Question about Dell Precision M90 Notebook
When powering up the system the power light comes on the HDD led comes on and then the system shuts off, tested battery, reseated RAM and tested using a known good HD. N/C
    President:
  • 414 Answers
Humm..if itz not the battery or hdd..i guess itz probably the system board..this is a typical insufficient Wattage/Oscillation/Frquency generation problem, in most of the cases..
DO IT ONLY IF U R A PROFESSIONAL..
however..plz do check the following as in order:..
the Hardware part:..
1) check mains/power supply..the fuse, switch, wiring n associated circuitry..
2) [in case of desktop] the smps itself may b defective/faulty..check the outputs of smps viz. 0v (black~ground); +12v(yellow); +5v (red, green~ps-on, violet~pg& grey~sb); -12v (blue);-5v(white); +3.3v(orange)..
retest the battery n adapter [main power], in case of laptops..
replace with a standby n see..
3) unplug mains supply..pick open/remove the cmos battery..check (above +3v)..resit..
4) open the cpu n see if heat is generated..if not..replace the cpu n see..
5) open the CPU Heat-Sink with fan out of the socket..put some "Heat Sink Compound" (available in local electronics chip level spare market)between the cpu/processor and the CPU Heat Sink *** fan..resit/fit it tightly in position..
6) on main/mother board..see with a debug card for mb error..may b short..look for defective capacitors(esp above1000mfd)/mosfets..go through the mb's south bridge n the circuit lie around atx connector..the crystal clock generator (if cpu isn't heating up)..
7)see if the ram(s) is loose/faulty..open clean/remove carbon & or oxide formed on the teeth with an eraser n resit it..or replace with a standby n see..
8)remove/clean dust neatly..dust is non-uniform in nature n may cause jam/short circuitry/excess resistance n many more..resulting an increase in heat..
plz give priority to steps(2, 4 & 6)..
if u r not a professional, always better to seek advise from ur system admin/vendor....
Posted on Nov 16, 2009
My acer aspire 5742 while pushing power button,the only thing it does is the blue light on and the cooler and nothing else... please heeeelp...
Does the battery charge light come on? Does the HDD LED blink? You get nothing on the screen at boot? Remove and test the HDD, reseat the Memory Mods. Have you tried a system restore/recovery?
Feb 20, 2013 | Computers & Internet
Acer Aspire 7000. Power light comes on and stays on. HDD light flicks twice then goes out. No noise or screen change. All dead. Think I may have hibernated it last shut down. Removed power supply and...
If the laptop is in hibernated mode, if and when it comes on, go into power options select hibernate and uncheck box to the left to disable this feature and click apply.
Jun 03, 2012 | Acer Computers & Internet
Toshiba l355d - s7815 won't boot and screen doesn't light up
From your description you have a motherboard issue, the only way to rectify this, it must be replaced.
Mar 26, 2012 | Computers & Internet
I press the power button on my Dell Vostro 1500 and the HDD runs and the num lock light stays on and the scroll lock and caps lock flash and the DVD drive light stays on then the thing just shuts itself...
There are 9 states for LED error codes on this model. The error you're describing indicates that the laptop does not detect any RAM (memory sticks). Since you tried to isolate bad memory stick it looks like your motherboard has a problem and needs to be replaced.
Jul 28, 2011 | Dell Vostro 1500 Notebook
I just received and installed a motherboard for my b130 laptop. The battery charging led is on (Green). When i push the power button, The power led comes on and the caps lock light blinks for 10sec. then...
The RAM may need reseating or the RAM module/s may be faulty.
If the notebook has two RAM modules installed, remove them and insert one RAM module then see if the computer boots up, then repeat with the other RAM module.
Try and use RAM modules with the same make ans size.
May 08, 2011 | Dell Inspiron B130 Notebook
Laptop starts to turn on but then shuts down, then repeats over
do the hdd and ram reseat and update the bios from hp.com.I am sure it'll fix the issue or else run the hdd test from f10 bios
Sep 29, 2009 | HP Pavilion dv6000z Notebook
LED on abit ST6
every motherboard should have a led light always on to indicate that there if power in it. the problem with system rebooting has to do with the ram or processor, since you said it does not recognize the hdd at times that means that the ram is working abnormally i.e it is week, u know ram means random access memory, so change the ram and make sure u get the right ram for your system
Jul 11, 2009 | Abit ST6 Motherboard
Hi my laptop wouldn't start up so I bought a new battery and it still wont start up. I can get the power light and the battery light so I don't think it's the power cord I can pull out battery adn unplucg...
Reseat the RAM.
Sometimes the RAM needs reseating because the RAM module/s are not making proper electrical contact with the motherboard.
If this doesn't work then :-
The RAM module/s could be faulty, if you have two RAM modules, remove the both modules and insert one at a time and bootup you computer to test them to determine the faulty RAM module.
Feb 19, 2009 | Toshiba Tecra 8100 Notebook
HP DV6000 Notebook - Dead/No Post
All I know is wife's did the same and they replaced the board, not repaired it.Hers was out of warranty and they fixed it free
Feb 10, 2009 | HP Pavilion dv6119us Notebook
Open Questions:
See all Dell Precision M90 Notebook Questions
Dell Precision M90 Notebook Logo
464 people viewed this question
Alun Cox
