Question about NRS Fleck 5600 - 64,000 Grain Timer Water Softener
The gears are jammimg when it gets to the brine
Have a Fleck Model 5600 .. the gears are jammimg when it gets to the brine position .. removed the motor to confirm it's not the problem .. still jammed? Have the timer off the tank and it still jams?
    Problem Solver:
  • 15 Answers
Most likely it's NOT the motor...If you can remove the entire timer box, or "Power Head", you will see that the main dial is easy to turn..remember..." CLOCKWISE ONLY!!!!"...the problem is more likely the main piston the is locking up in the valve bore, you can find parts for this valve online...you will need a new main piston, a brine piston (the smaller one on the right) and a set of spacers and seals.
Posted on Dec 23, 2010
Fleck 5600 wont draw brine
Eductor assembly is most likely plugged with iron. Clean thoroughly. Make sure the salt is not mushed and packed in bottom of salt tank also.
Apr 06, 2014 | Fleck Water Dispensing & Filtration
Re: Hydrotech (Fleck 5600) odour is similar to that of a skunk or burnt rubber. When the bypass is used, odour disappears, but seems to get stronger after a few days just prior to the next regeneraton...
If your using any product like IronOut, or anything with Sodium Hydrosulfate in it, this can cause the burnt rubber smell....If your softener has Anion resin, or other resin used for Tannins, you need to add a few ounces of Citric Acid to the brine tank every month or so
Nov 29, 2010 | NRS Fleck 5600 - 64,000 Grain Timer Water...
Not using salt
There may a salt bridge in the salt tank. Eductor nozzle may be plugged preventing brine draw.
What model softener is it?
RJ
Sep 06, 2010 | NRS Fleck 5600 - 64,000 Grain Timer Water...
Where to put the salt? and how to flush it? thank you wg844
Dump the salt in the separate brine tank. Always keep salt/brine tank at least half full. If you want to run a manual regeneration push the regen button. For delayed regeneration (2am) push once, for immediate regeneration push twice.
RJ
Aug 09, 2010 | NRS Fleck 5600 - 64,000 Grain Timer Water...
Have an rainsoft Q10 classic apollo softner that does not draw brine. Ran a wire thru the brine injecter tube and it appeared to be clear of obstruction. Drained tri-guard glass did startcycle and redrew...
You most likely have a slight leak in the brine line. This is the most common failure on a water softener. A slight leak will allow air to enter during brine draw, breaking the vacuum. it doesn't take much of leak, in fact it can be small enough that water does not leak out during brine refill but it will not draw brine. Check the compression fittings at the brine tank and the softener valve. disassemble the connection, cut back the tubing and reconnect. Other things to look for are low water pressure, the unit requires 25 psi minimum during regeneration. Also make sure the drain line is not restricted and the maximum head on the drain is 4' over the softener.
Mar 16, 2010 | NRS Fleck 5600 - 64,000 Grain Timer Water...
Kinetico Water Softening Unit has brine tank drainage problem
This sounds like the resin cylinder is perforated or connections at the top are leaking. The brine tank should only have a little water in the bottom - if it is full of water (maybe even up to the overflow?) then you will need to replace the resin cylinder or fix a leaky connection to it.
Is the water in the brine tank 'rusty'?
Feb 11, 2010 | NRS Fleck 5600 - 64,000 Grain Timer Water...
Not getting soft water. The system charges but it does not seem to be getting brine from the tank to wash the softener pellets. Is there some way for me to check the valve. Maybe change a simple part. ...
You need to remove the venturi valve and clean it. This part is usually found under a round plastic cap that unscrews remember to put softner on bypass or turn off water first
Nov 15, 2009 | NRS Fleck 5600 - 64,000 Grain Timer Water...
Timer ticking but backwash will not back wash and clock frozen
It is very common for the main and brine pistons of the Fleck 5600 to need replacement after 5 - 10 years of use. The valve will get stuck trying to complete a regeneration cycle. Very often this occurs at the beginning of the "brine rinse" cycle. The timer motor may stop at this point also. The motors are made to stop instead of forcing the valve ( which would result in gear damage ).
The solution is to replace the main piston ( # 60102-00 for water softeners ) and the brine valve piston assembly ( # 60032 ). If the valve is on a chlorinated water source or over 10 years old, it is recommended to replace the main piston seals ( # 60125 ) at the same time.
On rare occasions the timer motor may also need to be replaced. But try the pistons replacement first, this usually does the trick.
There are detailed instructions for replacement including a video here.
http://softenerparts.info/2008/06/28/replacing-the-main-piston-seals-and-spacers-and-brine-valve-piston-a.aspx
Aug 05, 2009 | NRS Fleck 5600 - 64,000 Grain Timer Water...
NRS Fleck 5600 - 64,000 Grain Timer Water Softener Logo
135 people viewed this question
Top NRS Home Experts
Donni Steen
john h
Bill Boyd
Are you a NRS Home Expert? Answer questions, earn points and help others
