Question about Emerson MS3111M Shelf System
It sometimes wont recognize that a disc is in the changer the light dims and brightens
    Problem Solver:
  • 6 Answers
Try cleaning the cd the proper way.if this does not work,get out your manual and try to determine if your stereo supports that cd type.
Posted on Nov 16, 2009
Dash lights come on with the headlights then shut off
Do you have a dimmer for interior lamps? Like a rheostat, a little wheel that you turn up or down to brighten or dim interior lamps. Usually the instrument cluster lamps brighten and dim the same way.
Can you brighten and dim the other interior lamps?
Apr 17, 2016 | Cars & Trucks
When i turn headlights on...radio lights go out..they come on when i turn dimmer switch..but then dome lights wont go off...tried it on all different positions...2008 patriot
It sounds to me like you may have a defective dimming switch. Are the instrument cluster lights working as they should? Do they dim/brighten with the dimmer? If the instrument cluster is working OK, then it could be an internal problem in the radio unit itself. Your panel lights are computer controlled. The processor in the instrument panel controls them. It uses a digital signal to "tell" the radio to either dim or brighten its lights. If the radio is failing to do so, the radio is the most likely cause since the lights work on "full power" which is also commanded through the same data lines. (this eliminates the signal from the cluster and the connection through the data lines.)
May 23, 2011 | 2008 Jeep Patriot
Player wont recognize disc
Sorry for such a simple solution, but it has saved my but multiple times. Try cleaning the disk reader laser with a smooth clothe rag or material. Clean the dust or whatever may be on it. If that doesn't work, then I hope someone with more knowledge on this matter will help.
Mar 15, 2011 | Pioneer PD-M603 6-Disc CD Changer
Lights Dim and Brighten
do you have any kind of entertainment systems hooked up to the battery for instance the subwoofers in my car constantly make my lights dim and brighten if i have them loud enough
May 14, 2009 | 1991 Lincoln Continental
Won't start lights dim and then brighten
Did you try to boost battery? Sounds like low charge. Check battery terminals for tight and clean as well as groung connection at body and power connection at starter for clean. If battery OK test for power on starter wires. Large wire will have contant battery power small wire will have battery power when key is in crank position. If power ok on both it will probably need a starter. Hope this helps...Good Luck.
Feb 06, 2009 | 2004 Mitsubishi Endeavor
99 chevy venture
check to see if all doors are shut tight,the same thing was happening to me,and it was the very back door that was the problem
Sep 21, 2008 | 1999 Chevrolet Venture
I can't get the led read out to brighten?
Does the dimmer switch in your truck make nthe light in the radio go up and down? if not the instalation was not done properly and someone left off the dimmer wire. If that does work and the brightness does go up and down, you may have an LED or Two out on the radio. Good Luck
Mar 23, 2007 | Sony CDX-5090 CD Changer
Emerson MS3111M Shelf System Logo
95 people viewed this question
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
