Question about Bosch Washing Machines
The door seal on a Bosch WVT1260DB01 FD8609 has
The door seal on a Bosch washer drier has gone. I have removed sprung steel clasp on the outer side. Is there any other fixing to be removed or is it just a tight fit in the inside
  • Bosch Master
  • 3,463 Answers
There is another clamp or spring depending on which is fitted.
Turn the door seal in on it'self, and you should be able to feel or see the second retainer, if it is a spring, get something to hook it out with, if it is a clamp, then it will have to be unscrewed.
Please rate my solution.
Thanks.
Posted on Nov 16, 2009
  • Bosch Master
  • 744 Answers
This video will show you how to change a door seal on this Bosch WVT1260DB01
Posted on Jul 22, 2013
The clasp on my steel watchband pulls away from the band creating a large gap. it looks bad and catches on things. what do i do?
You need to make sure that if you had the watch band adjusted they did not adjust it at the clasp. When you adjust the watchband links should be removed if you adjust it at the clasp the band keeps pulling open. When you open the clasp fully make sure the pins are on the end holes. If the pins are in the end holes then, the clasp is probably sprung somehow and you will need a new one or have a jeweler or watch repairman fix it! You may also be able to order a new clasp from manufacturer! Hope this helps!!
Sep 21, 2011 | Watches
Replacing door seal front loader bosch
This video will show you how to change a door seal on this bosch
Apr 04, 2010 | Kenmore HE2 Plus Front Load Washer
Front dor seal has a tear in at at the bottom. It leaks as soon a
you will need to remove front panel 2 screws at bottom behind kickpanel removed with one screw next to filter cap one more screw behind soap draw ,then remove steel spring clamp holding door seal to outer cover push seal into drum so as not in your way pull down front panel it will then come towards you remove door lock connection and lift away fromt panel this will expose drum front there is another spring clamp on back edge of seal remove this and pull away seal reverse procedure to refit new one may need some detergent on back of seal to make refitting easier.
Feb 04, 2010 | Bosch Axxis WFL 2060 Front Load Washer
How to change the door seal for the Bosch WFK2401 washer
Most bosch front panels can be removed by removing soap disp. then 6 screwss top/ bottom .remove door interlock..The boot seal is held by a spring ring onto the outer drum...you may find video on this @ utube...hope this helps
Sep 29, 2009 | Bosch WFK 2401
Change integrated Neff washing machine door seal
you will need to remove front panel this is quite easy,turn off mains open door and look for steel band spring holding front lip of door seal this needs to be removed it will be tight but will pull off,push door seal into drum so as out of the way, look at bottom of panel you will find 2 or 4 holding screws dependent on age of appliance undo these ,there is one other screw to undo behind the soap drawer take out draw and remove screw it is bottom r/h/side one you can then pull front panel away you need to disconnect door lock plug just pulls out.
remove panel out of the way and you will see another steel band holding back of seal to wash tub remove this and pull of door seal. reverse procedure to fit new one a little washing up liquid may help reassembly fit panel etc run check for leaks.
good luck
Dec 22, 2008 | Neff W5340X0 Washer
Removal of door seal on hotpoint washer drier wd420
You will achieve nothing by removing the door seal .
Depending what is in there, better to leave alone and trust it will find its way into the filter.
If it is anything substantial then it involves major work.
Dec 14, 2008 | Hotpoint Aquarius WD640 Front Load...
Leaking door due to the wire ring that holds rubber seal
Bosch Nexxt 500 WFMC3301 Front Load Washer how
to get the metal ring back on.
This video will show you how to change a door seal on this Bosch front loader washing machine and also how to replace the metal rings.
we have all bosch repairs in our channel.
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 06, 2008 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Wf860 door seal
un-plug the washer take the lid off now open the door undue the clasp that goes around the rim of the door seal on the outside of the washer (look carefully) once done the door seal should push into the washer now if u look into the washer from the top at the front though u will see a another clasp going around the door seal on the inside of the washer this is a screw un-screw it once done then the door seal should pull out repeat backwards to replace it m8
Apr 27, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing machine replacement door seal
This video will show you how to change a door seal on this bosch Axxis WFL 2060
Oct 26, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
136 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
