Question about Canon Pixma iP6000D InkJet Photo Printer
The yellow print head is not working. I have replaced the ink cartridge, performed the cleaning and performed the deep cleaning. Yellow is still not showing up on the test sheet.
    President:
  • 787 Answers
Try unclogging manually.Warning!!! Next steps may can make your print head not unusable.
Open the cover and first remove the ink cartridges.Then open the holder and remove the print head.Run hot tap water and put the print head with the nozzles up to stream water.Hold that 5 mins then turn the print head around with the nozzles down.Hold that for every color of 5 mins.Then put the print head in hot water with the nozzles down.Left it water about 15 mins and then you must very nice to dry.When the print head dry put it in printer and start cleaning.If this not help you need to replace the print head.It's part number is QY6-0050.
Posted on Nov 16, 2009
The printer is recognising that the Yellow is full but when I print out a test page the yellow doesn't print. Is this a printer or cartridge issue?
try to do deep head cleaning, few times. If this doesn't helps you need to remove the ink's and print head and bottom of print head ( where are ink nozzles ) few times press on wet cloath.
Then repeat the deep cleaning.
Aug 04, 2011 | Canon PIXMA iP4000R InkJet Printer
I have a Cannon i550 printer that does not print from the yellow port. Have done alignment, clean ports, both choices, and still does not print yellow. And yes there is ink in the cartridgy. Any...
Perform print head deep cleaning from the printer driver.
1. Right-click the printer icon, and then select 'Properties'.
2. Click the 'Maintenance' tab, and then click 'Deep Cleaning'.
maintdeep.jpg 3. Select the nozzles that need to be cleaned and click 'OK'.
4. Read the message displayed, and then click 'OK'. The power lamp blinks and print head deep cleaning starts. (Do not perform any other operations until print head deep cleaning is complete. Print head deep cleaning takes about 1 minute.)
Oct 04, 2008 | Cannon Office Equipment & Supplies
Yellow won't print
First try to replace the yellow toner cartridge. After that, try re-seating the cartridge (take out the cartridge and place it back in carefully making sure it is seated correctly). If this does not resolve the issue, clean the print heads and connections on the cartridge. This can be done by removing the cartridge and swabbing the connections with a Q-tip dipped in rubbing alcohol. Also, while the cartridge is removed, swab the connections to the cartridge that are inside the printer where the cartridge is seated.
May 09, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
I have cleaned and deep cleaned the printer a number of times but when I do a print check the yellow line does not print neither does the black line under it print. When I print anything else the yellow...
If a line doesn't print, the ink is out of the cartridge for that inkjet cartridge color. Replace the cartridge. Deep cleaning can use a lot of ink up at a time.
Nov 11, 2010 | Canon Pixma iP4500 InkJet Printer
Just changed the yellow cartridge. The printer says it's full. No ink. Same thing with last cartridge. Tried deep cleaning.
Ok I understand the printer says its full but are you saying your computer says no ink? or that it prints no yellow ink?
Ok assuming you mean that it prints no yellow ink, the culprit ususally means that the print head needs replacing! Call Canon with your model and you can buy the part for new print heads for your printer
Mar 16, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Canon Pixma yellow color problem
Either the ink you are using is not going to give the color you want, or you have print heads that are blocked.
Mar 11, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Canon pixma mp830 not printing yellow.
This just started happening to me also, I have been using the printer without issue for a few years. Replaced the yellow cartride, still no yellow. Anybody else seeing this?
Feb 23, 2010 | Canon PIXMA MP830 All-In-One InkJet...
HP Photosmart 3210xi - some colors (magentas) will not print
Remove the magenta cartridge, and try cleaning the head with alcohol, maybe with a small paint brush or an acid brush. It sounds like ink has dried and plugged up that head.
Jun 04, 2017 | HP Photosmart 3210 All-In-One InkJet...
Cannon mp830 prints all colors but yellow
Your print head is likely toast.
The only way to be sure is to test out your purge unit (aka capping assembly).
This assembly provides the suction when you use the cleaning function. One test is simply to install a new oem ink cartridge, do a bunch of cleanings and see that it is actually emptying the ink out of the cartridge (look in the cartridge and see that the ink is being used up).
Since you said you have tried several cartridges, I would hope this means you know 100% for sure that the ink level in the cartridge is going down (you cannot rely on the level indicator in your driver software).
Since your purge unit is working, then your print head is either so clogged that the purge unit isn't strong enough to clean it, or the print head is defective.
Remove the print head and inspect the bottom. Give the bottom surface (and no more) a rinse under very hot running water. Blot the bottom surface on paper towel and see if there is any yellow ink coming off in the paper towel. If you can find a tube that will fit over the yellow ink well in the print head (the part that contacts the ink cartridge) try and force water through the tube and see if a fine mist comes out the bottom of the print head. If yes, then the head is not clogged. If no, leave the print head to soak for several hours. A saucer with a small amount of water in it will do. Just let the bottom surface of the print head contact the water (the cap off of a can of spray paint usually works for this)
Let the print surface soak for a few hours, or even over night. Reinstall the print head and give it a deep clean. If it still does not work, call your local Canon repair shop and check the price of a replacement head.
Nov 04, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon Pixma iP6000D InkJet Photo Printer Logo
297 people viewed this question
old marine
old marine
