Question about Amcor 3900 GPS Receiver
The sound just quit working all setting on for sound and alerts is there a mute button or some thing else
  • tevans958 Nov 16, 2009
    What sofetware? the disc that came with?
    What software ? is it the disc that came with it?
Need sofwere
Posted on Nov 16, 2009
HOW DO I TURN ON THE AUTO MUTE ON A COBRA ESD 8285
When changing the Settings on your detector, please keep in mind: Each time the unit is turned On the factory settings of Highway and Auto Mute-On will be set. They can be changed while the unit is in use as described in the following sections.
Assistance Muting An Alert
Your detector allows you to quickly turn Off an audio Alert by momentarily pressing the Mute button. If you press the Mute button a second time during the Alert, the audio Alert will be turned back On.
Auto Mute Mode Auto Mute will automatically reduce the audio volume of all alerts after four (4) seconds for as long as the signal is detected. The factory setting for Auto Mute is On.
Highway/City Mode Setting your detector to City mode delays all X band audio alerts at lower signal strength levels. (A single beep will sound when the signal is first Notice detected.) This will reduce false alerts while you are driving in, or near, urban areas where there are many sources for conflicting X band signals such as microwave towers and automatic door openers. To change settings, follow the procedure listed below, which indicates what you will see and hear as you complete each step. The factory setting is Highway mode.
Highway Mode City Mode
Mute Button Press and release
To Turn Auto Mute Off X Ka L S
City Button Press and release
Press and release the Mute button while no alert is occurring.
Jan 27, 2016 | ESD-8285 Radar Detector
Tip
How to Troubleshoot a Mac Computer With No Sound
When troubleshooting sound problems on Macs, you can find thefix quickly if you isolate the possible problems first. Regardless of youroperating system, it will make things easier if you can narrow down thepossible points of failure by momentarily unplugging any sound devices.Following simple change of sound settings and testing internal sound alerts canfix the problem.Instructions<br />1.<span> </span>GeneralTroubleshooting<br /> <ol> <ul> <li>1 </li></ul></ol> Launch iTunes or another media player applicationand have it play continuously to start troubleshooting. Make sure the volume isnot muted or disabled. Move the volume slider on the menu bar up and down. Youcan also use the keyboard's Increase and Decrease volume buttons (usually F4 todecrease and F5 to increase the volume). <ol> <ul> <li>2 </li></ul></ol> Unplug any headphones that might be connected toyour computer's headphones port. If your <a href="http://www.ehow.com/computers/">computer</a> has internal speakers,unplug any external speaker plugged to the audio port to isolate the problem.Check if sound is working properly through the internal speakers. <ol> <ul> <li>3 </li></ul></ol> Go to System Preferences on your Mac menu. Clickon the ''Sound'' icon, under the Hardware section. The Sound settings pagedisplays three main buttons: ''Sound Effects," ''Output" and''Input." Click on the ''Output'' tab. Select the ''Internal Speakers,Built-in Output'' option, and raise the ''Output Volume'' at the bottom of thatwindow. Check if sound is working properly. <ol> <ul> <li>4 </li></ul></ol> Go to the ''Sound Effects'' tab, and make sure the''Alert'' and ''Output'' volumes are up and not muted. Select ''InternalSpeakers'' from the ''Play alerts and sound effects through'' drop-down menu.Click on any of the Alert Sounds in the left column and test to see if theysound as you change from one to the other. Check if sound is working properly.2.<span> </span>GaragebandTroubleshooting<br /> <ol> <ul> <li>1 </li></ul></ol> Launch GarageBand. A default piano track willappear. If it doesn't appear, click on the ''Track'' Menu and select ''NewTrack''. Choose a Software Instrument from the dialog box, and then choose aPiano from the selection of Instruments. <ol> <ul> <li>2 </li></ul></ol> Click on "Menu." Select ''Preferences''and click on the Audio/MIDI tab. For Audio Output, and Input select thecorresponding ''Built-In Output'' and ''Built-In Input'' from the drop-downmenus. Confirm the action. <ol> <ul> <li>3 </li></ul></ol> Click on the Piano track. Under the ''Windows''menu bar, select the ''Keyboard'' option, or press [ Command + K ]. A keyboarddisplays. Click on any of the keyboard keys. You should hear sound coming outof your internal speakers.<br />Make sure there is no headphone jack inserted in the computer. If sound doesnot work, try quitting the application and launching it again. <ol> <ul> <li>4 </li></ul></ol> If any of the previous steps do not fix the soundproblem, reboot and try again. <br />If you see a Disabled Volume alert when you try to raise the volume, alsoreboot. This is a known bug in Macs
on Jan 21, 2011 | Computers & Internet
Tip
CUSTOMIZING YOUR PHONE SOUNDS
the samsung sync is a pretty good phone with many options of customization available. problem is, most are hidden. heres how to access them:
1. open phone, and push the side key under the memory card slot. [alternatively, just get to the PROFILE option. in that case, skip 2]
2. scroll over to the 'PROFILE' setting
3. highlight the 'NORMAL' setting, and push the 'OPTIONS' key.
4. go to 'EDIT'. push 'CALL ALERT' and you get a wealth of options.
i will map them out for you too lazy to look through everything:
1.    INCOMING CALL
Call Alert Type:
                [Melody]
                [Increasing Melody]
                [Vibration]
                [Vibration Then Melody]
                [Vibration & Melody]
                [Vibration And Increasing Melody]
                [Mute]
Voice Call Ringtone
                [Takes you to My Stuff, where you can choose a .mmf file to use.]
Ringtone Volume
                [1-7]
Auto Reply
                [Activation OFF/ON]
                [IF ON, THEN REPLY TO SEND]
2.   New Messages
Message Alert Type
                [Melody]
                [Vibtarion]
                [Mute]
Message Alert Tone
                [OPTIONS:
                   [1. USE EFFECT TONE]
                   [2. USE MY ALERT TONE]
Message Alert Repetition
                [Once]
                [Periodic]
Alert Tone Volume
                [1-7]
3. PHONE SOUNDS
Keypad Tone
                [Beep]
                [Clean]
                [Mute]
Power On Type
                [Melody]
                [Vibration]
                [Mute]
Power Off Type
                [Melody]
                [Vibration]
                [Mute]
Folder Open/Close Tone
                [Melody 1]
                [Melody 2]
                [Melody 3]
                [Mute]
Volume, Phone Sounds
                [1-7]
if i missed anything, leave me a message, or email me:  mannyftw [AT] aim [DOT] com
on Oct 27, 2007 | Samsung SYNC SGH-A707 Cellular Phone
Why are there no audio alerts on my Beltronics Express 795 radar detector? The unit powers up and all alert lights work.. I've checked to ensure the "mute" button is off. I bought the unit new years
I know this sounds silly but check and see if you set it to mute. Most detectors have this option either in the set up sequence or by pushing the volume button down.
but see if you accidentally set it to mute. Most detectors allow a mute setting and only light flash. This can b
Nov 10, 2014 | Express 795 Radar Detector
Why did my sound just quit?
Try turning off the device then unplug it then hold the power button in for 10 seconds then plug it in and restart it as a possibility
May 30, 2014 | Haier LEC24B1380 24 inch LED HDTV/DVD...
Sound not working
Try going to SETTINGS > SOUNDS > RINGER AND ALERTS and see if the sliderbar is is turned to mute..you can also set the "CHANGE WITH BUTTONS" toggle to on
Feb 12, 2013 | Apple iPhone 4S
Everything lights up and is working,but i have no sound
Do you accidentally have it muted? The Mute button, located on PASSPORT's top panel and SmartCord. Have you turned up the volume on it? Volume Control (VOL) To increase or decrease the audio volume, press and hold the (+) or (-) volume control buttons located on the top case. A sample alert tone will be generated, along with a corresponding bar-graph on the display. Once you have reached your desired volume level, simply release the button. This level will be stored in memory. In Preferences Auto Volume is the default. This feature will increase the audio alert level automatically when the ambient noise in the vehicle is high. Good luck.
Mar 06, 2011 | Passport 9500i Radar/Laser Detector
Same thing but my laptop is a dv3
1. Have you had sound on this machine before?
2. Have you installed the right driver for your sound card?
3. Have you checked the device manager? Any red or yellow alert there?
Feel free to visit digitalsupporttech for getting help.
Aug 25, 2009 | HP Pavilion dv6000z Notebook
No sound alert on incoming messages in Skype 4
Here is my experience. This drove me nuts for a while but it works now.
I had the same problem with 4.0.0.206. I played around with mute/enable in Options/sound and Options/audio settings. I changed to ringing to my laptop speakers and now it all works. Go figure.
Feb 11, 2009 | Skype IM
Mic has quit working on Quickcam Pro 5000
Did you by chance mute it in the computers sound manager or a specific program (msn, yahoo)? These settings tend to over-ride the Logitech console settings.
Nov 14, 2007 | Logitech QuickCam Pro 5000 Webcam
Amcor 3900 GPS Receiver Logo
Top Amcor GPS Experts
Martin Murray
Donald Ayers-Marsh
Are you an Amcor GPS Expert? Answer questions, earn points and help others
