Question about SimpleTech SimpleDrive 160 GB External USB 2.0 Hard Drive
I have a simple tech external not registering
I have a simple tech external hard drive that does not register on the computer anymore, can you help me ? It comes on, but that's it.
Of chechked and/or done all of the the above but my SimpleTech 160gb Ext Drive is not recognized at atll (not even in Disk Mgmt or Device Mgr) but it has power. It works just fine in my new laptop. So the problems is obviously the older Toshiba w/WinXP. The product has not CD and is no longer being supported my company. What else can I do?
Posted on Jan 07, 2010
  • 3,153 Answers
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
7. It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure.
8. If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
9. If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
10. ensure that you have set removable drives for "quick removal" or that you use the "Safly Remove Hardware" option often shown on the lower toolbar.It is possible that files my not be fully written to external devices before they are removed. This corrupts the file itself and even on occasion the drive.
Posted on Nov 22, 2009
  • Project NOMAD
    Project NOMAD Nov 22, 2009
    SPECIAL NOTES
    USB flash drives can fail for no apparent reason.
    Sandisk Cruzers are especially bad for this.
    USB hard drives should be treated with extreme care.
    This is a real hard drive ! and knocks and bumps can quite literally kill them.
    Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
    Known as "The Click Of Death"
  • 358 Answers
First of all make sure that the USB port that you are using to connect it to your PC is a USB 2.0 port, and not USB 1.0.
Also if it came with an external power, connect it to the external power before putting on your PC.
This is because the voltage supplied by USB 1.0 is lower than that of USB 2.0 and therefore might not be enough to power up your USB Drive.
After making sure about this, power up your system, and plug the external drive, then Right-Click on my computer icon, select manage, then go to Disk Management Option.
On the Disk management option Page you should see ALL the drives installed on your system, including the hidden ones, so what you will just do is, try and locate the one representing your external drive, and right click on it. then select "Change Drive letter and Paths", and give the drive any new, unique letter (i.e alphabet) different from the ones already on your system, and click on OK.
This should make your external Drive to be detected automatically.
Hope this helps you out.
Hey there i want to access simple Tech device on my computer but i think i need to install the driver for it and i do not have the CD. is there anyway around that?
Sir..greetings..I have Problem with the Transcend StoreJet 2.5 120 GB USB 2.0 Hard Drive.
I didnot register it on line.in time i was presented this nice device..
because it was working ok .when i just connect it to LapTop.
NOW..After almost 2 years .it s became not RECOGNISED BY MY pc.
And i cant find any driver for it.I have all my important documents in Transcend.
WHat can i do.friends.. Any help?
Please help old Lady.
Thanks if responded.
dearme9@yahoo.com is my mail and this is banner i see.
i have Vista7
Sep 07, 2011 | SimpleTech 1TB External USB 2.0 Hard Drive...
Doesnt register and all the lights stay
Does it work after you change the USB cable?
If so, then your USB cable is the problem.
Does it work on some "other" computer?
If so, then your computer is the problem.
Does it work it _any_ USB port in your computer?
Failing that, disassemble the casing, to find:
* the USB-to-disk-drive adapter,
* the disk-drive itself.
Connect the disk-drive as a "slave" drive to a desktop computer, to see if the disk-drive can be detected.
If not, then the disk-drive has "died".
Buy a new disk-drive, and connect it to that USB-to-disk-drive adapter, to "revive" your external unit.
Read the serial-number from the disk-drive, and access Western Digital's web-site, and enter the number in the "check warranty" section, to see if your unit is still under warranty, i.e., a free replacement.
If not under warranty, then W.D. has a "Customer Loyalty Program" -- buy a new External Hard-Drive from their web-site, and they will give you about a 20% discount from their "retail" price.
Apr 08, 2010 | Western Digital Passport 320GB External...
HELP MY HARD DRIVE HAS GONE!
Ok to understand this , you dropped a 1 TB hard-drive external hard drive on the floor? Well considering that it is a external, the cases in most externals are meant to take a beating as well as the hard-drive it self. There is two possiblities I can think of, what could of happened. When the Hard-Drive hit the floor, it could of is disconnected the connection on the hard-drive itself inside the casing, which you will have to pop it open and reseat it. Or the hardrive, arm inside the hard-drive it self snapped or is misplaced, which is unrepairable. Open up the casing and looking for the hardrive it self. Towards the back of the hard-drive is where the connection of th drive is, it is eather sata or orginal set up with his pins based. Take the connection off and put it back on and see if that works, if it didnt, best advise would be is take in in and have the drive tested, see if its still operable.
DrakeTech
Feb 25, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Simple Tech external memory 1.0 tb not registering all the sudden
On the Disk management option Page you should see ALL the drives installed on your system, including the hidden ones, so what you will just do is, try and locate the one representing your external drive, and right click on it. then select "Change Drive letter and Paths".
Give the drive any new, unique letter (i.e alphabet) different from the ones already on your system, and click on OK.
Nov 21, 2009 | SimpleTech 160GB USB 2.0 / FireWire...
Moving my Iomega® HDD 80GB USB 2.0 External Desktop HD
You have to create a admin. user account on your computer. You do this from user accounts.
Nov 20, 2009 | Iomega HDD External Desktop (32660) 80 GB...
Hard drive will not register on computer
my hard drive is not registering on my computer anymore what should I do?
Jun 27, 2009 | LaCie 500GB FireWire-400 Porsche - 7.2K...
My Hp Slimline won't recognize my new Simple Tech Mini-Drive
I`m David ncc student , question is about the characteristics of various network computers (NCs) currently on market? please help me
Mar 08, 2009 | HP S3120N Pavilion Slimline Desktop...
Register
Hi, I bought a new external harddrive over the internet and found your website very confusing to register it, although I had the right website, in the end I phoned the office, I think in Melbourne, and a very nice lady gave me a great deal of help, and everything is settled now, so thankyou to your lady in the office in Australia for her kind assistance,
I could not find where to register my product on your webpage, and obvoiusly ended up going to the wrong section,
All's well that ends well
thankyou, anne roddick
Aug 12, 2008 | Computers & Internet
Simple Tech external hard drive
if you are running windows, then check the following:
go to control panel -> administrative tools -> computer management -> storage -> disk management.
you probably have a drive (located on the bottom right) that is listed with no drive letter, just assign it a drive letter and see if it comes back, if not, the drive is probably not initializing and you might have to either format it or replace it.
Jun 13, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Simple drive external backup
You need to use the Storage Sync program provided with the drive. You can get the latest version at the Simple Tech website
Sep 20, 2007 | SimpleTech SimpleDrive Portable USB 2.0...
SimpleTech SimpleDrive 160 GB External USB 2.0 Hard Drive Logo
537 people viewed this question
Top SimpleTech Computers & Internet Experts
Lyle Siemens
Lyle Siemens
Arora Singh
Arora Singh
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
