-   comp has original vid card have install ed voodoo 2 sli will this card work by itself or does it need another voodoo 2 sli need bios settings for voodoo running win98se what drivers run best whae i c9onnect monitor to voodoo i get nothing-   bronone
The intergrated graphics card "should" disable itself automatically when a video card is installed. You may also be able to manually disable it in the bios.
I had a pendrive of 32GB.it is deceted and also working but after copying files and after removing...
(More)
I had a pendrive of 32GB.it is deceted and also working but after copying files and after removing it and keeping it its not working but occuping space.
I apparently didn't get the "Quick Start Poster" that the box indicated was enclosed on my...
(More)
I apparently didn't get the "Quick Start Poster" that the box indicated was enclosed on my new Dazzle dvd recorder. I downloaded the installation disc then took it out. I then put in a blank dvd and clicked the "start record" button and it sounded like something was going on and a timer was clicking away but it kept going for over an hour after the video (playing in my camcorder and hooked up to Dazzle)quit. I then took the dvd out and reinserted but there were no prompts and nothing showed on my computer screen to allow me to try and play what I had hoped had been recorded. I had my camcorder on, playing the video (which I could watch on my camcorder screen but did not show on my computer screen). Any ideas? Can I download the Quick Start Poster?
when i try to capture it shows green lines through my computer when im capturing is there anyway to...
(More)
when i try to capture it shows green lines through my computer when im capturing is there anyway to get rid of that?
after nearly a year of flawless performance the the system hangs with a gray'd out screen that flows...
(More)
after nearly a year of flawless performance the the system hangs with a gray'd out screen that flows from top to bottom and has a repeating sound loop in audio. This hang only happens while playing WOW (but it is the only graphicly intensive program I run).
