Question about Sentry Office Equipment & Supplies
My sentry caculator is displaying SD in the window how do i turn it off
  • Sentry Master
  • 7,993 Answers
I do not know this calculator, but from my experience, it is likely that your calculator is configured to do statistical calculations (Standard Deviations) hence SD. Change the computational mode to COMP and the SD will probably be replaced by an abbreviation for the MODE in effect.
Sorry not to be able to help you more, but what do you expect if you hide the identity (or the species) of your calculator.
Hope it helps.
Posted on Nov 17, 2009
My tasco trail cam boots up with 4 dashes on display. Nothing else.
When you hit enter does it change the dashes to zeros? Default code is 0000
Apr 27, 2014 | Bushnell Trail Sentry 11-9200 Digital...
How to format a trail camera
I'm sure the Bushnell Trail Sentry User Manual can help you with this. See -Setup and Operation Guide - If the Sentry is turned on without a card in place, it may not turn off. Reset it by pulling one of the batteries out partway, insert a new or empty SD Card and put the battery back in place. Only remove or insert cards with power off.
Click on this link for more information or to buy additional Bushnell Trail Scouting Camreras
Aug 16, 2010 | Bushnell Trail Sentry 11-9200 Digital...
Trying to figure out a pass code for my camera
If the Bushnell Trail Sentry 11-9200 is turned on without an SD card in place, it may need to be reset. Reset it by pulling one of the batteries out partway, insert a new or empty SD card, and put the battery back in place. Read this Set Up Guide for instruction how to set up your passcode.
If you are looking for a replacement trail camera, or you want to buy another, go to my Hunting Supplies Website and browse through the different name brands offered for sale here.
Jul 01, 2010 | Bushnell Trail Sentry 11-9200 Digital...
Trail Sentry 11-9200 Digital Camera: I bought this camera from a store that used it as ...
Bushnell recommends to only remove or insert cards with power off, or it can damage the SD card.
Borrow an SD card that fits in your camera and test it. If this solves the issue, buy a new SD Card here.
May 16, 2010 | Bushnell Trail Sentry 11-9200 Digital...
Bushnell Trail Sentry camrera will not accept any code
If the Bushnell Trail Sentry 11-9200 is turned on without an SD Card in place, it may need to be reset. Reset it by pulling one of the batteries out partway, insert a new or empty SD card, and put the battery back in place. Read this Set Up Guide for instruction how to set up your passcode.
The camera will not Make sure the power is off before installing or removing the SD Card. If you forget, you need to do the reset procedure above.
Buy Name Brand Trail Scouting Cameras here.
Feb 07, 2010 | Bushnell Trail Sentry 11-9200 Digital...
How do you delete pictures from a sd card used in a bushnell trail camera
The Bushenell Trail Sentry camera does not allow you to delete pictures from the camera itself. To delete those pictures, you need to take out the SD card from the camera and insert it to an SD card reader. Plug it into your computer's usb port and delete using Windows Explorer or any picture management application.
Should you have any questions, please don't hesitate to ask.
Nov 13, 2009 | Bushnell Trail Sentry 11-9200 Digital...
My camera is locked and i cant get the password to reset
I'm sure the Bushnell Trail Sentry User Manual can help you with this. See -Setup and Operation Guide - If the Sentry is turned on without a card in place, it may not turn off-reset it by pulling one of the batteries out partway, insert a new or empty SD card, and put the battery back in place. Only remove or insert cards with power off.
Click on this link to buy additional Trail Scouting Camreras
Oct 30, 2009 | Bushnell Trail Sentry 11-9200 Digital...
2003 Chrysler T&C Key programming
STANDARD PROCEDURE - TRANSPONDER PROGRAMMING USING A DRB III® SCAN TOOL All Sentry Keys included with the vehicle are pre-programmed to work with the Sentry Key Immobilizer System (SKIS) when it is shipped from the factory. The Sentry Key Immobilizer Module (SKIM) can be programmed to recognize up to a total of eight Sentry Keys. When programming a blank Sentry Key transponder, the key must first be cut to match the ignition lock cylinder of the vehicle for which it will be used. The vehicle's four digit PIN code will be required to complete this task since you will need it to enter the Secured Access Mode in the SKIM. The following steps must be completed using a DRB III® scan tool:
  1. Insert the blank key into the ignition and turn it to the RUN position.
  2. Using a DRB III® scan tool, select "Theft Alarm," "SKIM," "Miscellaneous," and then "Program New Key."
  3. Enter the four digit PIN code using the DRB III® scan tool. When programming is completed, the SKIM will exit Secured Access Mode and the DRB III® scan tool will display the results of your attempt to program the key. One of five distinct results may be displayed. All five are listed below:
    • "Programming Successful" is displayed if the Sentry Key programming is successful.
    • "Learned Key in Ignition" is displayed if the key in the ignition has already been programmed into that vehicle's SKIM.
    • "Eight Keys Already Learned (At The Maximum) Programming Not Done" is displayed if eight keys have already been programmed into the SKIM. In this case, if a new key needs to be added due to a lost or defective key, the "Erase All Keys" command (which requires entering the Secured Access Mode) has to be performed. Following the "Erase All Keys" command, all keys that will be used to operate the vehicle MUST be reprogrammed to the SKIM.
    • "Programming Not Attempted" is displayed after an "Erase All Keys" function is executed.
    • "Programming Key Failed" is displayed if further diagnosis is required.
To learn additional keys, turn the ignition OFF, remove the learned key, insert the next new blank key, and repeat the steps from the beginning.
“CUSTOMER LEARN” MODE This feature is only available on domestic vehicles or those which have a U.S. country code designator. This procedure requires access to at least two valid Sentry Keys. If two valid Sentry Keys are not available, Sentry Key programming will require the use of a DRB III® scan tool.
The steps required to program Sentry Keys with two valid Sentry Keys follows:
  1. Obtain the blank Sentry Key(s) that need to be programmed. Cut the keys to match the ignition lock cylinder mechanical key codes.
  2. Insert one of the two valid Sentry Keys into the ignition switch and turn the ignition switch to the ON position.
  3. After the ignition switch has been in the ON position for longer than three seconds, but no more than fifteen seconds, cycle the ignition switch back to the OFF position. Replace the first valid Sentry Key in the ignition lock cylinder with the second valid Sentry Key and turn the ignition switch back to the ON position. The second valid Sentry Key must be inserted within 15 seconds of removing the first valid Sentry key.
  4. About ten seconds after the completion of Step 3, the indicator light will start to flash and a single audible chime tone will sound to indicate that the system has entered the "Customer Learn" programming mode.
  5. Within sixty seconds of entering the "Customer Learn" programming mode, turn the ignition switch to the OFF position, replace the valid Sentry Key with a blank Sentry Key transponder, and turn the ignition switch back to the ON position.
  6. About ten seconds after the completion of Step 5, a single audible chime tone will sound and the indicator light will stop flashing and stay on solid for three seconds and then turn off to indicate that the blank Sentry Key has been successfully programmed. The SKIS will immediately exit the "Customer Learn" programming mode and the vehicle may be started using the newly programmed Sentry Key.
These steps must be completed in their entirety for each additional Sentry Key to be programmed. If any of the above steps are not completed in the given sequence, or within the allotted time, the SKIS will exit the "Customer Learn" programming mode and the programming will be unsuccessful. The SKIS will also automatically exit the "Customer Learn" programming mode if:
  • It sees a non-blank Sentry Key when it should see a blank.
  • If it has already programmed eight (8) valid Sentry Keys.
  • If the ignition switch is turned to the OFF position for more than about fifty (50) seconds.
NOTE: If you attempt to start the vehicle while in “Customer Learn” mode (LED flashing), the vehicle will behave as though an invalid key is being used (i.e. the engine will stall after two (2) seconds of running). No faults will be logged.
NOTE: Once a Sentry Key has been programmed to a particular vehicle, it cannot be used on any other vehicle.
Oct 15, 2009 | 2003 Chrysler Town & Country
Forgot password on bushnell trail sentry game camera
If you are looking for a replacement trail camera, or you want to buy another, go to my Hunting Supplies Website and browse through the different name brands offered for sale here. http://hunting-supplies-net.com/
Dec 09, 2008 | Bushnell Trail Sentry 11-9200 Digital...
Top Sentry Office Equipment & Supplies Experts
k24674
Are you a Sentry Office Equipment and Supply Expert? Answer questions, earn points and help others
