Question about Sony PlayStation Portable (PSP) Console
How Do I Do it
If You know how to do it... tell me cause this is my first time doing this....
    Scholar:
  • 135 Answers
It'd be helpful if you could tell us what exactly you're trying to do...
Posted on Jan 09, 2008
I cant use my hisense phone because a lady keeps on talking when i try to press any button
You must stop talk back service from settings, my device talk back
Apr 06, 2017 | Cell Phones
Why do I think I am wasting my time here
don't know
is it because you do not give enough details in your question
is it be cause your question requires common sense
is it because you asked a question 100 posts ago but could be bothered including any details in this post
or is it you are expecting a 100% accurate answer for free because you will not go anywhere else that you have to pay
you tell us why you think you are wasting your time because you sure as hell are wasting our time
Mar 23, 2017 | Office Equipment & Supplies
While driving the car runs fine, but when stoping at a stop it idles rough and try to cut off. pulled code gave code p0325. I changed the knock sensor but still gets code p0325, and car still misses at...
Hi Thomas,
We have a couple different issues here.
First, your Maxima is either NOT a 1995 model, or it is a very late 1995 model that "thinks" it's a 1996. The reason I say this is because a 1995 model Maxima is NOT OBD compatible and is not capable of outputting "P-codes" to a generic OBD scanner.
Those Nissans that were claimed to be OBD compatible in the late 1995 model year only output certain codes. To find out the rest of the story, you still need a scanner that has software capable of accessing the engine computer through the Nissan-2 connector (usually in the fuse block area).
Then you need to understand about Diagnostic Trouble Code (DTC) P0325.
This code does not necessarily mean that you need a new knock sensor. I think you will be a little less confused if you know the facts. What you need to know about ALL fault codes is that they NEVER tell you what parts to replace. Fault codes only tell you that the computer has a problem with one of the many circuits and systems that it monitors. The fault code will tell you which system is failing or which circuit is failing. They DO NOT tell you what is wrong with the circuit or system that it is reporting. The person diagnosing the vehicle is supposed to figure that one out.
Most people think that "diagnostics" means plug in the "magic box" and replace everything the computer tells you to replace. I WISH it was that easy!
Now that you know all of this, we can examine the code itself. What causes this code to set? ...I'm glad you asked. The computer controls the ignition timing in your car. The trick is to advance the timing as far as possible (for more power and efficiency) while not advancing it too far, which will cause pre-detonation (also known as "ignition ping"). Pre-detonation can cause serious engine damage, including burning holes through a piston.
Here is where the knock sensor comes in.
SCENARIO 1: The computer advances the ignition until the knock sensor "hears" an ignition ping. When this happens, the knock sensor sends a signal to the PCM to let it know that the engine is "knocking". So the computer responds by retarding the timing a little to stop the knock. When the knock stops, the knock sensor will stop sending a knock signal to the computer.
DTC P0325 sets when the computer has ******** the ignition timing as far as it possibly can and the knock sensor is STILL sending a knock signal.
SCENARIO 2: The computer also tests the knock sensor by deliberately advancing the timing too far for a few seconds to see if it gets a signal from the knock sensor.
So, P0325 can also set if there is NO signal from the knock sensor when the computer is EXPECTING a signal.
For scenario 1, the cause is usually a mechanical knock in the engine. Loose timing belts, worn/loose timing chains worn distributor shafts, bad pulley bearings, etc. The knock sensor does not know the difference between a knock caused by pre-detonation and a knock caused by a loose valve lifter (or other mechanical reason). The knock does not go away when the timing is ******** because the knock is not CAUSED by timing....code P0325 sets.
For scenario 2, the cause is usually either the knock sensor itself or a problem with the wire between the knock sensor and the computer or the knock sensor is not grounded properly. These things will cause the knock sensor to not be able to get a message through to the computer....code P0325 sets.
Now, the misfire at idle is a whole other issue. The computer will default to base ignition timing settings if there is a knock sensor fault. You may notice a little loss of performance, particularly during heavy acceleration, but there is NO WAY that your knock sensor is the CAUSE of ANY misfire - especially not at idle. However, it is VERY possible that whatever is causing the misfire could also be the cause of the knock sensor code.
Basically what I am saying here is that you need to put the knock sensor problem "on the back burner" until you find out what is causing your misfire. Unfortunately, misfires can be cause by a LOT of different things ranging from a bad spark plug to a cracked cylinder head or worn-out piston rings. The misfire simply has to be diagnosed using the proper procedures to avoid replacing a bunch of things that will not fix the problem.
With all that said, WHEW! I hope you got through all that!
The older Nissans are notorious for the distributor shaft bushing going bad and causing a loud "rattling" noise. The movement of the shaft can cause a cylinder misfire, and the rattling can cause a knock sensor code to set. I have fixed many of the Nissan V-6 engines with this same problem by replacing the distributor. This is the FIRST place I would look. If your distributor is not rattling, try revving the motor just a little and see if it rattles. If it does, replace it. If it does not, let me know and we will look elsewhere for the cause of your problem.
-Dave (dttech)
Nov 19, 2011 | 1995 Nissan Maxima
I worked in a it company. my administrator blocked my facebook chat whereas i can do every thing in my facebook account exept chat.i can sea my online friend in my facebook account. i dont know how did...
He's the administrator and you better watch it cause he knows what you are doing on that computer at all times and he controls all. He is GOD to that computer even if I told you how ,you couldn't cause you don't have the privlages
Apr 08, 2011 | Cycling
I change the light bulb and still no picture or sound. It turn on then off. The red light blink three times. How do I fix the problem
If you have the owner manual it will tell you what the 3 blinks means.
I know it is one of two things: either the lamp door is not properly closed(these sets had a history of the door being warped by heat which causes this----I can tell you a easy way to see if this is your problem.)
The other possible cause (again owner manual would tell you) is these sets also have a history of a thermal fuse failing for no reason.
Let me know if you want to see if it is the door problem----takes ten minutes and you will know instantly.
Regards, SD TECH
Aug 05, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
96 Sebring stalling out at times
The MAP sensor does the same thing as a TPS Throttle position sensor Tells computer at what angel the intake butterfly is at non fixable Replace the part
Apr 07, 2017 | 1996 Chrysler Sebring
My car has been on the diagnostic machine 3 times and it has undocumented code 04122 nobody knows what it refers to. I have a Renault clio dynmique 51 reg. MY engine electronics light comes on all the time...
The OBD code PO4122 most common cause is a damaged catalytic converter, poss internal engine problems causing misfires that damaged the converter, a faulty head gasket. Do u notice oil consumption either?
May 27, 2017 | Renault Sport Cars & Trucks
TV is not responding
Your description does not tell me very much---You have a JVC AV-56WP74 and it does not work?
If the power light up front which is usually blue in color just blinks I can tell you a easy way to know exactly what is causing this problem.
If when you turn the set on the blue power light just blinks---that is short protection--most of the time a fairly cheap fix----LET ME KNOW WHAT YOU ACTUALLY HAVE GOING ON.
I am here to help---I do this here for free.
Do not hesitate to ask me for help or advice.
Regards, SD TECH
Oct 31, 2009 | JVC AV-56WP74 56" Rear Projection...
All of my locks keep clicking on my 98 saturn
the first thing i would do is make sure the spring inside the power door lock switch did not collapse and causing the door locks to click all the time,,,you should be able to tell just by pushing the door lock switch,,if not disconnect each door lock switch one at a time and see if it stops,and if it does then you know which one caused it
Oct 25, 2009 | 1998 Saturn SL
1998 honda accord v6 code 170 trim air malfunction, also has code 171 bank 1 too lean, do you know what it takes to repair
You may have one of many problems...
one you could have an intake leak..
or possibly a bad injector, or a bad o2 sensor.
With what you have given its not easy to diagnose. A mechanic will need to look at it to determine the exact problem.
Remember engine codes most times do not tell you the exact problem...they tell you where to look and tell you of a problem that exist..its the qualified mechanic which must take the code in formation and with his knowledge determine the cause and fix the situation.
Aug 27, 2009 | 1998 Honda Accord
Sony PlayStation Portable (PSP) Console Logo
35 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
