Question about Karcher 1201 Canister Vacuum
I have just used the karcher steam cleaner and now cannot get the safety top off. Rio
You need to even the canister pressure. Release the valve from the handheld device, i.e. it needs to be plugged in and pressed. Presure also exists at room temp.
Posted on Jul 24, 2010
I cannot get the cap off my karcher sc1122 even though its cooled down
Posted on Apr 15, 2010
Where can I purchase a safety filler cap?
See Google.
[PDF]steam cleaner - Pdfstream.manualsonline.com
pdfstream.manualsonline.com/.../e7f63cef-798e-41f3-bec7-5e43d5da5d...
When using your Steam Cleaner basic safety precautions should always be ... not screw the safety/filler cap onto the .... When using the Ultra Steam Shark II with.
Sep 29, 2015 | Shark Ultra Steam-blaster Hard Surface...
Karcher sc 952 having problems with no steam coming out.
this machine uses an electrical solenoid to open the flow of steam from the heater..... the switch is in the hand trigger and the valve on the machine.... one of these is at fault
If you have a Karcher then you should always post your machines barcode.
The karcher barcode is on a silver sticker and is usually 15 digits long. Example 156987400000123 is actually model 1.569-874.0 and serial number 00123....
Aug 04, 2013 | Karcher DE4002 Steam Vacuum
Cant remove safety valve cap
use some WD-40 oil and spray for to loose the valve cap, wait about for 20 minutes. and then proof.
God bless you
Jul 10, 2012 | Vacuums
DE4002 Steam Vacuum: Is there a manual for The Karcher DE4002 steam cle...
Hi There,
Here's a link to the owners manual for your Karcher DE4002.
If you found this information helpful, please be sure to rate the repair helpful, or leave feedback. This is really appreciated.
Owners Manual For Karcher DE4002 Steam Cleaner
May 05, 2010 | Karcher DE4002 Steam Vacuum
Karcher SC 1502 steam cleaner can't get cap off water tank
Dear jrider784,
I solved a problem like this on FIXYA, just a few months ago. I gave this solution. Try to fill the machine from somewhere else. You can do this from the outlet. If you manage to do this, put on the machine. ( now you know that when there is hot water in the machine, the tap goes round free for safety). Now as the water starts to cool down....start trying to see if you can unscrew it. My plan is that with the hot water, the safety will start to work again. If the cap does not release the safety on cooling, then there is no other way but to destroy the cap and replace with a new one. Very important to mention that this job must be done by a qualified technician or some one who knows what he is doing. Working with hot water is very dangerous.
Regards,
Fulltech.
Jul 27, 2009 | Karcher DE4002 Steam Vacuum
HOOVER F7430-900 STEAM VAC
I recommend to use the same detergent that came with the machine. Some detergents can cause problems such as damaging seals and causing build up. Hope this helps, post back.
Jun 23, 2008 | Karcher DE4002 Steam Vacuum
Wont heat up
I know that Karchers steam cleaners have had issues with the thermal overload. I have repaired Karcher machines that got turned on with no to little water in the tank and it would heat up really fast and trip the thermal overload. The thermal overload is to reset it self when it cools down but the problem has been the thermal overloads get stuck and dont reset. When they stick, they will give the same signs you have said. In those cases the thermal overload has needed replaced. The thermal overload did its job to trip, but it fails when reseting. I understand you don't want to throw more money into it, but that is the only thing you can do. You can get the part and do it your self, but they are tricky machines to get into and you dont want to break something trying to get in. Hope this helped.
Mar 25, 2008 | Karcher DE4002 Steam Vacuum
Vacuums Logo
1,458 people viewed this question
Top Karcher Vacuums Experts
richie46
Are you a Karcher Vacuum Expert? Answer questions, earn points and help others
