Question about HP Pavilion Media Center a1330n - AMD Athlon 64 2.4GHz Desktop Computer (Open Box Product, Limited Avai... (EL466AAABAOB)
Cd put in drive, is stuck and will not open. Have
Cd put in drive, is stuck and will not open. Have tried the eject under control panel and a paperclip in hole under drive door.
  • 863 Answers
Power down.  Now power back up and press the eject button at the top of the keyboard and hold until disc ejects.  If that don't work, then you gonna have to open this thing up and physically take the disc out cause something is blocking it from ejecting.
Posted on Nov 16, 2009
Dvd drive door stuck
In case you're not able to eject the disc using the eject button, you can try right clicking on the CD/DVD drive under 'My Computer' and clicking on eject. If that fails as well, you can try to eject the disc manually by pushing a straightened paper clip or a pin into the tiny hole on front of the CD/DVD drive. You should be able to eject it using the last method.
GuruAid.com
May 31, 2014 | Gateway 830GM PC Desktop
Cd stuck in mac laptop
A few ways of doing this
1) restart mac and press down the trackpad button after you hear the startup noise
2) if that does not work try opening up disk utility and click on the icon of your disk under the left hand column then go up to eject button and click eject
3) or open up terminal found in the utilities folder within your applications folder and then type in
drutil tray eject and then press return
4) Finally what to do is try pick up your macbook tilt the
imac to the one side and press the eject key and hopefully the effect of gravity will allow the CD to fall out.
However, I would say that DVD drives in all macs are a bit suspect and if
your macbook is still under warranty or under AppleCare take it back to the Apple Store and tell them that the DVD drive is faulty and they should replace it free off charge.
Feb 18, 2013 | Apple MACBOOK PRO 13 INCH NOTEBOOK 24 GHz...
I don't know how to open the CD compartment on this laptop.
Open My Computer, right click on the icon for the cd unit and click Eject.
Dec 04, 2010 | Dell Latitude D600 Notebook
Dell Studio 15, CD stuck in slot
remove drive out there's 4 screws below drive remove them, you should be able to open drive in 2 bits remove cd put all back together ;)
you may have 1 or 2 more screws just remove them to open drive in 2.
www.e-repairs.co.uk
Jul 04, 2009 | Dell Studio 15 Laptop
Cd drive will not eject or run any software
Place your laptop on a flat surface always. It give some tilt on already cramp space on the cd drive.It could make disc hit something inside to make it stuck so it will not spin and read. It also misaligned mechanism inside the drive to make a full eject.
Apr 08, 2009 | E-Machines emachines (emachinees) CD-ROM...
CD/DVD drive stuck CLOSED and NO pin hole
Use my computer and select the drive (eg drive E:). From pull down menu "File" select "eject". While the disk door attempts to open (hear slight movement of tray) massage the door with your fingers. This is done by smoothing out the across front door panel with your finger tips and pushing in and releasing pressure from door. Door should slide open partially and close again. Repeat. The eject button nearside the disc tray doesn't seem to work as well as selecting "File" and "Eject" from the menu. Something to do with the door cycle is less with the direct eject button.
Jan 28, 2009 | Zenith Data Systems Zenith (OP-260-74501)...
CD will not eject from drive
image1-main_full.jpg Hi Gerald,
There is nothing wrong with Files or Windows Xp, your CD-DRIVE is stuck. There is a small whole on front panel of the Drive, try to put a long needle in it to get shutter out. Alternatively you can take help of any hardware professional, it will take only 2-3 mins.
Thanks
Zulfikar Ali
Jan 27, 2009 | Roxio Computers & Internet
I have a Gateway 300x Micro-Tower case circa 2002 and I can not open the case, without breaking it. I'm trying to install a new audio card and can't get at the 300x innards. Help!
Most of these towers are vertical style, therefore the big button is just to the left of the Gateway symbol. Push it in and pull the left panel away from the case.
Jan 11, 2009 | Computers & Internet
CD driver stuck
In the front side of the dvd drive you will see a small hole ...so to eject that cd put one niddle in that hole and .
Now press the button at just after that apply a force on niddle .suddenly you will notice that cd will come outside ,if not try more times and you will learn to eject the cd when you are unable to do it by pressing the eject button...
Low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not.
Thanks
Dilip Bagdi
Technical Associate
Dec 06, 2007 | Dell INSPIRON 6000 CENTRINO...
Cd ejection
Reset this unit by pressing and holding the power/ATT and SEL buttons at the same time for several seconds.
Mar 13, 2007 | JVC KD-S680 CD Player
Computers & Internet Logo
166 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
