Question about Zanussi ZWF1630 Front Load Washer
It stops midway through wash with 'E20' flashing on the screen, it now won't do anything for me at all. there are clothes and water in the machine so door won't open either
Inlet water problem, check the filter on the inlet hose and make sure there is a good supply of water to the machine and that the hose isn't kinked, if it is get a replacement
Posted on Jan 07, 2010
E20 error message
maybe you should just get a new washing machine
Dec 11, 2013 | Washing Machines
Simpson eziset 550 stops at rinse cycle, light flashing
I had the same problem before, but removing the kink in drain hose does the trick. Maybe yours is more complicated but try it.
Aug 28, 2012 | Washing Machines
I have an E20 code on my front loading Frigidaire gallery series washing machine, what does this mean and how does my husband fix it. Also, has anyone had problems with the matching dryer destroying...
That E20 could be a bad pump or clogged pump screen. Remove and clean out the tub to pump hose. Look for object in pump. A clogged airline to the pressure switch can also give the E20 code. The switch thinks there is still water in the tub when in fact there is crud in the end of the hose.
Hope this helps!
Nov 20, 2010 | Washing Machines
My zanussi FJS1025W washing machine is showing the error code E20 and it wont let me spin or drain the water away. I have cleaned all the filter but still it wont do anything other than take in the water...
E20 is a draining error.
Check the filter.You need to take the filter out, empty it of all lint and replace it. It may have water trapped in already, so get a cloth ready to soak up excess liquid! Also, make sure when you put it back in you have tightened it enough to avoid leaking but not too much that you cannot get it back out.
If still the problem persists then the problem is with the draining pump.The pump is not pumping out the water.Check the pump impeller it may got stuck due to some obstacles.Replace it and this wont come again.
Thank You
Sep 09, 2010 | Washing Machines
Washer won't finish wash cycle
e20 on a lot of machines will generally indicate a water emptying problem. Possible solutions: kink in the outflow pipe, internal blockage which is letting the water away too slowly, pump not functioning each of these needs to be checked.
May 24, 2010 | Frigidaire GLTF2940ES Front Load Washer
I put on a load of washing and it stops half way through the machine flashes E20 n just stops the machine is a zanussi jetsystem zjd12191
Error code E20 relates to the pump/filter blocked.Drain the water either manually through the filter or drain hose.Check that filter is clean and pump can turn by hand.
Hope this helps.
May 19, 2010 | Zanussi FJS1225W Front Load Washer
Code E20
my cloths will wash but will not spin out the drum stop turning when it comes to the spin cycle makes a humming noise
Mar 30, 2009 | Frigidaire GLTF2940ES Front Load Washer
E20 code on washer : will not empty water on spin cycle?
something is stopping the water from drainning...check for kinked hose,,,check waste pipe,,,check units sump...onthejob
Dec 18, 2008 | Frigidaire Affinity ATF7000E Front Load...
Too many E20 errors!
the first thing i would try is the pump..........if its not draining all the water out it will take longer to finish...........pump could be blocked......alst the hose from the pump........check both first.....
cheers
Aug 03, 2017 | Zanussi ZWD1680W Front Load Washer / Dryer
Open Questions:
Zanussi ZWF1630 Front Load Washer Logo
190 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
