
Defective Flame Sensor (Gas Dryer Only)
The flame sensor's job is to monitor the ignitor for sufficient heat
to ignite the gas. A properly operating flame sensor will pass a
continuity check under room temperature.
Common Symptoms
If the flame sensor is defective in the open position,
the ignitor will not get hot when the dryer is started.
However, if it is defective in the closed position the ignitor
will get hot, but the flame sensor will not allow the flame to ignite.
In this case, the ignitor will usually stay hot for a long period of
time.
Defective Thermostat
The thermostats are responsible for maintaining the proper temperature
in the dryer. Check the exhaust temperature of the dyer and if the
temperature is above 150 degrees, you will most likely need to change
the operating thermostat.
The thermostat can also fail in the opposite mode.
It can prevent the element from heating at all.
A failed continuity check at room temperature will verify this condition.
There are some special thermostats that are single pole double throw.
These thermostats are often used to control the timer when set to the
Automatic Dry cycle. If the dryer timer will advance in the Timed Dry
cycle but not the Automatic Dry cycle, then the thermostat could be the
problem.
Defective Thermal Fuse
The thermal fuse is in series with one leg of power to the motor.
If the fuse is open (no continuity) the motor will not run.
The thermal fuse is located in different locations according
to the model and brand of dryer.
Solution:
Check the thermal fuse for continuity with a volt/ohm meter.
If it is open, it will need to be replaced
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Jan 25, 2009 | Kenmore 73952 Gas Dryer
Whirlpool Gas Dryer, LGR5636EQ2, timer not moving on Auto (DryMis
If that is a 3 wire gas assembly then the timer is screwed.The orange wire when removed from the mix will make the thing advance. The trouble is in the timer. If that is a 2 wire gas operator you need to change the high limit and open up the outside vent. My opinion.
Nov 14, 2008 | Whirlpool GGQ8831L Gas Dryer
Roper gas dryer works intermittently!
suspect coils on gas valve if ignitor glows timer is working
Jun 30, 2008 | Roper REX3614KW Electric Dryer
Dryers Logo
102 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
