Question about Sony Ericsson w580i Cellular Phone
Won't turn on ...I change the sim card and the phone is not turning on..you can see the red light blinking on the side when you push the on/off switch or connect the charger but that's all...
My phone is sony ericsson xperia x10 mini pro, i have kept it for charging after few minutes red color light is blinking and it is not turning on, i have tried removing battery, sim and memory card, but...
My phone is sony ericsson xperia x10 mini pro, i have kept it for charging after few minutes red color light is blinking and it is not turning on, i have tried removing battery, sim and memory card, but still th problem is same. please help me
Oct 03, 2010 | Sony Ericsson XPERIA X10 Cell Phone
My nokia 6300 phone won't turn on
it is not a issue with battery or sim card. It can be issue with display or software. Go to nokia showroom and check with them once.
May 10, 2010 | Nokia 6700 Classic Cell Phone
Phone wont turn on
Use a volt meter (may try one at radio shack) to see if there is any voltage in the battery. Damaged batterys will sometimes short and the meter will tell if you need a new battery.
Aug 11, 2009 | Sony Ericsson Walkman W810i Cellular Phone
Phone wont turn on it just blinks red
just connect your handset using datacable to your pc or laptop and then install desktop maanager and take a backup of your handset and reinstall your operating system.
Aug 11, 2009 | RIM BlackBerry Pearl 8100
My Sony Ericsson K770i is no longer working
I had the same problem, but I got the solution
...just use XS++ or SE_Tool2.. to flash the rom.. . and everything will be ok
Apr 07, 2009 | Sony Ericsson K770i Purple 3G Camera...
I can't turn off my Samsung SGH - D880
Yesterday I also got the same problem on Samsung DUOS SGH-D780!
I found temporary solution how to drop this error message and run the phone normally, but after next reboot it often become again. I will ask Samsung tech. support about this, but now here is the emergency solution:
1. Turn OFF the phone (by removing the battery)
2. Move out all the SIM cards from the phone
3. Insert the battery again (BUT DON'T TURN ON THE PHONE, just insert the battery)
4. Insert a charging cable into the phone and insert the adapter in wall outlet
(then I see the loading screen for the short time and after that CHARGING icon appears)
5. After that turn ON the phone. It will start in no-sim mode.
6. Turn OFF the phone
7. Remove battery, insert SIM-cards, insert the battery.
8. Turn ON the phone
After that it gonna be work good until next reloading...
Feb 27, 2009 | Samsung D880 Cellular Phone
....motorola v3xx won;t turned ON!!..HELP
Have you tried replacing the battery? Also try this first - remov battery and SIM card. Wait 1 minute. Replace battery and SIM and power on. See if that helps.
If problem persists, you may have to repair the phone.
Oct 25, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
It still doesnt work..
Try resetting your phone to factory settings. It's recommended that you turn off the PIN number and the Security number (12345 if you didn't change it) For Pin and Security go to:
Menu/Tools/Settings/General/Security/Phone and SIM card, Certificate management, or Security module.
For Reset go to:
Factory settings.
It should work, but it might clear all your stored data.
Feb 20, 2008 | Nokia N95 Cellular Phone
Sony Ericsson w580i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
