Question about Nikon ProStaff Laser 440 Rangefinder
My range finder doesn't range as far as it used to. I put in a new battery, but that didn't help.
I bought a new one.
Posted on Nov 18, 2009
Battery replacement for golf buddy range finder
Ask on Internet , All cell types available , even advises you on different make & types, See if you can get old Battery out of Buddy Range Finder,
Mar 14, 2015 | GolfBuddy Golf Buddy - dsc-gb200 - Golf...
Golf buddy pro
Here is a site that carries replacement batteries for the golfbuddy pro gps range finder: Golfbuddy Pro GPS Battery
Sep 23, 2013 | GolfBuddy Golf Buddy Pro GPS Range Finder
My zoom g1x displays BT even though i don't use any batteries for it
You need to replace the power resistor R54:
http://gisywall.blogspot.it/2016/01/zoom-g1xn-continuously-shows-bt-on.html
Sep 28, 2012 | Samson ZOOM G1x Guitar Effects Pedal
My E-scape Speed Boy doesn't hold a charge, I am wondering how far does a full charge go for. Also how long does a full charge take to charge fully?
Take your batteries out, and take them down to .a battery shop. Have the battery load tested, Reading the voltage under no load conditions will not tell you much, normally the batteries voltage gives you its state of charge. These batteries will show a full charge at no load, as soon as you put any load at all on the voltage drops off and you don't have much in amperage output. The amperage is what is important when you right down to it. When load testing your battery they will use an instrument that they punch in the cranking amps. The instrument will look for the voltage drop off at a load of what ever amp value you punched into the instrument. The instrument will give you a pass\fail indication for the cranking amps value the technician punched into the keypad. There can be a problem when load testing batteries. The technician doesn't key in a amperage value, This is what happened to me. The instrument when no value is entered will use a default value, Say the default amperage is usually set at around 200 Cranking amps. My technician was either rushed or just being lazy. He set the load tester to use the default values, my battery passed with the tester set up the way it was. My battery is a 35 amp\hr battery and puts out 480 cranking amps In actuality my batteries weren't putting out nearly that much. It would put out 265 cranking amps for about 2 seconds then die. He told me the batteries were good. When i brought the batteries back to him
i didn't let him take them into thee back room. THIS TIME HE DID THE CHECKS OUT IN PLAIN SIGHT OF ME. I asked to do a comparison between my batteries and new ones. We had to retest a number of time in order to find the upper limit of the new batteries. As it turned out my batteries were bad and all my problems disappeared with my old batteries. NOTE, scooters use deep cycle batteries only Glass mate batteries if you want to take your scooter on a flight.
Now if you had your batteries load tested and you know their good, its got to be the charger thats malfunctioning. Check the charger connection points make sure there tight. One connector should go to the negative battery terminal, the other connector should go too the positive terminal and read +24v. Make sure the connections are solid.
How long does it take to charge a battery? There are allot of variables to this but generally speaking if a charger is a four amp charger and you got a 35amp/hr battery it will take roughly 8 hrs to charge. Batteries typically don't like to be cold. My batteries are 35amp/hr my scooter will go 25 miles @ a max speed of 6 mph. The run time is roughly 5.5 hrs with a draw of about 6amps
Aug 14, 2012 | Electric Health & Beauty
Lost the battery cap for a Nikon LR550 range finder. need a replacement
I also lost the battery cap for the LR550. I signed up for an account on Nikon.com and asked how to get a replacement through the "Service and Support" section. Very delighted to report that they immediately FEDEXed a replacement part - free of charge!!!
Love my range finder, disappointed that the cap fell out but impressed with the service. Will put some tape over the battery cap from now on.
Apr 24, 2012 | Nikon Unisex LR550 Rangefinder
What would cause a clutch not 2 engage on a 19988 harley sporster.put new chrome primary cover on an clutch doesn't work.
U probably just didn't adjust the cluch cable correctly after you feed it in to the notch that I clips into their is a spring and a nut used to adjust the cable tension if it's adjusted to far eat her way it can slip or not let it clutch at all leaving it stuck in gear try turning the slot screw to change tension on the basket
Apr 13, 2012 | 1993 Harley Davidson XLH Sportster 883
My tv control doesn't work and i put new battery's in and that didn't work either
There's a quick test you can do to test the functionality of the remote to make sure it isn't the TV's IR sensor that's broken. To perform the test all you need is the remote and a digital camera (cell phone cam works too). Take the remote and look at the IR "eye" through the camera's screen. Don't actually take a picture simply use the camera as you would a magnifying glass. While looking at the IR eye press a few buttons on the remote. If the remote is working you should see light coming out of the remote. Our eyes cant see the IR light but the camera can. If the remote doesn't light up then the remote is at fault. You can replace your remote on many websites for somewhere in the 20 - 50 dollar range.
http://www.replacementremotes.com/
Here for example, you need to input your TV model number and it will tell you what remote you need with pictures. Then, once you are sure that is the remote you want, you can order right from the same website.
Hope that helps!
Jul 19, 2011 | Televison & Video
When we are deep water (500 ft or deeper) the fish finder will display 3.5-10 ft. and won't show the fish or shows tons of fish. Are we able to set the depth that we would like to see eg: if we are...
Im not familiar with your particular unit but you should be using a low frequency transducer for water over 500'; something like a 50 kHz transducer or a dual frequency transducer like a 50/200kHz for detail with the high freq. but increased depth range on the lower frequency. As far as setting it to 250 ft, you should be able to use the range feature and adjust the maximum to 250'. typically the factory default is automatic so it will caonstantly adjust the range based on the maximum current depth.
May 22, 2011 | Standard Horizon Standard Ff520 Fish...
Red dot finder doesn"t turn on
I had this problem too. You need to go into the "red dot finder" menu each time and just go into each option and confirm the blink intensity, etc. After I do this, it turns on.
Dec 26, 2007 | Meade DS-2130ATS (250 x 127mm) Telescope
Nikon ProStaff Laser 440 Rangefinder Logo
457 people viewed this question
Top Nikon Optics Experts
Mark Campeau
Level 1 Expert
Are you a Nikon Optic Expert? Answer questions, earn points and help others
