Question about Cameras
Lens wont go back in, camera wont stay on
The lens is stuck out and when i try to turn the camera on, the light turns on for about 2 seconds and then it turns off and the lens does not go back it like it usually does.  I have already tried changing the batteries 3 different times and I dont know what is wront with it, can you please help me? thanks.
  1. MY CAMERA WON'T TURN ON THE LENS IS STUCK AND THE LIGHT WILL TURN ON BUT IT WON'T STAY ON AND I'VE ALREADY CHANGED THE BATTERIES AND CHARGED THEM CHANGED THE MEMORY CARD TOO NOTHING SEEMS TO BE WORKING PLEASE HELP ME
  • 1 more comment
  • mrscasa Mar 04, 2008
    My lens won't go back in and the screen says "zoom error" I've had it for little over a year and am very dissappointed.
  • Anonymous May 31, 2008
    when i turn camera on it last about a second then sdhuts off,batteries sre good ,i tryed ac same thing.
  • Anonymous Jan 28, 2009
    sam exact problem
This is caused by the BATTERIES insert some top quality one better than durcell .
remove the memory card then do a reset which is the hole next to the trash can button you need a papper clip or a pencil shame the companys gone bust .
hope this helps
steve
Posted on Mar 02, 2009
I have the same problem.This problem comes back so many times on this site, there is no solution anywhere.... Pretty mad for a problem hapening many times.
Posted on Feb 25, 2009
DSC-HX5, Lens is Stuck in Zoom out mode. Turn On works but screen stays black. Automatically turns off after 10-20 seconds.
Since there is nothing you can do to fix this at home you have 2 choices, replace the camera or send it back to the manufacturer for exchange (very expensive)
Jul 27, 2017 | Sony Cyber-Shot DSCHX5 Digital Camera
Lens is stuck,camera wont stay on
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Oct 02, 2009 | Cameras
When turning on my camera the stays on for only a
2 possible problems..
This is due to one of two problems:
First and easiest: the batteries are dead. Im sure you know how to fix that problem.
Second: your lens is jammed. The camera tries to turn on and extend the lens but since it is stuck, can't do so and gives up, beeps, and shuts off.
To fix this problem, send it into a repair shop. it shouldn't cost that much.
I hope that helped.
Regards,
Jeep Brainy
Aug 11, 2009 | Samsung Digimax D53 Digital Camera
Kodak Easy Share Z1275 stuck lens
**** a very common problem with most cameras. There hasn't been much of a solution for this problem except to try to wiggle the lens zoom while pushing and holding the power button.
Also make sure you have brand new batteries installed. Even the slightest dead battery will cause a problem.
Jun 02, 2009 | Kodak EasyShare Z1275 Digital Camera
Kodak easyshare c533 lens is stuck
after 4 seconds view screen pic melts and goes blurry
Oct 19, 2008 | Kodak EasyShare C533 Digital Camera
I have a Kodak 1275. Green light would go on the off and lens was stuck open. Now for solution that worked for me. Get a can of compressed air, like what you use for computer keyboards. Blow the compressed air all around your stuck open lens, not to fast and switch directions of where you blow air around stuck opened lens. Make sure batteries are fresh and fully charged. Tap your camera against the palm of your hand twice, not to hard or you may damage instead of jarring lens lose. Next lay your camera on a table lens facing up, push power button on so camera will try to auto focus and lens should reseat itself and lens should move freely. It doesn`t have to look dirty or dusty, little tiny particles can cause the lens to get stuck and shut off fast because it is a safety feature. If this does not work try plugging your camera into computer so the lcd screen does not try to go on , thus giving even more power to get your lens moving . Do not try to force it closed by pushing or twisting with your hand or you may cause damage that will cost as much as the camera to fix.
Jun 05, 2008 | Kodak EasyShare Z1275 Digital Camera
It wont stay on
the same thing happend to me just now... you have to wiggle the lens untill it goes into place then it should retract when you turn it on. :]
May 14, 2008 | Polaroid i531 Digital Camera
Lens Error - Cool Pix L6 - Camera unuseable
helppppppppppppppp mne is stuck open and it wrks but whn iturn it off it stays open (1/2 of it)
Jan 07, 2008 | Panasonic Lumix DMC-FX10 Digital Camera
Camera Wont Turn on
Please eject camera battery and clean with a pin your battery tip in your camera with care fully.d36f20d.gif
Hope its helpful to you
Oct 17, 2007 | Samsung Digimax L60 Digital Camera
Cameras Logo
474 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
