Question about Hoover H3030 FloorMate SpinScrub 500 Upright Wet/Dry Vacuum
Hoover floormate plus model #H3010
Will not put any liquid onto floor -- will pick up. Has been used several years without problems until now. I have only used the recommended cleaning solution. Note: the product I listed below is not the model of floormate that I have. When I would try to type Hoover Floormate Plus H3010 it would tell me to enter a valid product.
  • 36 Answers
It seems to be a common problem with this series of floormate... some home quickfixes (a hassle, i kno) but put downward pressure while using the solution.... Check your warranty that came with it, and how long you purchased the floormate... Alot of vaccuums come with 30-90 warranties, I'd recommend having it checked out. That, or if u bought it recent enough,take it back... like i said, these models are unfortunately known to have this problem... Some people have ones that operate normally, but alot do not. >.<
Posted on Jan 09, 2008
Ihave a hoover h3010 it doesnt let out water or pickup water had for many years need help on what can be wrong and parts needed to fix my problem
Posted on Sep 09, 2010
My floor mate won't dispense liquid onto the floor
make sure the solution tank is on properly this link is for the manual
http://hoover.com/file/683/
Aug 04, 2012 | Hoover H3010 Upright Wet/Dry Vacuum
Can I use the Vacum cleaner for floors only without using the liquid. I do not want to wet the floors just sweep the dust away. I cannot find my manual.
first off your manual is right here....
http://www.hoover.com/pdfs/manuals/H3000.pdf
But more to answer your question, yes you can use it on the floor without the wet. You will want to turn your brush switch to the off position. Also, do not fill the water tank or press the spray lever for dry pick up only.
Hope this helps.
Nov 05, 2010 | Hoover Floormate H3000 Upright Wet/Dry...
Cleaning solution will not dispense
After sitting for a period of time, some of the solution may have dried in the inner walls of the feed tube from the solution tank. What I would suggest is to empty the solution tank and then fill it with hot tap water, put it back on the Floormate, and hold the solution "feed lever" on until it starts dripping water. The hot water will hopefully disolve the dried solution and allow it to flow again.
I hope this helps! :)
Sep 22, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Troubleshoot floormate spinscrub 800 floor cleaner
The brushes are not designed to scub the floor, they only lightly touch the floor. Make sure the front nozzle is put on correcdtly. Make sure your filter is dry and clean. I wet filter will give poor suction down to the nozzel. Down load the manuel at Hoover.com. The model is located on the back of the unit. H3000, or H3010
May 24, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Need schematic to replace detergent distributor on Hoover Floormate H3010
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=825293
Generic problem for all Vacuums
Posted by blars on July 23, 2008
Need schematic to replace detergent distributor on Hoover FloorMate H3010
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. You can contact the Hoover Cust Serv website or phone # and they will be able to send you out a schematic on your Hoover FloorMate H3010. the website address and phone 3 are listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 23, 2008 | Vacuums
Hoover 3010 FloorMate Plus not dispensing liquid
With the tank off, can you see if the rod in the handle is hitting the spot where the tank sits on, if not then there is a problem in the handle. If it is, then the reservior asm may be bad, it is what the tank sits on.
Jun 14, 2008 | Hoover H3030 FloorMate SpinScrub 500...
Floormate not picking up liquid at all
you may need new brushes and check sqweege in front.Also clean injecters for cleaner at bottom of unit.
Sep 04, 2007 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover floormate problem
I found a solution posted by someone elsewhere on this website. Try doing a search for Hoover Floormate H3000... The posted solution is as follows:
Remove the liquid dispenser and set it aside. Locate the plastic "plunger" piece in the machine that is surrounded by a black rubber circle (the one on my machine is blue/grey in color...). Place a small drop of hot glue on top of this plastic "plunger" piece and let it dry. Replace the liquid dispenser and test the machine. This solved my problem and my machine dispenses liquid properly again!
I really appreciate the original poster who posted this simple solution.
Aug 16, 2007 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover Floormate SpinScrub won't dispense cleaning liquid
I had the same problem and was preparing to take it back, the last thing I tried was to 'reseat' the handle -- I removed it then snapped it very firmly back into place. That did it, it's working beautifully now!
Nov 25, 2006 | Hoover H3030 FloorMate SpinScrub 500...
Hoover FloorMATE 3000 won't dispense cleaning solution.
I had the same problem with my Hoover Floormate H3000 and found the solution elsewhere on this website. Try doing a search for Hoover Floormate H3000. The posted solution is basically as follows:
Remove the liquid dispenser tank and set it aside. Look into the cavity of the machine where the tank attaches and find the plastic "plunger" piece (the one on my machine is a blue/grey color) that is surrounded by a black rubber circle. Put a small drop of hot glue on the tip of this plastic "plunger" piece and let it harden. Replace the liquid dispenser tank and try the machine again. My machine dispensed liquid properly after this fix-it.
I really appreciate the poster who provided this simple solution!
Nov 19, 2006 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover H3030 FloorMate SpinScrub 500 Upright Wet/Dry Vacuum Logo
1,018 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
