Question about Cooktops
I have a whirlpool gas dryer mod #LGR7620LW0. Some heat, good airflow, is there a cause for low heat?
    Problem Solver:
  • 11 Answers
Run with vent off for 1 load and see what the results are, just cause you have airflow does not mean it is sufficient, too long a vent can cause that too. and low heat is almost impossible, check it with a thermometer at the exhaust, no vent connected, it should read 155 to 170, it will go up and down!
Posted on Nov 16, 2009
  • david tobias Nov 16, 2009
    run with vent off for 1 load and see what the results are, just cause you have airflow does not mean it is sufficient, too long a vent can cause that too. and low heat is almost impossible, check it with a thermometer at the exhaust, no vent connected, it should read 155 to 170, it will go up and down!
Smeg mod nu.sar93xlpg gas cooktop is 20 years old and in good condition The gas igniter recently has been sparking once every 5 mins. works fine except one spark every 5 minutes,any ideas
probably find that after so long the igniter is starting to fail
call smeg and see if there is a replacement one available
there may be after market units from your local gas shop
Jun 25, 2016 | Smeg Cooktops
What wood cause a burner to ignite and will not turn off.
Is there an orange glow in the burner area when this happens? If so then the thermostat is not shutting the ignitor off and needs replacing. If there is no glow then the gas valve is not shutting off the gas and needs repalcing
Oct 10, 2014 | Whirlpool Kitchen Ranges
LP gas stove top . burners want turn down to low. Only medium and high flame work on burners.
Has this just recently happened? Check the knobs aren't cracked sometimes the brass spindle inside the knob is not gripping to turn it right down, also check your l p gas pressure it should be 2.75 kpa.
if the flames are big and yellow it's getting too much gas, not enough air.
Mar 13, 2014 | Whirlpool WFG231LVB Freestanding Gas Range...
Fame to low on my whirlpool stove
You mean the flame is low. You need to clean the burner jet hole orifice and also check if their is a gas pressure regulator which you can adjust the pressure a lithe more higher.
May 10, 2012 | Whirlpool Stove / Oven / Range Cooktop -...
Spark module wont shut off once it has ignited. Do I need a new one
I would clean the electrodes on the burners really good, sometimes they seem not to sense heat from the burner and will not turn off the ignition system. Other times I fond bad grounds to the cooktop or outlet that can cause the same issue. The electrodes since heat from the burners to shut down the inanition system, also with out a good ground this system is impossible to work correctly.
I hope this helps
Aug 21, 2011 | GE Profile JGP636 Gas Cooktop
Whirlpool gas range whistles when burners are turned on. What is the problem?
Your gas inlet valves are turned up to high or there is air in your system. Most of the time the burners are set either to high or to low. Meaning that not enough or to much gas pressure is being forced through the system.
Jan 01, 2010 | Maytag MGC6430 Gas Cooktop
Whirlpool Cooktop Burners do not light
Hi Scott,
Please view the link and videos below.
http://producthelp.whirlpool.com/Cooking/Cooktops/Cooktop_Product_Assistance/Cause_of_gas_burners_not_igniting%2C_lighting%2C_clicking_or_ticking
Searching youtube can often provide many helpful videos that clearly explain how to repair such issues.
Good Luck.
Jun 02, 2017 | Whirlpool 30 in.GLT3057 Gas Cooktop
Whirlpool electric Cooktop's one burner not heating
Initially, it could either be:
  • open heating element (most likely);
  • open temperature limiter (least likely);
  • faulty/loose connection/wiring (a possibility).
Please confirm that it is a Whirlpool RCC3024 Electric Cooktop.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 11, 2008 | Whirlpool RCC3024 Electric Cooktop
Replace burner seals of gas cooktop
good day,
hope this link below will solve your problem.
kitchen
Sep 03, 2008 | KitchenAid 31 in. KGCS105 Gas Cooktop
Cooktops Logo
96 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Cooktop Expert? Answer questions, earn points and help others
