Question about Motorola Mobility RAZR V3
It switches on and off and asks me for my sim pin but other buttons dont work
Get me a new security code of nokia 7210
The PUK code is not related to the handset. It is associated with your SIM card. When you enable the PIN in your SIM card, every time you switch on your phone, you will be asked for your pin. At given number of tries provided by your mobile operator, that you have provided the wrong PIN (usually operators set it at 3 tries), then you came to the stage called PUK-blocked.
To unlock, you would need the PUK code of the SIM card. The PUK code is usually an 8-digit code. This PUK code should have been provided to you when you purchased your SIM card. Some has the PIN-PUK code printed in the card body of the SIM card, while some attach it as a separate print out. Should your operator failed to provide this PIN-PUK code to you, you would have to get it from your operator. Try calling their customer service. Just like the PIN, the operator as well could say how much tries do you have to successfully unblock the PUK of your SIM .
Mar 14, 2011 | Nokia 1100
I jus locked my lg vu i dont know what the PUK code is
Mar 05, 2011 | LG Cell Phones
Hello i dont know what to do my phone says "sim unavailable please contact service provider" after i entered the puk code two many times!
This is a simple issue don't worry.First please remove the battery and remove the SIM card and see weather it is being damaged or you can see scratches on the gold plating.Take some cotton and dip it on kerosene and clean it nicely on the edges of the gold plating of the SIM card..Now place it correctly and switch on the phone.Some time loose contact may cause this problem and scratches too....If
still the problem persist check with other Sim card of your friends or family members..
If other SIM card is work's fine then it your SIM card must be replaced by your service provider.Ask him for a free replace..else the Sim card
connector is damaged you have to solder or replace it.If you don't have any hands on,take it to nearest service center.
If the above problem got solved and if it asks for PUK or PIN no follow this:
Please don't try more than 3 times.If you try more than 3 times the Sim will get locked.And it will ask for PIN code.Both these PUK and PIN code can be given only by the network service provider. Please call the network service provider of your mobile.And ask him to provide the PUK code or PIN code.He will ask you some basic details like name,date of birth for his verification.And he will provide you the PUK and PIN code.This is done for free of cost.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
thank you for using fixya have a nice day:-)
Aug 07, 2010 | Cell Phones
Nokia N 70 - Error - 'Sim Card Rejected'
IF you put PUK code many times depending on the model it wil lock the sim card. This is because to prevent unathorised person using your SIM card.
Default PIN code for nokia mobile is 0000
PUK code will be given by the service provider only.
Please call your service provider or go to service provider office,they will assist you in this issue.And they will have a security check like name,Phone number and other information to check weather the SIM card belongs to you only.Then they will assit you.
Thanx
Jul 23, 2010 | Nokia N70 Cellular Phone
I have nokia 1200.my bsnl sim pin blocked.how can find puk code
call to your sim card costumer care and they will give you right pin to crack that pin blocked and you dont have to pay anything for ask to costumer care about your puk code. remember dont put any number which make your sim blocked.
Thanks
May 19, 2010 | Nokia N70 Cellular Phone
I enter in my sim pin to change it but it won't let me change the
Switch your phone off,and switch on,
Then wait for about 5-10 minutes, and retype your pin again.
If not working,Go back to your sim pack where you cut out your sim from and check for puk number.
Type in type in the puk number,then it will ask you to type in new pin, and after it will ask you to type your new pin again then,you can start using your sim again.take care.
Jan 21, 2010 | Motorola Mobility RAZR V3
Code problem
You'll have to call T-Mobile customer support to get the PUK number for your SIM. After its unlocked, you'll have the opportunity to reset the PIN, the default of which is 0000
Jun 29, 2009 | T-Mobile Sidekick II
My sim won't work without d puk code
hey
the puk code prompt comes up when you have entered the pin code wrong 3 times.
to get the puk code you need to call your phone service provider, the will give it to you, if you try to gess the puk code wrong too many times it will make your ssim card useless, so get the right code from your provider, they are the only ones that have it.
after the puk code it will ask you to enter a new pin code and then confirm the pin code. then the sim will work normally and ask for pin again next time instead of puk, puk will come again if you enter pin wrong 3 times.
Jun 02, 2009 | Nokia 6600
I dont know what my PUK codes is
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
The PUK code is asked if you enter a wrong pin 3 times.
You need to call the phone company that released the SIM card, they can retrieve the puk code from a database for free.
In your case you need to contact your SIM card provider technical support to unlock the SIM.
The PIN and PUK are related to the SIM card, not to the phone.
If you replace the SIM card with a different one, then the phone will not ask for the PUK anymore.
Mar 17, 2009 | LG Vu CU920 Cellular Phone
Sim card missing for htc touch p3450
its a hard ware issue try putting a piece of paper over ur sim card to press it against the pins on the phone sometimes it gets loosen and does not detect sim cards or try restting the device as follows else go for service centre help but try these solutions first
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
Feb 16, 2009 | HTC Touch P3450 Smartphone
Motorola Mobility RAZR V3 Logo
631 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
