Question about InFocus LP120 / 1000 Lumens / XGA / DLP Projector Refurbished Multimedia Projector
Infocus 120 No view when hooked up to the computer
  • 2,239 Answers
Swap the cables, toggle the f4 on the computer, and reset the settings to factory default to make sure the resolution matches.
Posted on Dec 29, 2009
6ya staff
SOURCE:
Infocus lp770, trying to hook up to apple computer using the usb port? will this connection work to run the 770?
Hi!
You need to hook it up using VGA or HDMI for it to transmit information from your Apple computer to projector. You can check the Ports available at the back of your projector and you can Purchase cable needed from either Apple or Infocus or any computer store.
Hope this helps.
Sep 05, 2011 | InFocus LP 770 Multimedia Projector
Infocus LP 120 will not power when plugged in.
If the lamp door is not properly secure, the projector will not power up. If you are sure the door is secure then the likely culprit is a bad power supply or main board. Either will need to be repaired at a service center.
Oct 26, 2010 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Infocus 540 has a blue tint to it.
if it only has a blue tint when the computer or video is hooked up, reset the settings to factory default and replace the cables. if the splash screen (when it says "infocus") has the blue tint, one of the light filters are fried due to excessive heat and dust. unfortunately, you'll have to replace the entire optical engine.
Oct 08, 2009 | InFocus LP 540 Multimedia Projector
Cannot see computer displyed on output of infocus screen shot
Many laptop computers do not automatically turn on their external
video port when a projector is connected. On many laptops, the activation function key is labeled with an icon or the text CRT/LCD.
Try the Function Key with the Icon of a monitor to enable the external video port.
If that does work, look at the settings on the projector using the buttons on the top.
Check the "Default Source"
Default Source toggles among Computer 1 analog, Computer 1 digital, Computer 2, and Video. This determines which source the
projector checks first for active video during power-up. Highlight
Default Source and click the left or right mouse button to toggle
among the options.
Jan 12, 2009 | InFocus LP70+ Multimedia Projector
Colors showing red on screen
Hi Stella,
There is a button on the projector called "Auto Image"
Most people don't realize it's even there.
Press it while you are seeing this problem and most likely the projector will figure out the image issue and all will be well.
Note: this feature is nowhere in the menu(s)
Good Luck!
SagerTronics
Oct 29, 2008 | InFocus ScreenPlay 4805 Multimedia...
Infocus LP120 Retrying-Power Light Turns Red...
Usually when the lamp is good and you get this message, the ballast is bad. That is the part thatdrives the lamp. Check with Infocus for a repalacement balast.
Dan
Apr 09, 2008 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Cannot play movies
Yes you need to replace the cable first, I have seen a fw of the cables go bad on this model.
http://www.infocus.com/Accessories/Cable.aspx
Feb 13, 2008 | InFocus LP70+ Multimedia Projector
Focus with erector eyepiece on
Some eyepieces cannot come to focus in certain telescopes-- try a different eyepiece.
Sep 02, 2007 | Bushnell Voyager 78-9565 (120 x 60mm)...
InFocus LP120 / 1000 Lumens / XGA / DLP Projector Refurbished Multimedia Projector Logo
254 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
martin hogg
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
