Question about Acer Aspire One Netbook 8.9" Notebook
I cannot load windows. it carries out disc checking without success. it will not allow me to reload to earlier settings or safe mode
sri2008
  • 53 Answers
SOURCE: Windows did not start successfully.
hi asharah,
Ur operatibg system was corrupted ,u reinstall the operating system (xp ) .
Pl try it
Regards
Was this soultion useful? give the appericiation by rating it.
Posted on Mar 28, 2008
efs_perpends
  • 1996 Answers
SOURCE: It turns on then restarts when windows in loading...
Here are a few options;
If you decide to do a repair installation, make sure you have backups of your data incase something goes wrong..
http://www.microsoft.com/windowsxp/using/setup/support/nostart.mspx
http://www.microsoft.com/windowsxp/using/helpandsupport/learnmore/tips/doug92.mspx
http://pcsupport.about.com/od/operatingsystems/ss/instxprepair1.htm
or you could try to rebild the boot config:
http://support.microsoft.com/kb/330184
http://support.microsoft.com/kb/291980/
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Posted on Apr 16, 2009
sharky633
  • 510 Answers
SOURCE: windows will not boot on acer 5315 notebook
As the unit will not boot at, i am afraid you are going to have to do a recovery which will also wipe any data on the notebook.
To run a recovery make sure it is powered off then power on, as soon as you power on you must tap the left Alt + F10 keys together at the same time, now timing is important and can take several attempts before you enter the recovery manager. Keep tapping the keys at approx every half a second or so and wait for a message at the bottom of the screen which will state " Windows is loading files" then you can stop tapping. A new screen may appear after that which will state " edit windows boot options: for windows setup or it may say acer e-recovery" if this screen appears then simply press the enter key, you will then enter the Acer e-recovery manager which will then ask you "How would you like to restore?" select the first option for a factory default reset, hope this helps.
Sharky
Posted on Jul 05, 2009
SOURCE: Aspire ZG5 Won't Complete Boot Process
Hello Dzaitz,
A description of the error message: http://aumha.org/a/stop.php#0x21a
Basically, Windows' security has been compromised - so it won't work until you fix the security issue.
The "0xc0000005" part means that the error occurred in your memory. Most likely this was either caused by the power outage or malware. If the power outage caused it, there may be other damage that isn't obvious at this point.
Since you can't boot into Windows, your choices are a bit limited.
First, I'd suggest that you run this free, bootable memory diagnostic: http://www.memtest86.com/
As a "just to be sure" measure, I'd also run a free, bootable hard drive diagnostic (available at the support website for the manufacturer of your hard drive).
If you pass those 2 tests, then I'd suggest a repair installation of Windows XP. If you have Internet Explorer 7 installed, read this first: http://support.microsoft.com/?kbid=917964. Then the instructions for the repair install are located here: http://www.michaelstevenstech.com/XPrepairinstall.htm
Post back with any more questions or comments for additional assistance. Thank you for choosing Fixya!
Posted on Jul 14, 2009
sfender713
  • 397 Answers
SOURCE: acer aspire 6530 will not run windows vista, will
When your computer is first booting, try tapping F12 to get to the boot menu. Once there, boot from the Vista installation disk- you may need to fully reinstall windows from that point. Try doing a repair first- if that does not work, do a full reinstall.
Posted on Oct 03, 2010
My acer netbook (winxp) won't load after the mouse cursor appeared
Sounds like you need to run the check disk utiltity but since you don't have a CD Drive, you're up the creek without a paddle. try booting up into Safe Mode and if you get there successfully reboot and see if the normal mode works, if not you can uninstall Microsoft Security Essential in Safe mode. Or you can use System Restore to restore back to a point (date and time) when the system was working ok. Click Start/Programs/Accessories/System Tools/System Restore and select a restore point before you loaded Security Essentials. In Windows 7 just click Start then type System Restore in the search box above the start then look at the returned results and click System Restore.
System Restore does not lose any of your data, documents, music, pictures, videos or programs (unless the programs was installed after the date and time you selected).
To get into safe mode follow the steps below:
Turn off the computer, then hit the power button to turn it back on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Take the Safe Mode option and let it boot up. Safe Mode will look different to you, the screen will be darker and the icons bigger, this is normal.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
You can try to get to a dos command prompt or you can see if the system will allow you to boot in Safe Mode to get to the dos command prompt.
May 12, 2012 | Computers & Internet
I want my monitor to work once again because it says cannot display video mode? i dont understand help me?
You didn't say which OS you're running. However, it looks like you need to restart your computer in safe mode. This URL explains how to get in safe mode. When the computer boots the video it will look a bit grainy and you won't be able to see the entire desktop without using the scroll bars.
Both XP and Vista don't allow you to perform such an operation through the regular procedure and, as a result, you will only be able to get a screen resolution of 800×600 with the consequence that some icons and programs won't be displayed correctly. This is because Safe Mode just loads only basic services and drivers which are strictly necessary for Windows to run.
Fortunately, by employing the following techniques, you can get around this restriction permitting you to get whatever screen resolution you want.
Windows XP:
  1. Right click on your desktop.
  2. Click Properties.
  3. Click the Settings tab.
  4. Under Screen Resolution, drag the pointer to the right (where higher resolutions are located).
  5. Click Advanced.
  6. On the new window click OK, without modifying anything.
  7. Done, you should have successfully changed the resolution settings.
Windows Vista:
  2. Click Personalize.
  3. Click Display Settings.
  4. Under Resolution, drag the pointer to the right (where higher resolutions are located).
  5. Click Advanced Settings.
  7. Done, you should have successfully change the resolution settings.
Aug 11, 2011 | Dell 1503FP 15" LCD Monitor
Blue screen says error loading,dont know how to recover with safe mode or how to activate safe mode.it is a think pad t20
Hi,well these should work for you,to get to safe mode,power up the system as the IBM thinkpad logo is about to be displayed press the F8 key just before the Windows loading screen comes up so as to get to safe mode.if it does not work try reloading the operating system using operating system disc.
Dec 20, 2010 | IBM ThinkPad T20 2647 Notebook
Computer starts up windows to screensaver and goes no further. There is no start menu and cannot start it in safe mode.
by screen saver, Im assuming you mean the desktop wallpaper. (screen saver is the program that comes up and shows pictures moving around, or stars flying by, or pictures of pipes building some over-rebuilt plumbing in outer space). Whats going on is, your Windows shell (Explorer.exe) is not loading. that is almost ALWAYS caused by a virus. If you cannot load in safe mode, you may not be able to recover that system without a professional. If there is nothing of major importance on that drive, I suggest you gather your OS discs and your drivers and application discs and reformat and reload.Based on what you describe, your explorer cannot load and cannot process because of an infected file being loaded during startup.
Oct 26, 2009 | Dell Dimension 2400 PC Desktop
My gateway laptop stays on the windows xp loading screen after turning it on and just carries on loading friends of mine say it could be the hard drive
NO ITS NOT THE HARD DRIVE ITS JUST A MINOR PROBLEM WITH OPERATING SYSTEM INSTALLED IN UR LAPTOP
PLZ REINSTALL UR OS 1CE AGAIN IT WILL B FASTER
Aug 25, 2009 | Computers & Internet
Gateway laptop mx3414-black screen cannot load windows
Try going into safe mode upon startup by hitting the F8 button. If it does then hit safe mode to get into your computer. Go to start>accessories>system tools>system restore. Follow the wizard to restore your computer to a date earlier than when you started having problems. Let me know if you have any problems or questions.
Mar 19, 2009 | Gateway MX3414 Notebook
Can you help? Have a Advent 7096 laptop protected by PC Angel. Have run system recovery using 4 discs. Cannot get into Windows - message reads "load needed dll's for kernel" Not my machine but...
If you having problem running system recovery in normal mode try running system recovery in Safe Mode by pressing F8 key when you turn on the laptop.. a selection pop-up, select your primary hard disk where your windows installed still pressing F8 then a Boot Selection appear select Safe Mode after starting in Safe mode do the system recovery.. still not working choice the Last Good Configuration. TY
HOPE I CAN HELP
Dec 04, 2008 | Computers & Internet
Emachines E4062 I keep getting , We oppoligise for the inconvenience but windows did not start successfully. And it keeps doing the same over and over again .
Try starting it in Safe Mode by pressing F8 as the computer boots and selecting Safe Mode. If this allows you to do this then you will be able to restore your computer to an earlier time when you know it was working without any problems.
If the computer boots in safe mode, everything will look bigger on the screen, don't worry about that for now. Click on Start>programs>accessories>system tools>system restore and choose a date when you know your computer was working without any problems and click on restore. Once this has been accomplished the computer will restart. If asked choose start winows normally.
Hopefully this will resolve your problem
Oct 31, 2008 | Computers & Internet
Problem
If you can boot to safe mode, try doing a restore.
When you turn on the system, just past the POST (before windows loads), hit the F8 key to get the menu between normal boot and safe mode.
When prompted, select SAFE MODE. Don't select safe mode with command prompt, or with networking. Just SAFE MODE.
Use the arrow keys to select SAFE MODE. If you need to log in, do so and proceed to launch windows.
Windows should launch in Safe mode. If it does, proceed to click on START, ALL PROGRAMS, ACCESSORIES, SYSTEM TOOLS, SYSTEM RESTORE.
Select RESTORE MY COMPUTER TO AN EARLIER TIME. Click on NEXT. If you can, select a BOLD date preferably before your issue. Click NEXT. System will load some files, reboot and reload.
If you can't get to safe mode, there may be other problems holding your system up. Did you load anything prior to the messages?
Aug 10, 2008 | IBM ThinkPad T23 2647 Notebook
6480iPTD notebook- boot problem
Video drivers not loaded for that laptop, in safe mode reload the video drivers.
Jan 26, 2008 | KDS Valiant 6480iPTD Notebook
Acer Aspire One Netbook 8.9" Notebook Logo
23 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
